B16a2 in ej8, obd2a to obd2b conversion (p2t Ecu)
Old Feb 9, 2019 | 01:55 PM
Zulu451's Avatar
Default B16a2 in ej8, obd2a to obd2b conversion (p2t Ecu)
Hi I have a 98 civic ej8 with a b16a2, it currently has the stock p2p and ej8 harness (I didn’t do this). I bought a 99-00 P2T civic si Ecu and plan on ordering a eBay obd2a to obd2b Ecu jumper harness. (1)My question is what else will I need to make the motor run correctly? (2) Vtec, dizzy etc. all plug up to existing ej8 harness is this normal or modified?Anything would be appreciated stumped on this one.
Old Feb 26, 2019 | 12:46 PM
ngv1515's Avatar
Default Re: B16a2 in ej8, obd2a to obd2b conversion (p2t Ecu)
I did this to my 1998 civic. I did it the hard way though. You will need to move the O2 sensor and add VTEC wires.
Old Apr 19, 2019 | 02:30 PM
Bsmith1010's Avatar
I see you say you're going to find a OBD2A to OBD2B conversion from Ebay? I almost went this route on my B16a2. I realized while looking for that specific jumper conversion that NOBODY sells one except TA Motorsports or Rywire, I believe, both were not cheap at all. So good luck finding one! Instead of this I went to a P30, but you have a different harness and so on so I don't know how that would work for you.
Old Apr 19, 2019 | 04:41 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Boomslang Fabrication sells one as well.
stevtec
Oct 16, 2011 03:53 AM
smiko0124
Jan 9, 2010 09:34 PM
808kyle808
12
Mar 13, 2009 07:24 PM
heunde
May 6, 2008 05:01 AM
