PDA
View Full Version : Engine Management and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 [23] 24 25 26 27 28 29 30 31 32
  1. Emissions. . . . .
  2. AEM uego keeping ELD and O2
  3. obd2b jumper
  4. Tuning S2000 for Race Track, Engine Upgrade, Non-turbo
  5. tunning boost w/ vtec?
  6. b20vtec tuning options
  7. Lambda sensor / o2 heater help
  8. car wont rev past two-step
  9. Knock Sensor options
  10. Retarded. Please check my Freelog CSV // help with slopes
  11. Need input about LM-2...
  12. p72 ecu chipped and tuned for itr?
  13. i R nUb: And want to tune my car myself, so what do I need?
  14. new guy with question...chipping p28
  15. JDM Accord CF4 ECU tuning
  16. chipped p75 (dm4)
  17. How to output correct Innovate LM-2 AF Ratito signal to HondataS300 with P08J ECU
  18. CRAZY AFR issue after turning car off and back on no vtec?? S300 B16a EG
  19. WANTED: copies of Spoon/JUN/etc basemaps
  20. J&s ultra safeguard help
  21. Tuning my own car and for mates...
  22. CEL code 4 and Tacho not working
  23. idle problem with ectune
  24. NGK wideband NTK vs Bosch sensor
  25. rom verification error
  26. Crome 1.5.3 and latest version of Freelog - How to make work?
  27. re tune after tb bore?
  28. Turbo Tune Greensboro, NC
  29. P08J with Hondata S300J Queries
  30. Gsr or type r head?
  31. EG ECU wiring harness
  32. HELP!!! B18 TIMING BELT REPLACEMENT
  33. o2 heater wire circuit
  34. Honda builder's hand book
  35. b16a pr3
  36. H22 Swap Info***HELP***
  37. Does Crome Pro have boostcut, anti-lag and boost by gear
  38. emerald m3d help wanted
  39. apexi neo afc
  40. Looking to upgrade my ecu
  41. Changing Cams..Do Or Don't?
  42. rc injectors
  43. Whats a Oil Catch Can For???
  44. AEM EMS 1000 and 1040??
  45. auto to manual ecu conversion (with factory chip)
  46. Does Anyone Know About The Valves?!?! Help!!??
  47. AIM MXL Dash with S300
  48. Engine harness
  49. 2000 civic with s300 tuned!. Is o2 sensor even used?
  50. plans for my gsr
  51. a friend gave me this..what is it?
  52. wideband with SMC
  53. What to do - OBD1 with Hondata but need an OBD2 for Inspection
  54. Is there a sticky or thread?
  55. help!!knock sensor?
  56. s200 with p28 ?
  57. s300 PWM install pic?
  58. tuning/ chipping ecu advice
  59. Last Atlanta tuning event, February 26-28th
  60. tachometer not working with chipped p28
  61. Best ECU Ever!
  62. heat temp gauge
  63. Whats my ECU?
  64. Hondata boost control solenoid
  65. Which wideband kit to purchase?
  66. buying used S200 what to look for...
  67. Need Confirmation Fast?!?
  68. h22 del sol with "JUN" chipped p28 (poor mileage)
  69. crome basemap
  70. P0501 on 96 Civic LX Auto
  71. AEM 1040 Standalone MAP Sensor Calibrations
  72. S300 settings for turbo built car with no turbo?
  73. SST27SF512-70-3C-PGE showing as obsolete as do several other chips...what now?
  74. FuelInjectorClinic injectors
  75. Chipped P28 to P73???
  76. P28 vtec wiring question -Help Please want vtec hooked up lol-
  77. ECU QUESTION
  78. map sensor or Engine management??
  79. old school ecu question
  80. d15b 2stage vtec(i need help)
  81. rule of thumb for ignition and fuel trim?
  82. bad ecu?
  83. ls/vtec questions..
  84. 95 civic b18c1 revs up and down fast at startup!!!!!
  85. p28 pwm components
  86. Ignition break up
  87. aem 30-1020 box moded for epm cop=probs??
  88. Anyone in the San Jose, CA area willing to help me test an ECU?
  89. What is the BEST weather conditions to tune a car?
  90. Timing retard activation by gear
  91. Need some help with D16z6 swap
  92. Pls Help: Acura MDX Chk Eng (misfire)
  93. dash harness differnce ?
  94. De-pin an obd1 to obd2 jumper harness...
  95. Rywire Harness
  96. ecu comparison
  97. AEM EMS 30-1000
  98. Tuning help...
  99. P0131 -> the SOLUTION
  100. Been searching for weeks h22a IABS
  101. Chipped P06 Code 19 Manual ECU
  102. HELP!!!!!!!!!!!!!!
  103. Hondata S100 or Crome
  104. please help guys - timing question
  105. h22a basemap chip
  106. Help with F/b and turbo zc. . .
  107. lsvtec gsr head s300
  108. F23A1 in off-road buggy, need wiring help
  109. Freelog without Ostrich?
  110. Tuning With Chrome. . .Help
  111. V6 OBD1 Chip ? Is that can be done ?
  112. crome tuning
  113. PID fuel control?
  114. omni power tps sensor
  115. tune gone bad?
  116. Disable OBD2 Fuel Tank Pressure Sensor?
  117. sohc high comp. tuning
  118. Chip question
  119. tuning and break in phase !
  120. acoord ecm??
  121. chipped p28
  122. AEM Series 2 LSturbo need a starting point
  123. aem ems tune - 2 maps ?
  124. GSR swap
  125. Neptune RTP feedback?
  126. AM27c256 chip - what for?
  127. Help i need to find a good tuner.....
  128. ls vtec no start
  129. 92 prelude h22a ecu question
  130. Knock Input Volt
  131. Chiped ECU or Stock ECU????
  132. tuning pole Hondata vs Chrome for allmotor?
  133. Non-Typical H22A Swap Help
  134. CEL after S2 IM, ITR cams and ECU install
  135. Ostrich 2.0 Is it worth having?
  136. If I disable knock sensor in crome do I have to unplug it?
  137. Replaced O2 Sensor and still get Check Engine Light On.
  138. Possible tunning problem
  139. HELP with obd2a spoon
  140. solid cel... but car runs and drives...
  141. seeking help of 98vtec
  142. compression?
  143. what hardware do i need to have for neptune?
  144. Turbo'ed & Tuned????
  145. checking check engine lite w jumper harness
  146. ls turbo questions
  147. Problem after clipping J1 jumper...
  148. Is it possible to disable o2 sensor?How?
  149. b16 a2 swap into a 96 hatch questions and problems
  150. New To Site :)
  151. LS/V tips,tricks,help
  152. Looking for a good tuner for northeast?
  153. anyone use hks vpro?
  154. TESTED: CROME works with Hondata S100!!
  155. Help in hondata S300 distributorless
  156. whats a good wide band
  157. E85 Help...
  158. Data logging with PLX M-300TE?
  159. reliability?
  160. PLX wideband gauge not reading
  161. P73 ECU
  162. Mods delete
  163. Base Tune for LS Turbo (T3/T4, 8psi, DSM Blue Injectors)
  164. Recommended Tuners?
  165. How Do I Datalog Hookup for AEM WB w. s300
  166. ECU question. b16b/b16a
  167. Greddy Ultimate on K20 don't start
  168. I have a couple questions about my LS swap. Appreciate any help, Thanks.
  169. neptune vs. crome
  170. have you ever seen this ecu for a b series?
  171. have ever seen this ecu for a b series?
  172. Hondata s200 questions???
  173. whats the better system
  174. whats going on with crome
  175. looking for accurate parts list (moates Vtec conversion)
  176. ???????Weird Jerking.... Ideas???????
  177. Tuned for 93, now what? Moved from SC-CA
  178. any good tips for idling 1000cc's?
  179. ECU problem - auto to manual swap
  180. tuning questions
  181. MAP sensor :/
  182. B20 Vtec built now needs to be tuned! What's the best affordable way to go?Crome/s200
  183. Have S100 want to go Crome???
  184. ecu pins
  185. coil on plug and T1 cam trigger
  186. new set-up not running right.
  187. p28 or p72
  188. B20B Vtec swap need help with tuning questions?
  189. Issue with P61 or bullsh@t?
  190. missing coolant WTF?
  191. Need Greddy E-manage ultimate software!!!
  192. OBD1 CEL Code 2
  193. will this burn obd0 chips?
  194. Breaking up in boost
  195. SAFC on a Diesel tuning via TPS
  196. Calculating Ignition Timing?
  197. crome tip in?
  198. Which Distributor to Get?
  199. Do you have experience any of these engines better?
  200. need base map for s300
  201. Does the 2003 Acura TL have high flow cats?
  202. How Do I Increase compression ratio on Acura 3.2
  203. Air temp sensor needed on OBDI?
  204. AccessPORT Update: Rev-Hang Eliminated
  205. Freeware datalogging programs?
  206. 2.2 vtec can't idle when warm?
  207. crome tuning
  208. 94 Civic water circulation problem
  209. best timing light?
  210. hey peeps hondalog dont log high cam
  211. uego to ems
  212. h22 tuned for non vtec (is this hurting my motor)
  213. Pulley broke :shrug: IDK... But helppppppp
  214. wanted
  215. Can you download s300 on Mac?
  216. H22 Swap ECU question
  217. Little help diagnosing a problem
  218. My R.P.M. bounces I need help
  219. Slight Misfire: Help
  220. IAT sensor upgrade
  221. Need help! Wit map sensor
  222. 5-speed ecu on an Automatic
  223. When do you tune
  224. b20v ecu question
  225. 3 bar map help on honadata
  226. which map sesnor do i selecton my s300
  227. need help finding a resistor box
  228. RC Injectors
  229. hondata s300 software virus?? confused
  230. 00 civic under dash pinout?
  231. launch control always on? ectune
  232. Hondata A/F ratio on a K20
  233. Delaware Tuning?
  234. LS/VTEC info/feedback?
  235. Before i go tune, Can i break 500whp with this set up. Need help asap.
  236. Decent Tuner Shop in Michigan?
  237. Decent Tuner Shop in Michigan?
  238. Buy S200 or modify ecu for s300?
  239. my gsr ecu is crazy...im stressing
  240. need s300 1000cc basemap or tune
  241. check engine light on but no code,hondata
  242. b16a keeps killing 2 spark plugs help
  243. Hondata S300 CEL code 13 Baro Sensor
  244. obd2a to obd1 Conversion Question??!!!!! Help!!!!
  245. Basemap for vtec-e
  246. Hondata S300 Launch Setup
  247. Converting to obd1 and hondata???
  248. OBD2 conversion to OBD1 question?
  249. Spark plug wire keep poping out of cylinder NEED HELP!
  250. installing injectors
