Looking for some help with basemap
Old May 3, 2019 | 06:54 AM
93DelslowSI's Avatar
5 Year Member
Default Looking for some help with basemap
I finally got my car running! Thanks to anyone that gave me some input when i was deciding what parts i should buy, and then again when i ran into trouble trying to get her back together. all i have left to do is get a tune put on it and ill be ready to drive! :D. Problem is the way the car sits right now, it would blow up before it made it anywhere near the tuner, and I don't have an extra $500 for a tow truck on top of the tuning fees. I'd really appreciate it if anyone could give me some information or link me to a basemap that might get my car running a little bit better. basically it runs pretty good (13/14 afr) for the first 20 seconds or so when its in open loop, but after it switches back to closed loop it wants to die and i have to keep giving it gas every couple seconds to keep it alive. i understand that my compression is way lower with the vitaras now so i guess i would have to delay my timing a bit, but i'm not sure how much timing is to much and i have come way to far just to blow this thing up in the driveway messing around with it. i've tried downloading other people's basemap that i found on the internet with similar setups and haven't found any of them to work. if anybody has any helpful input i would really appreciate it.
Fuel injector clinic 775cc
p28 with hondata s300
speedfactory 4 bar MAP
aem wideband
vitara/ eagles
Old May 3, 2019 | 07:11 AM
DaX's Avatar
DaX
Loved
Community Favorite
Default Re: Looking for some help with basemap
Disable closed loop until you get it tuned. Set your fuel injector size to 775cc/min and enter the dead times on the Fuel Injectors tab in the Parameters window. If it runs at all, I assume you have also already set the MAP sensor to 4-bar in the Parameters window?
I can't help you with a base map - see if your tuner will send you one.
This thread should probably be moved to the Tuning or FI section of the forum.
Old May 3, 2019 | 07:28 AM
5 Year Member
Thanks for the reply. yes i have all the information entered already but for whatever reason it almost seems to run better on the stock integra p75 ecu. sorry for posting in the wrong area i'm still pretty new to this, how do i change it to the tuning section?
Old May 3, 2019 | 08:52 AM
DaX's Avatar
DaX
Loved
Community Favorite
No problem, a moderator will likely see it and move it. @TomCat39 ?
Did you re-try it with closed loop disabled?
Old May 3, 2019 | 04:14 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Thanks Dax.
Moved as OP requested and is fitting.
Old May 6, 2019 | 05:36 AM
5 Year Member
Yes i've tried it with closed loop disabled and when i did that it didn't even want to start up and idle.
97Preludeguy
Other Make Vehicles
Dec 17, 2009 06:13 PM
j0keefe21
10
Mar 28, 2009 05:59 PM
the.hamburglar
Mar 26, 2006 08:19 AM
SETI20
Jul 21, 2004 09:50 AM
cougar10ag
Apr 26, 2004 05:57 PM
