Any idea with O2 sensor Fault codes
Old Nov 9, 2019 | 12:17 PM
Honda2003CRV's Avatar
Default Any idea with O2 sensor Fault codes
I have p0134 and p1164 that often come up. I’m able to clear them but with them clear the car sometimes will hesitate under a bit of load. When the code returns the car functions fine but the check engine lights up.
i have tried changing the O2 AF sensor with a new one, but the same issue remained. So, I thought it was a faulty sensor and bought a second one with the same results.
The other day I did a read and the code p0137 also was present.
Old Nov 9, 2019 | 08:28 PM
motoxxxman's Avatar
Default Re: Any idea with O2 sensor Fault codes
Do you have any exhaust leaks before the primary o2 sensor?
Old Nov 9, 2019 | 10:53 PM
Never noticed any leaks before the sensors but I’ll have a look. I was thinking the pipe that the O2 and AF sensors screw into may have a build up of Carbon and giving a bad read. However, the code is that the heater element part of the sensor isn’t working.
bigfoot89
Engine Management and Tuning
Dec 21, 2011 05:22 AM
Bossup!
Sep 9, 2009 07:35 PM
amej8
Jul 11, 2006 06:25 PM
JibOnALib
Aug 25, 2005 08:54 PM
Shakes
Aug 12, 2004 10:06 AM
