- does crome pro have boost by gear option?
- obd1 pr4 vtec chip question
- Apexi V-AFC2 settings
- TUNING FOR OBD0??
- *Need help with Hondata*
- ls with p08 and s200.
- S2000 wiring help please
- p06 ecu can this chipping/vote
- Crome tuning/jdm dc2r... Where to start?
- "D16A" JDM, specs and model infos.
- De-tune back to stock?
- Is there a way to fix this!!!!
- i have an easy question
- F22a1 and mods
- Ep3 immobilizer with swapbox k-not working!!
- where to get crome?
- 1991 accord f22a4 wont fire:( Noobie in distress!
- H22A4 ECU choice
- faulty ecu? (s300 veterans please help)
- p30 to p28 with a gsr
- LS/Vtec ecu question!
- OBD2a-OBD2b?
- Can you bypass the oil pressure switch in Hondata s300?
- Timing issue
- honda swap
- AEM Help
- Is my wiring right? Using diff. O2 sensor, getting CEL
- Places with Best Dyno Rate
- xenocrons website problems
- LC-1 wideband wiring to 30-1060 questions
- SLR Motorsports chip legit?
- o2 sensor vs voltage(current)
- help confused
- A Stock Tune?
- OBD2A Diagnostic question
- Half the lands on this ECU are toast
- OBD2 to OBD1 wiring help
- obd0 to obd1 help
- Using an Adaptronic e420c on a turbo b16a1 obd0 engine
- Problem With Neptune
- Looking for central florida tuner ASAP!
- fix or info on iacv driver? i think mine bit the dust.....
- Need a ls/vtec base map turbo
- Noise Problem!
- problem with kpro update help please
- p08 s300 v. p28
- p28 or modded and chipped p06
- Datalog with Skunk2 Chip and XS Chip?????
- my s300 wont show cel's
- S300 chips looked like this when I open the ecu.
- Questions regard Timing X Knocking
- hondata s300 help!
- ??? 95 civic integra swap what ecu ???
- Issues with LM-2 and Crome, please help guys :(
- which to trust: the boost gauge or the map sensor?
- VAFC or VAFC-2 ??
- AEM PRO Problem "A dashboard contained in this template has been deleted" ?
- Neptune
- p72 Hondata s100 Install
- soldering hondata s300 help
- Switch to open DP...Need to retune?
- PC does not see the ECU HELP!! Please
- Idle problem on modified H22
- just got hondata s300
- AEM EMS daily driver question/problems
- hondata s300/ aem uego help
- quick question 2.5 to 3 inch muffler
- tps only reading up to 84% then drops to -11
- P28 ECU
- HELP!!! Cant find anyone in North Jersey to Tune my Civic
- closed loop cruising problem.. need help please
- Need help with torque setting for b20a cam caps
- FT OBD1 chipped LS ECU for BOOST!
- Stock ecu vs base map for dyno...
- hondata s300 help ecu burnt
- vafc2. basic question.
- setting up my new lc-1 wideband with db gauge. burnt hand on o2 during calibration
- In the market for TUNING CLASS
- 99 ls pherable basemap
- AEM ems 31-1001 in a b-series compatible?
- Chipped & added vtec to p06 now will not show code
- another CN2 DKU-5 but this time only a 3 wire???
- Wanted Info For D16Z6 Head Swap.
- Wisconsin area dyno tuning?
- 2 step module problem
- midwest tuners
- help!!!!
- Crome Gold
- Obd1 pr4 vtec add-on?
- eCtune OBD1 CEL Code 11
- 00 teg 310 injectors/255 pump untouched ecu???
- Hondata s300 Help
- Using a mix of E85 in my 2003 Acura TL with NO problems
- Need some help with ectune
- Bad Ecu ? Chip? Ectune
- circuit j1 is fried is it fixable
- I need the GReddy e-manage disc HELP!!!
- gm 3 bar map wont fit?
- Best engine for Honda civic(EK9,EK4)
- liquiud filled fuel pressure gauge or non liquid filled
- help
- ATTN Algebra/Excel lovers: need an AFR slope equation
- Good gas milage + ignition timing
- CROME problem
- My DA died the other night, was wondering if HT can help me.
- Looking for good a tuner in NY for Hondata s200
- can a skunk2 exhaust work with dc sport headers?
- question on tuning my b16a with s200
- JDM Concepts
- Need abit of help finishing up a tune h22
- chip burner help...pics inside
- S300 software download
- torque damper
- where to download free tuning software?
- Hondata s300 Controlling
- Hondata s300, WTF!
- ECU Problems
- jackson racing sced my element tuning help
- ecu question
- RSR Manifold
- how bout tunerpro rt??
- 96 Accord FAN problem
- Supercharged S2k fuel issues...pls help
- Hondata boost solenoid question
- Virtual Com Ports? for datalogging etc
- STI Injector Help?
- Spoon P73 or Chipped P28? JDM 98+ Spec R
- Using a lsu4.2 on a aem wideband?
- Real tuners only, Should i use a resistor box? M4
- full synthetic and Synthetic blend
- advise plz on lauch rpm for 2 step
- b16a to b18c - p30 bogging at WOT
- Can't rev past 7900 on Crome
- Whats the best way to build a B16a For turbo??
- chipped p72 AND chipped p75 limp mode
- Tune Blew My Engine.... Thinking of suing Advice Needed
- B16A2 in trouble
- AEM FIC
- who can help me, if I'm help'able?
- Nokia DKU-5 without little box...
- launch control problem
- Has anybody tuned Obd0 before? (HELP)
- Interesting timing table
- Dizzy obd2B problem
- power fc, GM map sensor
- h22 sitting for two years.
- 91 Civic DX 2-Door Hatchback Rough Idle - HELP PLEASE
- AEM Wideband Question
- s300 completely dead..
- tuner around Rochester,ny or itb base map
- Good tuners near the 323 area?
- OBDII inspection problems HELP
- Spoon Sports Computer for DC2 Facts ??
- Looking for a good close tuner!?!?!?!?
- good tuner for apexi power fc in Chicago or Kansas city???
- engine problem?
- OBDIIB to OBDI Harness Required?
- vafc
- Need a second opinion
- datalog help
- Fuel regulator advise
- Tech edge wideband and s300 help please
- AEM EMS old one to new one
- K20 Idle Issue
- SFC VTEC controller on a d16z6
- (k20 a questions)Been out of the Honda scene for around 6 years
- Pro1 Idling help!
- Injector help
- a lot of questons
- THE ECU GODS ARE HATEING ON ME!
- VTEC not engaging *Searched* Neptune
- knock sensor delete ?? ECU decision
- damaged trace on j1 jumper. any bypass?
- P06 O2 sensor ground
- helppppp wiring please!!!
- Engine swap help.....H22 tooooo.......
- B- series cam shaft problems
- tuning and basemaps stock b20b turbo obd1
- p06 on a b18c1 swapped 95 eg6-- need help!
- USDM/JDM ITR Hybrid Exhaust
- 99-00 civic si ecu (p2t), immobiliser?
- Tune now, or later?
- pleas identify this chip
- smanager tuning for dummies??
- solid cel with service connector jumped
- Need help identifying chipped ecu? Pics inside
- Coils on plugs setup with aem ems 30-1050u
- 95 civic lx gsr swapped,,check engine code 19 solenoid lock up valve?
- INJECTORS RUN 100% ALL THE TIME
- Which map to tune with?
- oil pressure question need help!
- HELP MOTOR PROBLEMS!!!!!!!!!!!!!!
- Need to know a spot that does good Surfacing near 626
- base map vs stock map?
- R135 curcuit on p28 is burnt
- S300 changed catback and AFR is crazy and car chug
- please help with ur info...k24 or k20
- Updating AEM ems software
- 87 CRX DX
- chiped computer wont turn on pump
- Vacuum Issues!!! PLEASE HELP!
- data logging
- My DA Idle to high at startup
- OHIO! What's the best place in OH to get a dyno tune??
- JDM P72 ECU
- which is the best launch control/2step?
- tuner in hartford ct
- VAFC question
- WHere to get my Gsr head installed at? need advice
- need a 3 bar map n boost tune help
- noob+s200
- BAD ECU?
- 92 eg hestitation to start
- wanna learn about tuning
- Simple tune for new header?
- RDX Injector Dead-Time Test Results
- Issue about Engine Harness Integra OBD1 & OBD2
- s300 im lost
- convert an OBD2 Alternator to OBD1
- '92 Prelude - Shaking/trembling problem and electric problem
- Temp dependant Rev limiter
- d16z6 running rich after cam gear install
- no rev limiter? (head scratcher)
- Can a OBDI P05 work on 1995 integra LS
- CAR LAGS TO TURN ON
- Ok to drive car for a little bit?
- Do i need a Gsr Harness?
- aem or hondata
- EMERGENCY HELP PLEASE!!
- s300, code 20 after loading p74 rom
- still looking to go obd1 chipped.
- wideband showing up as voltage in smanager?
- removing crome to go back to stock-possible??
- Crazy T.P.S. Issues, Bad E.C.U.??
- which is the best Mivec or B16A EF
- APEXi VAFC II Problem
- Hondata datalogging plugin for Crome?
- BayArea Tuners!!
- 95 dx swap
- Acquired Neptune RTP.. Tuning Tips
- HELP!!! Lean in High rpm's
- aem ems 30-1020 switching jpt1 and jpt2 jumpers
- Random rough idle, Smoke, Knocking... Modded B18C1
- do i need a new ecu
- 2010 Accord LX-P: EMS/ECU
- Which ECU?
- checking for a working ecu?
- Boost control
- S300 GSR 9:1 Help
- Help! B16 ecu
