- s100 questions
- anyone tryed reading a bin file off a ostrich with a burn1?
- Detonation under deceleration?
- msd install...retune???
- Neptune RTP VS Hondata S300??
- moving from stock Map to Omni 3-bar
- Using B18C5 Power FC in H22 Swop
- tuning on 100 octain
- Spark plug gap
- Neptune is limping
- o2 sensor and closed/open loop
- what could this be??? Acura 3.2TL
- Injectors for DOHC ZC
- will a 90 ls alternator work on a d16a6?
- tuning a hondata s200
- auto ecu in manual??
- Injector Pulse? Please HELP Car Wont Start
- tuner not in area.
- Am I being paranoid? Please advise!
- Constant Knock Voltage on S300
- ECu options
- Apexi VFAC II on K20A2 with H/I/E
- new to honda
- Ignition problem after AEM EMS install
- Scan Tool
- need help tuning skunk 2 adjustable cam gears
- S300, dogbox, strain gauge ??
- New to the honda world, first accord troubles
- how do you transfer s300 datalog from one ecu to another
- HELP!!!
- Is anybody in the Colorado area running Autronic SMC?
- s300 idle parameter
- suja1 motoring
- My ignition map, can i add more timing?
- BRE odd problem
- OBD1 injector clips required for obd1 ecu?
- 00 EM1 GOING LST... NEED INFO???
- can i fix a spun bearing??
- Switching ECU's for inspection
- OBD-0 37820-PG7-L030 ECU
- S100, please advise
- need base maps for smanager
- 1992 Accord H22a swap having water temp sensor issue
- perfect power SMT8 anyone tried?
- VAFC and Blox intake manifold worth it?
- Hondata s300 module only or ECU?
- hondata s300 02 sensor help!
- I NEED HELP BAD!!! ignitor keeps burning. is it ECU OR tune
- Air Fuel Ratios while driving not at WOT
- aem wideband and cromePRO!
- Unplugging the battery, Hondata S300
- Intermitant CEL
- need help with code
- chipped ecu.. no fuel pump...help
- how to eliminate knock sensor on s300
- s300 disconnecting problem
- PCM Reprogramming
- afr's and dyno mapping myself
- NEED HELP FIXING A PULLEY
- Engine cuts out at 6000 RPM JDM H22A Automatic
- what motor can be swapped to carburetor
- p06 ecu with p28 guts???
- tuning boosted engine with apexi?
- Prelude Injector Question
- Flex Fuel
- need help with valve adjustment
- Quick question. How much more fuel for mini-me?
- AEM FIC on OBD1
- power fc help
- H22A4 engine swap problem !!!
- hondata s300 smanager help
- Calling all Tuners!!!
- crome trouble with options window
- Tuning spark tables with crome
- Re Chipping ECU?
- Tuning for power: "4 gas EGA assisted" vs "wideband o2 sensor"
- ECU H22 auto question
- WHATS A BETTER EMS CROME PRO OR NEPTUNE?
- wideband placement
- HELP!! Do you know any tuner for OBD0?
- 86 Honda Accord problem
- High Flow Cat??
- Can't find if your able to convert a Po6 to operate VTEC?
- anyone make their own hondalog usb adapter?
- EG4 D15B2 - alternator bearings.
- k24a1 with ep3 si head?
- die out!! help
- looking for good mechanic hudson county nj
- omni 3bar map sensor with crome..what sensor do i select?
- crome tuners 3 bar map help
- CEL Using Crome?
- Someone knows a good Tuning Schools??
- help with part throttle cruise.
- sputer ls vtec
- high boost low boost ?'s
- Ek9 or Dc2 opinion / advise needed.
- phearable.net
- Chrome or Hondata for stock JRSC setup?
- itb help
- Ignition timing...searching done
- where can i get a dyno or tune in germany?
- D15B w/D16Z6 head. Custom timing question???????????
- Pressure Washing the engine???
- Tunning Spots....
- air/fuel ratio????
- How can you tell your OBD Number?
- [HELP] Specification Spoon N1 Muffler
- DC2 Integra. Auto LS to Auto GSR.
- Greddy FCU installation
- Obd2a to Obd1 ecu question???
- open header harmfull??
- no start up fuel problem
- tuning with crome
- the Main Relay and what it look like?
- b18b Idle problems
- Auto p30 to manual help?
- for the tuner people IAT/ECT corrections
- user sensors, passthrough, or actually usable?
- What ECU for 83mm sleeved GSR?
- P75 ECU troubles, high idle then car shuts off
- HELP HELP HELP!!!!! B16a
- I am looking for stock roms
- B18b IACV Problem
- Stand alone engine management
- crome gold boost controller
- need new ecu after blox IM install?
- Chipped P06 shorting out...
- code 16 on s300!! help!!!
- H22 Tune / Tuning Theory ... Ignition advance trends
- wacky rev limiter
- cel always on...
- Turbo S2000 tune problem
- Throttle Body Air Adjustment
- B18b Ignition Timing
- turbo/tuning question...
- Passing Smog?
- how to email logs with s300
- hondata s300 on p72 ecu or p28???
- where to put my temp sensor?
- civic vtec engine swap
- how to identify hondata s300
- eCtune or other EMS question
- BIG PROBLEMS
- looking for a tuner
- Having trouble reading code
- A/P low side pressure
- CRX injectors Vs 95 Civic Si injectors HELP!!
- 550cc injectors works like 350cc
- having the correct temp when tuning..?
- Need help on wiring of knock sensor on a 96 Teg LS with a 99 gsr swap..
- Odd power loss in upper RPMs
- UTAH TUNERSSS
- stock p30 basemap
- Getting rid of the distributer -help
- hondata s300 Question
- Do Pistons Affect Emissions?
- S300 A11 output
- Adjusting Air Fuel Ratio On Throttle Body
- Best way 2 tune hondata s300
- turbo h22 on hondata, CEL 10 won't go away, IAT sensor
- will hondata s300 control boost?
- boost option
- Hondata 4bar MAP/GM 3bar MAP?boosted SOHC.
- How does Neptune work?
- B18B ECU Help
- e-Manage blue, e-01, Chipped P28
- pgmfi
- aem stand alone????
- how to tell what ecu and if its chipped
- Anti-Lag in Crome Free
- have i ruined this ECU??
- pulling a file from an ostrich 2.0
- Ostrich 2.0 + Which free software?
- Q about Neptune chip
- is fried ecu fixable/reusable??
- adjusting launch control with crome?
- TurboEdit, OBD0, Code 16
- Neptune, gear based boost control issues....
- Street tuning.
- how to tell if a chipped p06 ecu has been converted to p28?
- eprom programmer
- after tuning with chrome on p28 car idles higher and eats more gas!!!
- Ecu Question (Swapping between cars)
- Deleting ghetto Vtec wiring for a NON-Vtec swap
- OBD2B TO OBD1 conversion ?'s please help
- hondata vs crome rom
- honda/acura dyno shoot out
- crome rom
- AEM EMS Variable valve timing
- which way to go
- B16a2 and B18c5 fuel/ignition maps?
- can i disconnect my battery
- Type-R Basemap
- chipped p05 wont idle right HELP
- ?Tuning Resources?
- K Motor Forum
- breather nipple what pipe goes on it ?
- Chipped P72 going back to stock jumper for Smog
- hondata s200b problems
- is the open loop map based on TPSxRPM or MAPxRPM
- Need Map for B20 VTEC HONDATA
- tuning b16
- hondata ???
- Car stalling after a pull...??
- whats this moates emulator works with hondata now..?
- chipped p28 gsr map with blown transistor
- ecu remap/chip??
- Why won't my wideband work with s300?
- MSD with hondata s300
- Fantasy D16 Setup
- chrome chipped obd2b to obd1 /tach problems
- Have CEL, but won't produce a code when jumping...
- what part is this?
- rev limiter/boost cut not working--uberdata
- Vafc with chipped P28
- 2 explosions after revving?
- f22a1 turbo
- Japanese writing on ecu chip, can you translate?
- Help tuning non vtec engine over 8000 rpm
- H22a4 Tunning Help Please!
- Help setting up Neptunes Boost By Gear with Solenoid and Switch???
- Dear hondata...what injectors
- so i want to start tuning.....what do i need?
- oil and spark plugs?
- p73 ectune
- After socketing an ECU the car has a CEL and won't blink the CEL code.
- PLX Datalogging
- Defective Hondata ECU P28, TPS sensor
- Hondata and OBDII- Emissions
- Is the s300 significantly better than the s200 w/boost
- dataloging gone wilde, noise polution maby? incl video..
- P28 s200 or P72 ectune for boost DC2R
- Hondata S300 & AEM UEGO setup ?'s
- in need for a running aem basemap d16 780 4bar
- REGARDING BASEMAPS!
- Will P08 ECU work in JDM H22a Prelude?
- best ecu for non vtec turbo
- need help with aem tru turbo boost controller adjustment
- S300 people.. need help. Am I running too lean at WOT?
- ls-v dies out launching
- bent valve
- need help 91 integra turbo or na?
- Air Fuel Ratio Contollers Controllers (NOOB)
- Basemap for B18 with Skunk2 Pro2?
- need a s300 start up map
- Just bought turbo kit...Tuning?
- Ectune basic and demon
- Injector size?
- Turbo GSR Breaking Up In Boost...hondata s300
- FS: HONDATA S200 W/ BOOST OPTION
