- H22a tuning help please!
- Euro - Disable 'auto-choke' on cold start?
- problems with rpm
- p72 ecu jdm or usdm?
- Help me please
- OBD1 CRX Si B17a1 running RICH!
- correct wide band ratio for turbo sohc?!
- P2P ECU?? pics
- b20 vtec ecu question
- P0685 Code Need Help!!!
- Adding datalogger to Hondata s200
- WHATS A GOOD (HIGH)REVING HEAD FOR A B20?
- Mixing Meth with gas
- tach works but no revlimitor with crome..?
- Help ecu trouble code 3
- Will a P28 chip work on a P05 conv. into vtec?
- Wanting to learn more about ignition mapping
- VW guy in need of your help
- crome pro and aem wb
- Data logging for break up after 12psi >>
- PS9 ECU Troubles
- good vafc setting for b16a2?
- problem I cant figure out
- running hard for long - BOOST
- LOOKING FOR TUENR IN AREA !! @LOOK@ IL/WI BORDER !
- e management ultimate and aem uego
- AEM water/meth injection (please dont move)
- setting up ECU for PWM, ? about D14
- ?DIY what to look for IN GOOD TUNER ?
- cel code 22 had enough! help please
- Wideband and Narrow Band in one O2 Sensor
- ECU fuse blowing when A/C on
- OBD II Emissions Idea
- heeelp i think i fried a resistor!!
- Pulling the chip question
- b20vtec swap help
- AEM EMS and emissions
- Need help with car running problems
- Spoon Sports PR3 b16a ecu
- vtec engagement point on a b16a3 turbo
- s300 boost problem or mac valve
- datalogging in cn2
- Should i get a tune?
- ignition diagram for 1990 to 1993 accord needed
- desoldering help
- Moates Hulog Problem on Crome PRO
- Need help Greddy ultimate E-managment to AEM UEGO Wideband
- P73 DC2 Pin Data/Plug Data anyone?
- AEM EMS compatibility
- KMS engine development
- j32 EG swap- NSX ECU?
- B16B S300 base map
- s300 and pr4 ecu problem
- pull basemap from chip to laptop, can it be done??
- ECU memory
- pros/cons on disabling closed loop???
- demon and crome
- Nitrous ????
- wideband hookup to chipped ecu?
- Neptune tuning issue
- what pin is AEM using as switched power?
- S200 plug question.. need some help
- trouble shooting map sensor
- base map before tune drivability
- trying to get ahold of RSTECH
- Hondata s200 Base Map Questions
- hondata s200
- B18c5 Internals
- Freelog AFR issues
- Injector Sizing Help
- crome messed up
- can someone tune my p28 w/s100
- suddenly running rich while warming up???
- Low Voltage at the injector clips!!
- No bat reading S300 sensors window
- Cel light comes on when tuning...
- apexi vafc1 issue. please help!
- having a hard time controling injectors s300
- 2008 Honda Civic Si N/A with Mods FlashPro Dyno Tune Question
- AEM EMS, MSD DIS-4 question
- setting up PWM
- I think I fouled my plugs
- Looking for a d16 aem map/cal
- Where did you put your PLX sensor module
- What computer equipment do you use to tune?
- best non v-tec ECU to add v-tec
- Can't get engine to idle down
- Tuning an OBDII w/auto trans
- ecu help
- car running rich?
- retrieving s300 datalogs?
- Is it possible swap B18 LS engine automatic?
- Anyone use the new AEM Needle style Wideband gauge yet?
- wonky idle
- Hondata ecu
- ecu management
- tuning question
- acceleration problem
- help with lm1 +lc1 wideband kit
- Neptune Experts Needed
- 2nd injector stuck open paypal reward of $20 for a real solution
- advance until it knock,, how to know ??
- Need Help AEM Twin Ignition Wiring OBD2 (1060 box)
- Looking for dyno tuner in san diego??? help
- Question about Neptune's Input/Output feature
- Faster burn: rich or lean?
- Question
- Questions on k20a swap on ep3 Im New to everything.
- NEED TUNER, ANYONE LOCAL >? MID WEST ! @LOOK@
- fuel management help!!
- H22A tune.... 90% stock/ Neptune ECU
- JDM h22a boosted, no power
- question abour k and b series? plz help
- vtec ecu on nonvtec?
- best for spray
- Neptune Demon Vs Hondata S300
- tune on obd2 with crome
- S100 gsr basemap help
- DA ENGINE HELP PLEASE HELP ME
- Understanding Ignition maps fuel maps
- gsr obd1 question
- i need a tuner asap chattanooga,tn
- B18B1 Rebuild assistance!
- Car wont idle once warm
- Which ECU do i need?
- s300 2000 prelude JRSC 02 sensor
- Haltech - K-series support / Plug and Play development
- I want to learn how to tune
- Is it okay for me to turn up the boost?
- converting an auto P28 to manual
- Does hondata allow you to see how the ECU works?
- d16y8+p28 ecu throwing code 9 (No.1 cylinder position sensor)
- Motec Gear Detection.
- Power FC: Reset Idle Learning Function
- AEM Uego Wide 6-in-1 -> Gauge+ECU?
- Wrong basemap?
- Mixed Engine problems
- HOW CAN I TELL IF MY B20 IS HIGH COMPRESSION?
- #2 cylinder exhaust valve keeps breaking
- d16y8 and timing in hondata?
- So does J. Cui just live in a cave now or what?
- Can you add the components to an ECU board to support wideband? IE: VX OEM wideband
- Finding MBT and spark plug reading on the dyno
- new clutch, neccesary to retune?
- tuning time/process for a fng?
- Moates Flash N Burn + Chrome
- dead ecu/RTP board? or why the hell wont my car run
- crome pro quick question
- rtp dataloggong not working
- 20-21 PSI on pump gas... D16a6.. safe?
- Hondata S300 Templates
- crome launch control and boost
- Chipped p28 problem
- Tuning Question
- Question about hondata s300
- obd0 chip in obd1 p28 ecu
- burning neptune onto a chip
- 1991 Accord Pulley Problem
- p28 ecu problems help!
- What's the max stock ecu can modify a/f?
- NO ONE TUNES CROME!?!
- where should i get aem ems civic tuned at...help!!
- Overheating issue and odd looking dataloggs....
- tuners
- how to tune with hondata s200??
- need help with map sensor voltage... for crome
- How much driving can I do using a phearable base map b4 tuned?
- hondata s100 with boost option
- What all is involved with basic chipping?
- injector stuck open. many tries with dif stuff
- Quick question about chipping a obd0 pm6
- can anyone tune with the wideband values?
- question about ECU and a chrome p72 chip
- I think this might be a tuning problem please help
- Imobiliser Problem
- Looking For a TUNER. (hawaii)
- Freelog error message
- ls vtec + s300 = no vtec
- obd1 p30
- injector upgrade question?
- If you have AEM EMS, any benefit to Aem Cam Gear
- ecu problem please help
- leaking oil behind distributor
- LC-1 Help with crome and freelog
- 10-1 gsr with stock p72
- strong mini me
- how to convert an obd1 p75 to run vtec
- H22A + P30 problems
- weird hondata s200 problem
- using a boost controller with a chipped ecu
- Jdm H22a ecu question
- b18c1 tuning
- e85 tuning questions
- question on running 8 injectors
- My tune seems to be changing all the time, tuners need advice
- open loop vs closed loop
- obd0-obd1 quick feedback needed
- Jdm H22A tune, what kinda wot ignition timing.
- Engine Overheating Mystery
- 2timer Issue
- jdm p72 or obd 1 non vtec ecu
- Need help with a turbo F22 basemap please
- i think i gots a bad injector
- B20b Base map?
- code 22
- Ecu A/C issues
- Terminals & Connectors
- top tuners please post your first tuning mistakes
- grounded starter wire, solid cel, fried ecu/hondata? how can i fix?
- Basemap for 100% Stock GSR w/ S2 IM (No IAB)
- b20b wiring questions
- CTR s300 base map
- AFC/vs. Hondata Basemap
- Smanager V 1.4.1 crashing pc
- p28
- red light
- map code 3
- 96+ JDM ecu pin-out
- cel for knock sensor
- Remapping p28 using SAFC2
- help me please
- AVG anti-virus reading s300 software as VIRUS! help
- D16 Crank shafts?
- AEM EMS 1050 Civic 99 startup issues
- P30 upgrade question
- B18C No VTEC after warming up
- need help figuring out if my RC injectors are saturated or peak&hold??
- ANYBODY HEARD OR USES GLOWSHIFT WIDEBAND CONTROLLER?
- Need pic of AEM AFR gauge's backside wiring
- Greddy Emanage
- wideband datalogging s200
- basemap for crome
- s300 b18c5 getting tuned
- data log play back, live graphing, crome update?
- Loaded basemap on s300 No Spark
- Hondata & safc?
- ok im confused
- s200 or s300
- Hondata display issue
- Itr & ctr ecu
- going lean, whats that noise??
- I put 5w20 in my 99 Ex stock engine. is that ok?
- AEM ems users that have JRSC. POST HERE!
- Hondata Help...
- help with re-swap wiring
- What tps to buy?
- where to tune?
- aem base map
- Please HELP!!! OVERHEATING PROBLEMS
