B18A1 fully built head stock block
I’ve got a B18A1non-VTEC head that I put dual Brian Crower valve springs and retainers in. Brian Crower intake and exhaust valves.(OEM sized). The block is completely stock. I am going to run stock cams at first and then “turbo cams” when I run boost. I’m going to run it n/a at first. But I wanted some ideas on what I should do with my Hondata S300. I’m all ears because I’m new to the Hondata. If you think I should do something differently let me know...
thanks guys
thanks guys
Re: B18A1 fully built head stock block
thanks guys
thanks guys
not to sure what your asking, but yes, keep the hondata s300
I’m asking if I should change anything up with the Hondata. Like to make up for the built head. Like change the tune up. I don’t know where to begin. It’s a P28. So I know I would turn VTEC off. But then what. I’m inexperienced excuse me.
You take the car to a tuner for proper help. Tuning isn't for the inexperienced... the learning curve is expensive.
^^ don’t mess around with these things, you can destroy your motor...... BUT if you must, Visit www.pgmfi.org to start learning some basics on tuning.
btw, installing dual springs and oem sized valves does not constitute a “built” head. At least not enough to require the ecu to be tuned with anything but b18a/b maps, as you’re not creating power with those mods.
