PDA
View Full Version : Engine Management and Tuning
Pages : 1 2 3 4 5 6 7 [8] 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. at what afr do you start to wash the rings
  2. pct ctr ecu specs?? pct on b16a??
  3. hola buenas algun espaņol o latino que hable espaņol por aqui?
  4. p28 ecu with a gsr motor run p72 stock map?
  5. Correct Stock MAP min/max mBar?
  6. Ideal AFR for B16A
  7. lc-1 wideband wire obd1 with neptune
  8. Do I need a tune ?
  9. wideband on d14 - obd1
  10. B20vtec swapping to b18c5 in dc2 gsr. Help plz
  11. AEM FailSafe question
  12. p28 capacitor locations
  13. P28 D16Y8 HELP
  14. P28 + Neptune + 02 ?
  15. neptuneRTP: using B5 AC switch for map switching
  16. Coilpacks & jdm ecu's
  17. p28 ecu problems
  18. WOT ignition advance tuning for D16 all motor
  19. HonDash -Specifications and Description
  20. Civic Type R (EK9) Base Map (B16B)
  21. F22B2 base map for hondata?
  22. F22B2 base map for hondata?
  23. neptune ignition limitations + ignition adjustments questions
  24. IAT corrections, 135* IAT vs 105* IAT
  25. Crome vs. Hondata on a B16B in a CRX
  26. Rich AFR Idle and Cruising
  27. Looking for tuning advice turbo b18
  28. Why so lean on a cold start?
  29. 99 prelude
  30. crx d16zc auto chipping/mapping???
  31. wot 6k rpm cuts off
  32. AEM wideband on 95 civic d16z6
  33. B18a1 fully built low compression turbo extended crank/intermittent no start HELP!
  34. high cam operation still reads low cam tables? crome pro
  35. high performance academy online course???
  36. NeptuneRTP fuel cut prob??
  37. WERE TO DOWNLOAD ECTUNE?
  38. 06 TSX MT. K20Z3 VTC wheel and Hondata reflash questions.
  39. lean spike with small increase of tps neptune
  40. s300 idle drops when AC or fan turns on
  41. Chip remapping
  42. Errorcode 20 ELD - DelSol D16Y8 to B16B swap
  43. Quick questin about e85
  44. What do I Have???
  45. ectune tuners near pa area
  46. Tune in cold weather?
  47. ABS light Integra Type R with OBD1 ECU
  48. GSR eg6 rough idle after dyno tune
  49. Neptune rtp code 14
  50. No throttle after hitting rev limiter
  51. need help please
  52. Tuning Solutions in Texas
  53. Chip pins about to break!
  54. Speed sensor (vss) signal B18c
  55. Florida Man Sentenced in Federal Counterfeit Case
  56. kpro and water temperature gauge wiring
  57. s300 help
  58. b18c jdm type r OBD2A Connector Help
  59. b18a1 aem ems v1 basemap download
  60. F22a6 turbo base tune
  61. b16 adjustable cam gears/timing help (noob question)
  62. 1997 Honda Del Sol S ECU VTEC
  63. new cam, slightly different setup. need it to idle
  64. H22a euro R obd1 or PCD ??
  65. Southern Ontario modified honda expert needed
  66. b18b1 obd1 to obd2 emissions help
  67. Rich cold start on b18c1 w/ type r pistons
  68. Setting up inputs for logging EMAP and Fuel pres on Neptune.
  69. Narrowband O2 Simulation - Innovate LM1
  70. Tuning turbo 95 integra automatic p75, help!
  71. VTEC Pressure switch on s300
  72. Ignition Dwell adj. Advantages/Limitations (NepTune)
  73. NepTune NOOB!!!
  74. Apexi Power FC - Engine Light?
  75. s300 launch control question!
  76. Problems with fuel injectors or s300.
  77. A thread posted when everything is good.
  78. Hondata S200 WARNING
  79. s200 questions
  80. S300 and boost control issue
  81. Will adjusting fpr mess with tune?
  82. Tuning at HPTautosprt in Asheville, NC
  83. AEM 1010 W/ EPM, KSeries COP setup
  84. trying to idle e85 with 1680cc what a ......
  85. Any unofficial repositories for S300 maps out there?
  86. crome - GOLD MAP vs P30 BASE
  87. Ecu help urgent
  88. 94 civic build
  89. Burning Ostrich tune onto chip?
  90. Cruise Stumble S300
  91. P1259 rsx engine code
  92. b18c4 tune
  93. use s300 v1 on stock car?
  94. NepTune/Demon
  95. spec's of a stock B-Series ignition coil
  96. fueling poblem mystery now with gsr motor
  97. Boost Ignition Table Insight / Advice
  98. how would you control 8 injectors with s300?
  99. P08 Ecu tuning program _ need
  100. 2001 Civic Backfires & Shuts Off
  101. ecu confusion
  102. 99 Ek Hatch w 97 GSR motor CODE 4 issues please help!
  103. Neptune y8 map timing sync question
  104. aem uego and crome pro connection problem
  105. 2005 V6 ACCORD O2 Scanner code.?
  106. 91 civic dx
  107. b16 in a 1950 citroen traction avant wiring?
  108. Crome Pro datalog graphing
  109. eCtune help....hulog problems
  110. Question about making basemap
  111. Phearable Tuning...
  112. honda ecu experts. bbg pwm. check this out! wtf???
  113. Kpro gear ratios
  114. Solid CEL and IACV humming
  115. Higher quality jumper harnesses?
  116. honda accord v6 2001 which EM?
  117. P2P ecu on a stroker
  118. Chrome closed loop erratic idle
  119. Looking for some "Old School" builds.
  120. Rev Limiter Not Engaging
  121. rusEfi - DIY ems build thread
  122. Stock P2P ECU on a stroker build?
  123. s300 v3 advantages over v2
  124. s300 data log problems
  125. test your pwm boost controller
  126. Any tuners please help
  127. Best ecu for 98 civic ex
  128. rev limiter always hits lean cut. innovative wideband datalogs stoo fast
  129. Help adjusting fuel using s300 at idle
  130. Whos good at reading kpro logs? Fuel cut and overheating help?
  131. Ebay Chip AC Off at WOT
  132. Help with s300 BBG set up
  133. boosted civic si....needs tune please help
  134. Anyone had problems with on-board logging not working on Neptune?
  135. Buddy Club Spec III's idle issues on Crome?
  136. SManager Help Error on Windows 8
  137. Total timing
  138. Can you comment on dyno graph plz
  139. B16 SPOON ECU
  140. how much is my Hondata worth?
  141. S300 v3 boost by gear included?
  142. try this on for size
  143. OBD 1 help
  144. Id1000 b18c basemap
  145. Boosted h22 tuning question. s300
  146. CRX Swap Tuning Problem
  147. S300 Breaks up during shift
  148. crx OBD0 code 17,43.
  149. D15b7 sohc ignition help
  150. Obd0 to obd1 wiring questians help!
  151. P28-A52 blew diode d10. Help diagnose please.
  152. Full Throttle Shift in Crome free.
  153. P28 Question
  154. p72 ecu problem
  155. S300 - Car runs different when I enable B5 for datalogging
  156. 1990 integra b18a1 obd0 to obd1 conversion questions
  157. need some guidance
  158. 2 liter type-r on stock ecu?
  159. 92 honda civic grinding noise and won't start
  160. s300 issues possibly. h22 turbo swap
  161. Who makes honda obd 1 and 2 scanners
  162. Throttle tip-in / tip-out under boost question
  163. s300 no upload!
  164. SDASH app hondata s300 for android
  165. Help identifying engine harness
  166. 1997 Honda Civic
  167. xenocron obd0 tuning?
  168. What advantages would using a s300 over chrome
  169. D15b7 with d16z6 head vtec won't work
  170. HP Academy...anyone ever done it or heard anything about it?
  171. 1990 integra no spark
  172. injector question
  173. Crome need help tuning,
  174. Crome need help tuning,
  175. need help!! with install of s300
  176. Neptune 10psi boost cut
  177. help in need of a crome base map for a f22b1 or f23a
  178. Hondata s300 random lean
  179. 1993 Del Sol 1.6 4th cylinder not sparking correctly
  180. Tuning: Compression Ratio Change Questions
  181. AEMLog Cannot get Internal Logging working
  182. CYP Sensor and Ectune
  183. looking for someone to help me fix my come pro datalog
  184. Just upgraded from chipped Neptune to RTP: adjusting launch?
  185. Hondata S300 v2 question
  186. 2009 civic si was turbod but now returned to stock and just turns over???
  187. Need help with a dam science project build
  188. beginner here, just got a spare P06 for my EJ2. i want to maxamize MPG
  189. Misfire, studder, Rev limit, HELP!
  190. ECU modifications/piggyback/chip help understanding once and for all
  191. download for chrome not working?
  192. BBG on Crome GOLD?
  193. Aussie D16Y4. ECU Help!
  194. Solid CEL goes off when jumped
  195. Bad ECU?
  196. Hondata s300 questions/help
  197. Fuel Trim Imbalance at Idle
  198. Fuel Injector Phasing Calculator
  199. Tuning With Chrome/ New Tuner Needs Advice.
  200. Obd1 pin 21 & 22 (Sensor Grounds) how much voltage does this support?
  201. Coil Pack/K20 Ignition, on b16/18/20
  202. Skunk2 Pro2 tuning help
  203. Default D16A vtec-e (2stage) in need for base map.
  204. where can I buy ecu components
  205. Kpro vs Aem ecu
  206. AFR running rich after skunk2 tuner2 installed
  207. EVAP, Catalytic converter, O2 all read NOT READY
  208. engine calibration
  209. Odd issue, possible ecu problem.
  210. Fuel vapor Lock? or what
  211. Hondata s300 help
  212. AEM Failsafe Wideband signal out question
  213. Fried Ecu Fixable? Solid CEL
  214. Help needed for tuning auto cars using OBD1 solutions like Neptune, Crome, etc
  215. Good Dallas, TX Tuner
  216. what is needed to tune an engine?
  217. Map sensor setting
  218. EG jumped wrong DLC connector??? help????
  219. This is my TIY thread using crome pro (b18c5 + jrsc) smf autox car
  220. Did I get a bad tuned ECU?
  221. Code 1 O2 problem
  222. PGMFI with tps?
  223. Hondata s300 v3 can't record data while driving(without laptop)
  224. H22 Turbo Vtec boundaries
  225. Neptune RTP datalog. Looking lean, need help.
  226. ecu,fuel pump relay and other trouble
  227. ecu,fuel pump relay and other trouble
  228. Closed Loop Stuffing up my Crome Tune?
  229. Non responsive MAP sensor
  230. How do I set dizzy timming with s300
  231. Hondata s300 cutting power.
  232. ECU Chips
  233. Removing IACV on Crome and Hondata
  234. Android App for datalogging
  235. how can i supply 12v to ecu without car
  236. EM1 Wideband question
  237. does anyone have OBD1 P72 ecu circuit board diagram
  238. B16a2 fuel pressure rises high
  239. subaru 560CC PINKS top feed dead time/offset question
  240. Fully build d16z6
  241. Hondata -NEW Traction Control Feature
  242. basemap sharing
  243. horrible cold starts on 94 gsr/runing rich.
  244. Double-Din Parameter Monitoring
  245. S300 not reading sensors
  246. limp mode while logging
  247. Turbo B16 boost by gear troubles, Neptune, stumped!
  248. Burn chip with hondata s300??
  249. Weird Datalogin Ign.Avance
  250. spitting LOTS of moisture on cold start e85, any fixes?
