P08 + 300j doesn't work IAB for boost controller
Old Oct 7, 2019 | 02:04 AM
fate2's Avatar
Default P08 + 300j doesn't work IAB for boost controller
Hi guys.
I have P08 + s300j v2 Hondata installed.
Accordingly documentation JDM ECUs can control boost using A17(IAB) pin, instead of A11 purge valve solenoid output.
So, but i have issue that IAB pin A17 has stable +12v regardless of hondata settings(boost controller on or off, any frequency, any settings...)
Where is problem? P08 doesn't work with IAB? Or i missed something?
Old Oct 8, 2019 | 06:32 PM
kugantuning's Avatar
Default Re: P08 + 300j doesn't work IAB for boost controller
Originally Posted by fate2
Hi guys.
https://www.hondata.com/help/smanager/index.html
"Some ECUs contain all the necessary components (PR4, square frame JDM ECU's with IAB control)."
Not all JDM ecu's have IAB control, if wiring and settings are correct you will have to add IAB to the ecu.
WAUKEENEM1
Engine Management and Tuning
Apr 5, 2013 07:54 PM
10sec4door
Feb 5, 2010 08:46 AM
integraturbo
May 24, 2008 05:37 AM
postman
Jan 7, 2008 08:10 PM
Acura_I-RS
Mar 3, 2003 11:56 AM
