PDA
View Full Version : Engine Management and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 [27] 28 29 30 31 32
  1. depin A22 when using aem ems? OBD1
  2. engine smoke..
  3. CEL code 11 - overheating
  4. s300 datalogging
  5. getting chipped ecu back to stock?
  6. boosting a K20a3
  7. how many pounds of boost?
  8. STACK wideband install, ECTUNE, HELP???
  9. what else do i need before i go to get tuned?
  10. 96 GSR runs like crap with obd1 ecu
  11. Comp raised tuning question
  12. tuned ecu's, chipped ecu's
  13. HELP I'm doing an obd1 swap in an obd2 automatic car ....
  14. B18C throws CEL then no power? help please
  15. Innovative LC-1 install problem
  16. 90 ef wont stop 2 stepping
  17. I have some questions about knock sensor
  18. looking for most user friendly EMS for weekend track car.
  19. data log
  20. ECU 37820-P30-010 question
  21. Highest ignition timing recomended on race fuel for Itr
  22. Tuning all motor Probkems
  23. Autronic??
  24. DSM34X Aero Shape Design Install
  25. usdm pr4 crome pro code 36? WTF!
  26. obd1 p72 for b20z2/gsr head???
  27. burning oil
  28. civic EX 97 starting problem... please help !
  29. Getting My P28 Chipped and need Y8 fuel maps. with Phearable
  30. crome advanced table help
  31. New - Hondata FlashPRO
  32. Converting OBD-II ECU from auto to manual?
  33. Im looking into buying an acer aspire for tuning.
  34. AEM Startup calibration
  35. will the afc2 work on my supercharged 07 si..?
  36. Can i use just my apexi neo to engage vtec
  37. Need alittle help wierd rpm and speedometer problem
  38. need help picking ecu please!!!!
  39. Will this datalogger work? Palm IIIc w/ cable to 3 pins.. for a DSM.. PICS INSIDE
  40. some suggestions for s300
  41. Can we pin a thread to this forum with a list of .bin dumps.
  42. tuning stock d16 with emanage
  43. Crome Tuners?
  44. D15b7 ecu
  45. Aem ems general question
  46. Tuning shops in northeast illinoi
  47. AEM EMS delete sensors
  48. i have an s200
  49. J12 Pin on OBD1 ECUs
  50. Can i use a auto p28
  51. Phearable or Neptune?
  52. crome datalogging problrm
  53. is there any other gm 3 bar
  54. P06 Vtec Please help..
  55. 2 step setup through Nitrous/aux on s300??
  56. need help on crank pulley bolt!
  57. Help identify what ECU I have???
  58. Neptune Moates Demon
  59. trip out on this...
  60. automatic ecus
  61. do ALL obd1 P72 ECU's have the 2nd circuit board on top upside down?
  62. Dyno Tuner in Denver??
  63. S300 usdm P30 Base map need help
  64. tuning/tuner options
  65. greddy emanage on p28?
  66. ROMULATOR does not respond any more
  67. Emissions exemption on OBD2 car
  68. d15b ecm
  69. Tuning my 98 GSR turbo, which computer? Need help.
  70. PCT or P73
  71. obd0 ecu flashing code....help
  72. closed loop questions
  73. Where is the ECU ground for p72??
  74. Need help identifying my ECU
  75. having issues with crome
  76. From EMS back to stock P28
  77. obd1 p72 on gsr eg swap
  78. dumb question about S300 Nitrous set up.
  79. Setting lamda, a/f with S300
  80. Crome tunning a p72
  81. dyno days in socal?
  82. obd0 base map?
  83. s300 and fan control
  84. S300 installes -> constant CEL
  85. needing help to tune my car caldwell
  86. can i modify a tuned s300 ecu?
  87. DIY "real-time programming" board
  88. OBD2 to OBD1 and smog?
  89. misfiring @ low load/rpm after fully warms up.
  90. purge solenoid + tuning question
  91. S300 problom. No vtec? Help!
  92. any suggestions would help!!
  93. freelog datalogging thread
  94. p73 stock tune in p28... possible?
  95. hoondata on accord
  96. sohc ecu running dohc
  97. safety on crome?
  98. Need help. Need an S300 .slk file/base map to help start my car.
  99. Na cutting out at 7000 rpm??
  100. High compression on stock ECU???
  101. Throttle cable help???
  102. A/F ratio question under WOT
  103. I just want to get something clear
  104. anyone used an innovate lc-1 wideband
  105. starter solenoid :(
  106. Tanabe Super Medallion Exhaust
  107. tunign with crome injector battery offset for HUGE INJECTORS!!!!!
  108. B16?
  109. which is the fuel pump relay 93 honda accord
  110. AEM 30-1040 + TWIN FIRE + AEM EPM + 01+ coils
  111. Limits of the stock ECU?
  112. skunk2 mega flow
  113. Wideband problem
  114. Cluster problem
  115. how much should i pay?
  116. D16a6 Mini-Me Crome Tune Needed!!!
  117. please help!
  118. obd2 vs obd1
  119. 96 Civic, Phearable ecu, 550's... Bad Idle
  120. bogging coming on VTEC
  121. obd0 tuning
  122. not com. with s300
  123. what ecu?
  124. How to get 880cc injectors to idle smooth
  125. AEM still junky?
  126. Fuel injector cleaner
  127. Authenticate a chipped PW0 ecu?
  128. do i need to tune my car on a dyno
  129. what kind of management
  130. Advantages of P72 with Hondata ?
  131. How to set up Hondata s300 w/ water/meth
  132. how long to tune?
  133. P30 ecu with HULOG
  134. crome fuel tool problem
  135. S300 max power
  136. Quick Emissions Question
  137. eCTune vs Hondata vs etc
  138. 1.25* retard/lb boost b16a
  139. pwm boost problems
  140. Cam Lobe Height Differences, D15B and D15B7
  141. Hondata won't connect
  142. Looking emanage blue installer
  143. Can Crome IGN maps for the P13 be trusted?
  144. Ecu back from Evans tuning
  145. Vtec oil sensor Hondata S300
  146. where to find honda wiring diagrams
  147. New computer... car not running properly
  148. ZC Auto to Manual ECU conversion/chipping?
  149. Advice Needed...Hondata s200 or Crome?
  150. EFI Education
  151. Help with AEM Fuel trims & Engine start
  152. Ctr ecu
  153. need tunable ecu for H22a Auto Swap
  154. Hondata S300 with DIY wideband and logging question
  155. Help....H22 with ls trans,,,,any good??
  156. car idles for 3-5 seconds then dies
  157. Check engine light
  158. Can a bad O2 sensor cause a stall?
  159. chipping ecu
  160. GM 3 Bar map wiring problem
  161. tuning for 100 octane
  162. Solid CEL, constant revving...PLEASE HELP!!!
  163. running lean
  164. Synapse Synchronic wastegate and S300 boost control...anyone make it work?
  165. Car dies while driving RSX with K-Pro
  166. who writes the best basemap.
  167. autometer wideband with s300
  168. P2m automatic to manual
  169. MAC boost solenoid acting up
  170. Need help! with obd2 wiring harness
  171. whats the best program
  172. Ecu Problem P75 obd-1 (Pheable chip inside)
  173. Will an O2 sensor ment for a Civic SI work for an EX?
  174. Fully built turbo b16 emanage blue...need new EMS!
  175. Ecu fuse keeps blowing
  176. where to tune in northeast
  177. 750whp what size injectors
  178. need some info on a spoon ecu!
  179. use windows vista to tune?
  180. How do I check a bad CAT Convert... ?
  181. P0420 code thrown... stalling problem, Help?!
  182. Swapped P72 ECU w/Hondata S200 chip into a P30 ECU w/Hondata S200 now engine light on
  183. Freshly chipped p28, running like crap on basemap
  184. How can an improper tune kill an engine?
  185. 1st post 90' prelude few problems
  186. Assistance with finding a tuner in Miami
  187. Activating chip on Chipped ECU? How?
  188. OBD2 "soft code" errors
  189. Hot idle issue - Hondata S300
  190. crx tuning
  191. Neptune RTP- where to get?
  192. What spark plugs with S300?
  193. Vortech V-5 G-Trim Supercharger
  194. Pherable ecus
  195. switching from crome to ectune
  196. Timing question. Dizzy / ECU relationship
  197. Tuners chime in. Car bogging under light/WOT throttle
  198. Crome Changes
  199. hondata tuning question
  200. changine rev limit effect tune?
  201. Which ECU for LSV, P30 or P28
  202. any other tuning prgrams like this? freeware (ducati)
  203. burning oil?
  204. b20 block question
  205. Built b16 turbo help!
  206. Hondata S300 "auto tune"
  207. 98 lx
  208. OBD0 D16Z2 stock map with 450 DSM's
  209. Horrible Cold Start Symptoms.
  210. Bouncing boost gauge
  211. accord stock injectors
  212. crome tuning for idle
  213. Adjusting the Cams For More Power
  214. any megasquirters"
  215. Will my motor need a tune? (h22 w/ type s)
  216. A few s300 questions.
  217. eCtune gear based boost control
  218. Who is the best tuner in southern california?
  219. stock injectors
  220. Bosch saturated injectors
  221. basemap required because of change in c/r ?
  222. Bosch saturated injectors
  223. Civic motor swap b16
  224. Can you align the tps with s300?
  225. A few questions after S300 install
  226. Wierd issue with supercharged d series.
  227. b16 w450s
  228. Has anyone here ever heard of this "shop"
  229. Anyone have a basemap for a gsr turbo on the s300?
  230. components needed for proper tune? 91 integra turbo
  231. Chipped ecu help
  232. aem 30-1040
  233. Wiring harness dilema
  234. Crome & DSM Injectors
  235. checking ecu job
  236. Please help!!will a tune fix this???
  237. anyone know of any tuners in the greater los angeles area?
  238. odb0 to obd1 conversion 91 integra ls
  239. Vafc
  240. Where to buy plug (B) for AEM EMS?
  241. Help me find a wideband WITHOUT a display
  242. obd0 type r possible
  243. any tuners in cny
  244. Is this the right ECU?
  245. Crome Pro users
  246. opinion needed, s200
  247. Launch control on b18
  248. Cell tracing with Crome
  249. Scaling gm 3 bar and omni 3 bar
  250. Need tuning for turbo h22
