PDA
View Full Version : Engine Management and Tuning
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. obd2a vs obd2b
  2. How many catch cans
  3. L15B7 internals on an L15A7
  4. Why are there so many threads on can't advance enough
  5. What ObdII Ecu can i run in a H22a
  6. Datalog cable cant connect no matter what
  7. Immo off d15z8 P9L ecu
  8. Need a stock JDM P72 map and B20B for Crome Gold
  9. Base map help
  10. 98 integra tach and speedo signals
  11. AEM X-SERIES UEGO problem wtih AFR display mode
  12. DC/ MD/ VA Auto Shop Recommendations
  13. 2013 TL CELs
  14. VTEC
  15. 13 TL TYPE SHAWD KTUNER Q's
  16. I WANT TO TUNE MY CAR
  17. Is this basemap ok? D16Z6
  18. Ethanol Content (Flex Fuel) Sensor Dropouts. Out of Ideas.
  19. Cold Idle options without FITV - OBD1 ecu
  20. Honda CODE READER
  21. H22 Emulator help please
  22. timing weird issue
  23. 2001 honda accord 4cy VTEC 4000 rpm cuts out
  24. F20B Basemap Required
  25. Zdyne software
  26. Aftermarket Distributors and Sensors
  27. Immobilizer chip swap between 2 obd2b p72's
  28. Oil Pressure Sending Unit / Switch.
  29. Canadian car has no ELD or EGRL, can't datalog
  30. better fuel economy with only 1 o2 sensor working?
  31. engine shutting down when getting to 2rpm
  32. HTS can you data log an already tuned car?
  33. Need help with red light on Kpro V4
  34. Unable to build boost
  35. Tach jumping, power cutting out. OBD1 conversion crx
  36. D16z6 into a 2000 Civic EX
  37. VTEC Solenoid High Voltage CEL S300 -No boost past 6psi. Thoughts?
  38. Remove Pop Tune
  39. B20 swapped 91 integra ecu
  40. Hondata S300 vs. A'PEXi Power FC?
  41. Need an Electrical Wizard!
  42. RSX with Hondata Mapping module. How do I remove to sell it?
  43. D17A1 to d17a2 swap
  44. Troubleshooting: 2013 Acura TL Ktuner Flash V2 Getting codes
  45. Troubleshooting: How to get Proper Ignition timing without lower timing cover
  46. D12 engine
  47. Chipped P72 In Limp Mode
  48. Anyone have any issues dealing with chippingsolutions?
  49. D16Z6 swap
  50. Chipping/Reflashing a P28 D16Y8 ECU
  51. K series turbo guys: A question regarding VTC & Power.
  52. Code 14 not going away. Bad ECU?
  53. 99 CR-V B20Z2 AWD AUTO
  54. Assistance needed: How to route OEM vacuum lines without a Helms manual.
  55. Closed loop inputs
  56. California Residents... how will your next BAR appointment go ???
  57. Ostrich won't connect
  58. OBD1 P72 internal diagram needed
  59. Safe basemap to use until I get my car dynoed?
  60. Tuning a stock 2013 CRV?
  61. Fueltech ECU into EF Civic
  62. S300 fuel issue
  63. Suggestions Needed: 2015 Accord 2.4L - P0088 high fuel pressure Code issues.
  64. '97 Accord OBD2A Dizzy Works With OBD1 ECU?
  65. J37A1 swap into a 2007 Ridgeline. Can I use J35 harness?
  66. Does this ECU look normal ?
  67. J35A3 3.5L harness and ECU compatibility.
  68. Erratic afr/lean missfire
  69. Couple questions on Honda sensor and plug types
  70. TPS signal noise?
  71. Mixing E85 and Regular 87 Pump gas?
  72. AEM wideband ECU install
  73. Autotune with Flashpro, KproV4, S300
  74. 1997 honda accord se oil pump
  75. hondata CPR help, crank but no start
  76. Can’t get timing right
  77. In need of an HTS LSVtec Tune w/ a Snake EMU.
  78. Is the PR3 B16 OBD-0 ECU able to run Crome?
  79. Troubleshooting: No power to ecu / hondata
  80. What are my options for tuning solutions? (didn't research beforehand)
  81. Is Bestparts4u on ebay legit?
  82. PLX Wideband to KPro V4 Install - Correct Diagram?
  83. F22 ECU with B series??
  84. Engine codes P1298 P0325 and P0420 help
  85. Help with idle issue
  86. B18 smoking cables
  87. Wiring table for MAF sensor Acura RDX 2012
  88. Vss based rev limiter? B16
  89. Fuel control issue
  90. Hondata s300 v3 vs aem ems 4
  91. B20B knocking sound
  92. D16y7 Automatic D16y8 intake mani swap
  93. Crome tuning smart tracking/live tuning
  94. Hondata S300 V3 no datalog and 4000rpm rev limit.
  95. Aem series1 map scale and connection problem
  96. 99 honda Civic ex obd1 or obd2 ?
  97. PCM causing 93 Civic to run rich.
  98. AEM: Help tuning accel / tip-in fuel
  99. Loss of power
  100. Valve Adjustment Question
  101. 95 accord oil type help!!!
  102. HRTuning help with horrible support
  103. B20B swap not running right at all
  104. I
  105. Do I need to clean the injectors or just change??
  106. Before I make my own, off the shelf 36-1 crank wheel?
  107. D16 vs B18b
  108. Kpro engine compatibility
  109. 2010 Honda Accord V6 Starter replacement
  110. Help: PR4 ecu, no fuel trigger.
  111. Coolant pressure sensor
  112. AEM Wideband Gauge smoking issue. Will AEM help out?
  113. I put aftermarket 421 heads on my 89 CRX SI
  114. Chipped ecu in a 2000 honda accord
  115. Help ASAP b20 swap running on 1 cylinder
  116. MAP/MAF Parameters
  117. ECT reading 120F Cold and 134F Hot???
  118. Can I tune my OBD0 injectors on a OBD1 p28 ECU?
  119. P28 Burnt Chip on board, need help identifying
  120. S300 says ignition is off
  121. Recovering tune from chipped ecu. Possible?
  122. Help understanding logged fuel params from AEM Series 1
  123. Snake EMU + P28 = mistake?
  124. EGT placement and cylinder fuel trim balancing
  125. 98 civic with B18c tuning question
  126. Got the car running but idling insanely rich
  127. Aem 30-0300 vs 35-8460
  128. Can I put bigger injectors in 1987 CRX without ECU tune
  129. Just installed harness and engine wont start
  130. Redid harness cranked once and now it clicks
  131. Bad harness blowing ECU
  132. Mix match wire harness / plugs
  133. ECU tuning on a d16z6 1990 si
  134. What tuner options available for NC/SC/GA area?
  135. 97 Accord Vtec, Tuning and Mainenence Help
  136. Engine knock?
  137. P06 ecu fuel prime issue
  138. B20b4 swap tune file needed
  139. Snake Ecu tuning?
  140. G23 basemap needed
  141. D16y7 block with y8 head
  142. Help with my harmonic balancer. Is it okay to drive in this condition?
  143. Vtec wiring help
  144. ObdII port not reading
  145. Troubleshooting: code po441-purge solenoid incorrect flow. What does this mean?
  146. B16A Dyno Tuning
  147. Chipping Questions p06 p75 b20 non vtec
  148. What ECU / chip is this?
  149. Automatic or manual?
  150. k-pro secondary o2 sensor
  151. Shakedown MAP issue; 933 PSI????
  152. P75 socket and chip problem
  153. Assistance needed: Sputter problem B20V chipped ECU
  154. Three flat bars on wideband after hondata manager install
  155. Civic giving me HELL
  156. Black soot/black smoke from exhaust-Super rich with lean readings?
  157. Assitance needed: Tuning issue involving AEM UEGO Wideband
  158. Really rough idle, low power and doesn't rev over 3k
  159. DUAL FUNCTION SENSOR
  160. Can I use a p28 ECU in an 03-05 Accord
  161. Advice Needed: 1991 Civic CEL Code 1
  162. HELP
  163. 4.9v from ecu map signal pin
  164. Hondata problem (described in thread)
  165. 2013 Civic (RHD) power supply fault
  166. using TL866 to burn chip??
  167. Hondata power lights
  168. Hondata False Constant Voltage AFR
  169. S300 lost d3 power light
  170. Has anybody ordered a phearable ecu?
  171. Looking for kpro install write up
  172. I Cant get a stock gsr running with Hondata NEED HELP!!!
  173. Ls/vtec tune and learning to tune?
  174. Flashing check engine light/exhaust burning bumper
  175. Has anybody used one of these OBD2 chips
  176. P28 c14 capacitor question
  177. K-Tuned Immobilizer/Multiplexor Bypass
  178. p72 s300 v3 NA b16a innovative MTX-AL wideband sensor
  179. Thorton Tuning Chip. Scam or the real deal?
  180. Looking for a good JDM shop in CT
  181. D15B Turbo Crome Tuned
  182. P28 and P72 info
  183. Vtec not working plz help p28 S300 v3
  184. can this ecu be changed to hondata S300 v3 (pics)
  185. AIM Strada 1.2 S300 Issue
  186. Best ECU mounting approach?
  187. Need help finding a tuner
  188. 2001 Odyssey sand rail adding OBD PORT
  189. Does Ktuner flash program eliminate "Rev Hang" on the 2016 Civic?
  190. B16a2
  191. hondata kpro
  192. Main Relay No Power D16z6 (zc imported motor)
  193. Using Bosch LSU 4.9 wideband sensor, directly connected to ecu.
  194. What kind of head is this?
  195. Oil pressure sensor to neptune rtp
  196. F22b1 header questions from a noob
  197. P75 1980 borad vtec conversion q17 missing s300
  198. Sluggish acceleration and choppy idle.
  199. Limp mode p28
  200. H22A Type S with ATTS and OBD1
  201. h22 Question
  202. What's needed to get tuned on e85
  203. SST27SF512 - Quantity Being Used?
  204. Questions regarding Hondata/ Neptune/Crome pro
  205. Integra loss of power when shifting
  206. Anyone know what injectors these are?
  207. Hot restart idle issue, Neptune RTP
  208. P75 id
  209. Hiccup on tune, street driving take off. HELP
  210. No power to Ecu nor fuel pump
  211. What OBD1 ECU is most recommended to use with Hondata
  212. Jdm p13 ecu/hts
  213. Problem with P28 Hondata S300
  214. P28 or P30 ecu for DC2R
  215. Assistance needed: B18C fuel trim issue in Neptune
  216. What is the Hondata Kpro?
  217. EM2 standalone tuning
  218. Ecu problems - HA Motorsport replacement
  219. Timing always hitting TDC Mark
  220. Product feedback inquiry: $400-$500 to use on a "piggy-back" style EMS. Suggestions?
  221. P28 ecu will not prime fuel pump.
  222. Questions on Flex Sensor location and Coolant Pressure Sensor
  223. What ecu is best to use for my B16B?
  224. Tb coolant line help (d16y8)!!
  225. Learning Hondata?
  226. 'sand rail' version of the J series ECM and wiring harness?
  227. Hondata KPro V4 CAN Bus
  228. 405A b20 crower base map request
  229. product inquiry :Any k-pro pretune maps to use for start up and test drive?
  230. Abstract question: What methodology does one order parts to test? NA E85 project
  231. Question: How can remove evap/o2 function from an auto ecu?
  232. Kpro "burble" "pop" tune question
  233. Chipping P06 - Xenocron chipping kit missing components?
  234. 99 Civic Auto Transmission. Can anything be modified on the ECU for added performance
  235. D16A9 with PR4 OBD0 ECU. CEL light issue
  236. Replacing Fuel Injectors, is retuning required?
  237. Help - Car cuts off Check engine light but no Code? (log added)
  238. Product Feedback request: Hunter Tuned's Honda tuning suite?
  239. Which AFR gauge for tuning yourself? Is one better than others?
  240. JDM P30-910 - difference in TPS from P28
  241. Code 16 jdm h22a swapped EG hatch
  242. ECU question for Hondata prep
  243. Forged Higher Comp Pistons and Stock ECU. Is it possible to use?
  244. Taking a look at my ignition timing table s300
  245. B20Z1 Ignition Map inquiry
  246. Need help with b20z1 eg5
  247. Turbo J32a2 - MoTeC M170 Tuning Questions
  248. Question regarding proper range of wideband air-fuel-ratio
  249. Who chips p28 ecu's ?
  250. E85 on stock ECU
