PDA
View Full Version : Engine Management and Tuning
Pages : 1 2 3 4 5 [6] 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. Tuning question
  2. Odd Problem - RPMs Drop 3500 and can't accelerate
  3. P28 ECU - Resistor installed in C52 location...
  4. Assistance needed: Hondata S200 setup for B18A/B. Still possible in 2016?
  5. Found a p06-a52 ecu running my d16z6
  6. How to hook up AEM water/meth "boost safe" wire to switch to secondary tables
  7. ELD D10 capacitor circuit
  8. which type-r bin is correct?
  9. Integra vetch
  10. B18b turbo gas on top of piston
  11. H swap guys!
  12. P72 codes 41 and 23
  13. P28 or p72 to run b18c5 ??
  14. OBD1 ECU COIL ON PLUG MODULE - TROJANTUNING
  15. Limp mode
  16. Low idle problem help!!
  17. AEM FailSafe Water/Meth Need help to Wire up to Hondata S300v2 Devils Own Kit
  18. The most important thing you learned when you started tuning
  19. getting started with tuning. need advice
  20. CEL code 0, car drives fine
  21. s300 tps security suddenly on
  22. Accord 2001 LX want to bypass all engine sensors can it be done
  23. converting ECU to VTEC and need help P06
  24. Berto24's GT35R 11.5:1 compression Dyno graph: Suggestions welcomed
  25. knock recordings in crome?and other questions
  26. Rev limiter?
  27. B18b gas on top of piston
  28. Bee*R type h (92 civic hatch b16)
  29. crome inconsitent AFR and cant change fuel corrections
  30. Launch Control/2 step/Rev Limiter
  31. Any Hondata tune shops in Minnesota????
  32. CTR camshaft CTR piston Detonation
  33. Neptune ECU?
  34. AEM Infinity and Racepak IQ3
  35. Hondata or CROME?
  36. Honda Accord 2001 LX 2.3 l Auto p1381
  37. Hondata Quick spool
  38. D17A2 OBD1 INDIVIDUAL COIL PACK
  39. Bought a car with a chipped p28 with s300
  40. Fresh b18b build
  41. Help identifying injectors
  42. Chipped ecu?
  43. Cylinder head help please...
  44. CX wiring harness
  45. Idle dips when A/C is turned on
  46. Utilizing analog inputs: D10 ELD
  47. Aem ems 4 how to hardwire with out eliminating the oem ecu?
  48. Need help finding chip on Internet???
  49. Honda Accord 2001 intermittent idle chug leads to p1381
  50. Accord 2001 LX 2.3 ACV valve does it simply move the butterfly
  51. Honda Accord 2001 idle screw 2.3 l LX
  52. b16 tuning
  53. Resetting the check engine light on my '03 CR-V
  54. Civic em1 swap b20z2
  55. Revving out problem
  56. wideband sensor location question
  57. S300 basemap from phearable very rich idle
  58. Malware warning when downloading CROME
  59. P1381 Honda Accord 2001 LX trick limp mode
  60. Honda Accord 2001 LX p1381 tricking limp mode
  61. Achieving smooth idle with IACV disabled.
  62. Is Kpro 3 still being sold via dealers?
  63. Running b series on kpro........
  64. New to Hondata - Looking for D16Z6 basemap and recommendations
  65. Ecu repair
  66. Help with Crome tuning
  67. Tuning a chipped p28
  68. upstream and downstream O2 sensor same?
  69. Updating TPS parameters using Hondata S300
  70. chipped ecu was working fine till now. Need help
  71. Ecu help
  72. Civic 99 b20z2/trany sir ecu problem
  73. Tuning Timing in Vacuum misunderstanding
  74. Adding addtl. sensors on AEM V2
  75. Same VSS issue for almost a year!
  76. quick knocksense question
  77. Crome map question
  78. Ignition timing question
  79. GSR Obd1 / Obd2
  80. EG civic fuel pump wont prime
  81. Flashprotuning.com was gone & now back charging to download pre-tunes / basemaps
  82. Gsr full bolt ons tune
  83. Glowshift WB gauge - obd0-obd1
  84. 97 ex motor, Ecu, harness, in 97 lx chassis?
  85. GSR swap in 93 SI
  86. OEM ECU Based Tuning Tricks
  87. Having trouble with a basemap
  88. Need to find a basemap for hondata
  89. Bank 1 system too lean???
  90. tuning b16
  91. Hondata S300 SManager (NOT WORKING HELP!)
  92. Need help with getting a hold of John Cui or anyone from CROME!
  93. Coil on Plug without dizzy
  94. Crome Pro Reg String
  95. Wideband Bosch LSU 4.2 versus 4.9
  96. Harness for LSV
  97. S300 V3 vs Demon V2
  98. Hondata s300 and rc750s fueling issue
  99. 93 jdm b20b eg si hatch starting issue
  100. im out of ideas on this o2 issue
  101. Integra GSR Long cranking
  102. Obd2 to obd1?
  103. anyone have ectune ?
  104. AEM - disconnected battery for a while, now having problems
  105. FTW FUEL
  106. Information J32a3 Engine Acura TL
  107. flashpro v2 3.5 update
  108. Which port to set in Crome to datalog with bluetooth adapter
  109. crome 1.6.15 or 1.6.11r2?
  110. reading 5volt lsu 4.9 sensors
  111. tuners and shops which wideband do you use?
  112. DIY tuning, a discussion
  113. Shared cells in fuel map between WOT and part throttle
  114. defi style plus lsu4.9 help
  115. Questions about Neptune RTP
  116. TRYING TO BUILD BASEMAP FOR ITR (INSIGHT REQUESTED)
  117. What pins for LC-2 Wideband?
  118. P1381 & P1336 Wiring issue
  119. P0420 Diagnosis Challenge & O2 Readings
  120. AEM 30-1010 with EPM
  121. ECU Problems?
  122. Crome 1.6 and Freelog 1.0
  123. offsets for Delphi 01D030B 42lb
  124. AEM boost by gear with Greddy solenoid
  125. Simple Stand Alone Ecu
  126. crome 1.6.15 hulog and ostrich issues
  127. Cylinders flooded with fuel
  128. Need someone in Maryland that tunes NepTune
  129. crome 1.6.15 - all plugins broken?
  130. b18c5 with boltons basemap?
  131. Bad ECU or Chip? Car won't start after sitting for a few hours after tune and new ECU
  132. Wandering TPS voltage
  133. s300 questions
  134. Hondata s300 compatible with aem 4 channel wideband?
  135. changing internals will it affect fuel maps?
  136. 98 Accord P0135 Code HELP!?
  137. Tuning ITB's for Street use
  138. Neptune Setup Issues
  139. need idle and ignition help hondata
  140. 1991 Honda Civic-Wont start-Fuse box
  141. Any universal generically-programmable guages out there?
  142. Tune
  143. Car doesn't idle below 1400.. my basemap?
  144. Crome gold and wideband
  145. B18b1 with P72 pistons tuning with crome
  146. Why do fuel values drop on fuel tables?
  147. fastuun? learning how to tune.
  148. Tuning VTEC killers
  149. Bosch fuel injectos
  150. chipped ecu question
  151. E85
  152. 98 b20b turbo tuning help
  153. Crome 1.6.13 datalog issues
  154. Aem 5bar Brass MAP
  155. no idle/struggling to start
  156. E85: Hondata S300v3 or AEM EMS v2
  157. Adding and Deleting Columns in Crome?
  158. S200 with CEL Problem
  159. Is there something wrong with the hrtuning (neptune) website?
  160. Crome
  161. b20v bogs at low rpms and runs bad until warm
  162. Mini Me - Timing Advance / Retard - Crazy question for newbie
  163. How To Use an Air/Fuel Meter to Optimize Your Ignition Timing Curve
  164. Motec M4 base map help
  165. VAFC Tuning..a few questions.
  166. Car Dis Likes Hondata S300v3
  167. advice.keep chipped p28?
  168. Car breaking up but AFR reads fine?
  169. Is a TL866CS capable of programming P28 chip?
  170. Changing Spark Plugs And Found This In Cylinder 4
  171. AEM 5bar with Crome
  172. Aem ems v1
  173. Hondata S300 question- OBDII and OBDI
  174. Civic HX tune for MPGs
  175. Fried P28 diagnosis pls
  176. Full Throttle Shift + Rolling Antilag Feature Possible To Use Both?
  177. Spark Plugs Reading
  178. P28 manual ecu
  179. Hondata BBG - duty vs boost variances at track
  180. Need some info!
  181. Changing wiring harness
  182. any specific reason for knock at 7000 rpm?
  183. The hotter she gets the leaner she runs
  184. MAP check engine light ECU fried?
  185. Crower 404 Cams Idle Issue
  186. Precision 1000cc injectors No Start
  187. Can you mix nitromethane and 91 octane
  188. crome nitrous tuning and plugin or script
  189. need help with plx wideband
  190. running rich and high idle
  191. S300 losing memory
  192. b20v, itbs, e85, hondata s300 and cpr. Leans out at idle, dies when cold
  193. High Compression AFR
  194. Add Rows 2 CROME
  195. Ford IAC with AEM Series 1
  196. ECM not commanding IAC plus burnt board pics
  197. Weird high AFR during startup when warm outside
  198. Chip Burner question (minipro tl866)
  199. Hondata s300 few questions
  200. Semi-new.. Edelbrock mani + second injectors?
  201. i need a good b20 basemap..usin crome lmk
  202. AEM EMS Compatiblility
  203. reading spark plugs for power
  204. b18c5 will not run on s300
  205. Hondata cpr no spark
  206. need a really good b20b basemap please help
  207. Running P72 ECU on b20b?
  208. ECT Sensor
  209. ID725cc settings in Hondata S300, P74 file
  210. obd1 fault code help
  211. PGMFI finaly dead?
  212. Factory Jumper settings 30-1050
  213. Hondata Guru's WANTED!
  214. Windows 10 and aem v2
  215. has anyone modified jdm cluster to work for us?
  216. Need Engine Management advice
  217. 2step rev limiter fireball needed for car show
  218. Turbo edit throwing O2 cel?
  219. NeptuneRTP throws solid CEL
  220. chipped p08 vs chipped p28
  221. VSS Signal With No Cluster
  222. voltage dropping effecting afr's
  223. PGMFI.org Users
  224. IAT Dependent Ignition Retard - What do you guys do?
  225. help tuning jdm b16a stock motor
  226. B20Vtec resetting ignition timing with current Hondata tune
  227. terrible hasitation missfire with crome/neptune/hondata need help
  228. Crome Tuning NItrous
  229. blown resistor p08 ecu help
  230. Help with Neptune map for startup on fresh rebuild...
  231. Freelog not matching wideband
  232. Where does A22 on OBD1 pinout go?
  233. Crome. Does it have an ignition timing issue?
  234. D17 non VTEC to VTEc
  235. Nope.
  236. Q37 transistor on ecu?
  237. h23a1 on crome
  238. D16y8 hondata s300 calibrations
  239. D16y8 hondata s300 calibrations
  240. Any way to lock a map on sst chip?
  241. Ignition timing tuning on dyno with no HP gains?
  242. Leaner in lower gears??
  243. Part Throttle Tuning
  244. New basemap starts but stalls
  245. Who is happy with AEM Series 2 EMS ?
  246. TurboEDIT files?
  247. Looking for a tuner in or around Philadelphia
  248. Turbo Integra GSR sluggish as engine temp rises...
  249. Crome gold map won't start. Help
  250. map sensor calibration
