PDA
View Full Version : Engine Management and Tuning
Pages : 1 2 3 4 5 6 [7] 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Which area is 'vacuum part' of the map when tuning ignition
  2. Crome fuel cut and ignition cut when overboosting?
  3. High Compression & Ignition tuning
  4. Ecu harness quality
  5. Hondata S300
  6. DA Integra ECU clock crystal speed/frequency?
  7. EGT (and other) Sensor Options
  8. Hondata s300
  9. Engine Running Lean
  10. Neptune B20V base map
  11. No longer logging data
  12. O2 Sensor Question
  13. ECU map question
  14. AEM water/methanol "boost safe" feature with Neptune.
  15. o2 sensor cuts out
  16. New to tuning, few questions on basemaps
  17. Data logging error?
  18. Need help with hondata s300 p28
  19. Tuning With Lambda % Differential
  20. overheating because not enough ignition timing?
  21. E85 tuning
  22. good read about o2 sensor troubleshooting
  23. fluctuating idle when warm
  24. Neptune Issues, No data to be logged, or on program gauges.
  25. Quick question about MBT
  26. PGMFI.org Redirect
  27. P72 OBD1, ECU check out?
  28. Need basemap for built h22
  29. Setting Up CROME Pro
  30. tunerview 2 with crome pro
  31. K24 swapped rsx
  32. Rust on hIc2 board on a jdm p30 ecu where can I find one of those boards?
  33. New engine harness and now tune is off?
  34. 2000 civic em1 no start with chipped Ecu
  35. tunerview rd1 with crome gold.
  36. CROME Ignition Timing Location
  37. Making my base map with Neptune, questions.
  38. B20VTEC tuning advice
  39. Hondata Tuning shops denver
  40. Sst chip identification
  41. OBD1 B-series ECU used on OBD1 D-series motor?
  42. Can Hondata do this?
  43. S300 V2 vs S300 V3
  44. Hondata s300 WOT BOG AT 4800 and up rpm
  45. TCM/TCU Tuning Question
  46. P75 to P28
  47. Tuners?
  48. Hondata s300 Tip in Fuel Initial Normal Tables.
  49. b16a2 build
  50. 93 civic si hatch injector problem
  51. B16 turbo hondata base map help
  52. is this ecu no good?
  53. oxygen sensor obd2a-b questions
  54. Uploading base tune to S300 on Desktop in living room??
  55. Dyno tuning in or around North Atlanta?
  56. ID1700 Injectors have officially been released!
  57. D16y7 fuel injectors for obd1 civic
  58. Tuners in San Diego
  59. Ready spark plugs so I can drive to tuner lol
  60. o2 Lambda app readings
  61. what happened to pgmfi?
  62. Hondata help! AC not disengaging
  63. SOMEONE PLEASE SIMPLIFY
  64. A04 ECU in a 01 Integra LS
  65. Factory ECU REFLASH
  66. Aem epm
  67. Injector latency?
  68. Cant open bin on Crome
  69. AEM EMS coil dwell factor
  70. ID2000s E98 - idle/run issues
  71. No vtec...no thermostat
  72. t1 cop with rsx coil tach issuse
  73. Fuel cut
  74. What's up with this ecu?
  75. Fuel pressure??? New intake manifold & TB
  76. Need Basemap b18b Integra
  77. 92 EG GSR Swap Code Reader?
  78. WOT duty cycle spike
  79. B16 JRSC S300 lean idle, surging, dying
  80. PGMFI.org site down?
  81. AEM EMS coolant issue
  82. auto lean when tapping throttle.
  83. Using wrong wiring harness + ECU? Transmission related
  84. Wiring crank sensors to AEM FIC on 01 Prelude
  85. got to the track no 2 step...... wtf..crome pro
  86. Hondata S300 vs Crome vs eCtune vs Neptune fuel tables
  87. P06 chipping with d16y8 motor?
  88. Hondata CPR kit Help
  89. how does throttle tip in work?
  90. Laptop connection to ECU for monitoring perposes
  91. Problems with NB simulation on P30 ECU
  92. Possible Rolling Anti lag/launch control Setup?
  93. hot start idle low for 10-30 sec
  94. need help with emulator
  95. JDM B18C TYPE R basemap
  96. Ecu swap for h22a
  97. What is neptune exactly?
  98. Remote tuning! What is all about?
  99. k20a2 with z1 cams
  100. Ostrich not connecting to ECU
  101. f22b2 basemap
  102. help
  103. Nitrous Tunning????
  104. Hondata help!?
  105. Dyno Tuning
  106. A few issues chipped jdm p08 ecu
  107. ECU Chipping...Solid CEL. Need help =/
  108. I need some help deciding on a chipped ECU
  109. ecu modified??
  110. Will a virgin p28 run my setup?
  111. Converting from Neptune to Hondata?
  112. more s300 driver help
  113. hondata question
  114. Can I use an unused pin?
  115. Reading Spark Plugs - A Discussion
  116. jdm h23 dohc vtec basemap anyone?
  117. Ectune can't connect to car
  118. help!!!! tune ecu ... readd more !
  119. Can someone help on standalone ecu..please
  120. crome pro afr datalogging
  121. d series super charged nitrous
  122. B16a2 to b18c5 ecu tune
  123. Bluetooth Datalogging
  124. what am I looking for when checking plugs
  125. b18c4(gsr) timing question
  126. Hondata S300v2 Water/Meth Fail Safe wire hook up? Transducer
  127. AEM 30-1040; what are they going for?
  128. Switch from Crome to Neptune
  129. jumper harness/stock p30/ or chipped p28
  130. Back probing an ECU
  131. How to use Virtual Dyno Properly (Good Repost from another forum)
  132. Default Anyone have a neptune basemap for a Y8?
  133. smoothing your dyno graphs and tuning...
  134. vortech SC b18c5 maps
  135. PLEASE HELP! F22a6 Boost Tuning
  136. does iacv stay open during acceleration?
  137. Obd2 to ob1 conversion help
  138. problem with my ecu please help
  139. Target Air/Fuel Ratio Map?
  140. Aem v1 1040 box base tune
  141. tune needed after change in vacuum routing?
  142. fuel tuning in boost.
  143. noob wideband question
  144. Hondata and B18C1 GSR. Help.
  145. Trying to get this street tuning thing down
  146. Constant code 41 after studdering issue?
  147. Hondata Not Datalogging Correct AFR Numbers
  148. AEM v2 30-6051 , Mag to Hall
  149. 1993 del sol ecu name? Si model
  150. Ignition adjustments. Why to keep them enabled?
  151. AEM V2 IQ3 problems
  152. Mil-spec loom
  153. FIRST DYNO SESSION: How to know when to stop?
  154. LS/Vtec civic bogging down when vtec kicks in at 5k
  155. B18cr and stock ecu
  156. Need help 93 hatch b18b1 stall problem
  157. Chipped obd0 pr4 questions.
  158. Best tuning software?
  159. ? bolt ons and tunes
  160. Help!! Tune or mechanical issue??
  161. Texas Inspection Question
  162. Sir f20b ecu recommendation
  163. p73 chip in gsr ecu obd2b?
  164. Why the p28?
  165. Can anyone still do eCtune licenses?
  166. First tune.
  167. Aem series 1 ems
  168. obd questions
  169. Need help 93 hatch b18b1 chipping issue
  170. engine parameters calculator?
  171. F22b2 basemap for crome
  172. SmartFire Injector & MAP Sensor Warning
  173. H22 Crank Trigger With COP and AEM
  174. Glowshift wideband with S300v3 how do I connect to ecu?
  175. P28 S300 CODE 14
  176. Lean idle and lean 50% and under throttle(s300)
  177. g101 ground
  178. BAD idle (missing/popping) d16z6 (vid included)
  179. VAFC2 Question regarding setting storage
  180. need help ecu
  181. neptune tunerview and s300
  182. Will P06 with S300 work In b18 del sol?
  183. tunning hondas
  184. p28 chip problem
  185. 2000 civic si B16A2 tuning question?
  186. how can I set my rev limiter?
  187. a question for knocksense or other knock sensor users
  188. Do I have to install an aftermarket ecu or can I flash the stock ecu
  189. Crome unknown problems.pls help!!
  190. Help with auto CRV tuning....
  191. GSR p75 obd2b immobilizer
  192. Ecu for both B & K series.
  193. idk whats what help
  194. engine removal
  195. weekend of fixing cel's and vtec wiring
  196. JDM dc5 type R with Kpro PNF ecu
  197. hondata question
  198. AEM UGEO wideband and Hondata s300
  199. afr at idle and cruising s300 turbo motor
  200. Help with my obd1!!!!!????
  201. Crome Datalogging Problem
  202. gsr with type-r internals on stock p73 ecu?
  203. question for Power FC tuners
  204. Tuning In Denver
  205. rewire oem knock board for neptune/hondata?
  206. hondata s300 nitrous control
  207. Central FL dyno recommendations?
  208. crome tuning, poping with lights off,
  209. Tuning Dual Fuel Rails
  210. Injector choices
  211. buying ecu worries...
  212. 97 civic hx o2 sensor issues. help!
  213. Hondata s300 vacuum unit
  214. stock ecu difference?
  215. p28 d16z6 more aggressive????
  216. f22b1 vtec base map for Hondata
  217. Need a Custom Base Map Help
  218. s300 map or tps
  219. Need a stock JDM P73 map for Crome Gold
  220. Ignition monitoring with Apexi AFC NEO
  221. How to terminate sheilded wire through a circular bulkhead connector?
  222. Hondata Fuel Tuning Noob Questions
  223. Tuning query
  224. NepTune Version2?
  225. IAT placement
  226. Need guidance guys
  227. NEWS: Introducing Hondata K-Pro Version 4
  228. eBay USDM ecu was jdm
  229. Is there software for logging AFR only?
  230. Leaving eCtune...Hondata or Neptune?
  231. Zeitronix zt-2
  232. 98 civic won't start
  233. radiator pushing out water
  234. Running 8 Injectors...
  235. help please
  236. Open loop control
  237. Crome is broken, again
  238. street tune after swapping parts have a question
  239. NEED HELP!!FOR PPL WITH TRUBO CARS
  240. AEM EMS 4
  241. hondata issues
  242. AEM fan control?
  243. Crome Highcam ignition issues debugged / Bandaided
  244. Can i run 93 on a 12:8.1 comp build in b18-c1?
  245. 92 Civic/B16 swap - 2K rpm cold idle, low warm idle and cuts off
  246. Why Does My B20 Swapped DelSol Run Fine With No Tune?
  247. does LC-1 really need free air re-calibration
  248. OBD0 to OBD1 ( Pinout )
  249. LC-1 AFR voltage table
  250. needing help
