Chip Burning Using Universal Programmer!!
Old Jul 30, 2018 | 09:32 PM
civicsirii's Avatar
Default Chip Burning Using Universal Programmer!!
fellas...
first of all i think i made a mistake since i bought this non-compatible chip burner with crome or flash burn, but after i read the manual for crome it says you can use devices other than moates devices so i got this burner which i believe its from a chinese manufacturer and comes with its own software for chip burning.
my issue is when i burn the bin file that i saved from crome to the chip and install it to the ecu the ecu doesn't get anything from the chip and acts to a safety mode or something else and i get a rev limit to 4000 RPM with fuel cut and it doesn't read the chip at all, even when i try to read the chip back with the software it reads it and crome opens it like no problem but when ever i install it to the ecu i get nothing, i tried this with different ecu's and i am no where, appreciate your help.
chipping kit bought directly from moates.net so its completely legit.
ECU P28 USDM, P30 USDM.
Burner type TL866II Plus
Old Jul 31, 2018 | 08:21 AM
7rrivera7's Avatar
Default Re: Chip Burning Using Universal Programmer!!
What offsets are you using?
Old Jul 31, 2018 | 08:24 AM
civicsirii's Avatar
No offsets it's all stock readings I didn't change any parameters
Old Jul 31, 2018 | 10:11 AM
7rrivera7's Avatar
You need to tell the burner where to place the code. For an SST512, use this:
Buffer Start 000000 -> Buffer End 007FFF
Chip Start 008000 -> Chip End 00FFFF
Read here for more info on offsets: Programming Chips Using Offsets « Moates Support
Old Jul 31, 2018 | 10:24 AM
civicsirii's Avatar
Yep it worked..
thank you bro for your time
Old Jul 31, 2018 | 11:36 AM
7rrivera7's Avatar
Originally Posted by civicsirii
Yep it worked..
No problem. Glad it worked out!
Vtec140
Oct 3, 2017 02:15 AM
Brandeezy1
Engine Management and Tuning
Jul 25, 2012 07:18 AM
98_ssbp
May 29, 2012 12:44 AM
WeB
Jan 19, 2010 11:17 AM
revlimitcrx
Apr 13, 2006 02:17 PM
