KPro on 05-06 RSX-S, what sensors are disabled?
Looking into the KPro for my 05 RSX-S. According to Hondata's site, some sensors had to be disabled to run the 02-04 ECU in a 05-06. Does anyone know what specifically they took out? I searched all over for this info. If no one knows, I'll bug Hondata directly.
- An primary oxygen sensor from the 02-04 RSX or 02-05 Civic Si must be used. The 05-06 RSX O2 sensor will not work.
- Some sensors must be disabled to eliminate errors generated by the ECU.
- The speed sensor spins about 100 times faster on the 05/06 RSX gearbox as compared to the 02-04 RSX. Above 65-70 MPH cruise control may not function smoothly and may cancel from time to time. Also see Tech - K20 TransmissionI
