- Best ECU for 2001 GSR with only SKUNK2 intake manifold???
- Apexi avc r tuning..
- Tuning Prices
- Question about "Street Tuned"
- Apexi solenoid. normally open or closed?
- i want an ems and or ecu but i dunno which on to get
- Questions about socketing for S300 Hondata
- wich ems to go with
- Wide band question
- noob, 3.5 litre engine management question, tuneability
- What is VTo and VTi from V-AFC?
- s300 2-step
- B16a2 engine tune
- Tuning books
- s300 & omni power 4bar map problems
- Tuning Automatic LS Turbo
- can a p2e ecu run a obd2 b18?
- Crome or hondata
- How to install a Aem Uego wideband in Hondata S300 and Configure it to Work?
- Air/Fuel Vtec Controller
- what ecu do i need for my b16a?
- What is this IC on the p72 ecu??
- ideas, honda s300 vs aem ems
- DOHC ZC help.
- JAW DIY WB O2
- help tuning vafc II for my jdm b18c5
- launch control
- Hondata s300 x64 Driver for Windows
- s200 or eCtune
- s300 help
- quick tuning question
- Hondata S300 - P28 - Baro sensor error (code 13)
- Gain power by remaping my ecu, Possible?
- Street tune or Dyno tuned???
- using 1.3.6.0, updating to 1.3.8.0, any changes
- 96 civic ECU reflash ?
- Hondata S300 gurus How am i looking???
- Reading 5-wire O2 wideband sensor?
- idle issues
- Build NA motor in an obd2 hatch emission questions
- auto ecu question
- Able to Connect to Freelog but all the data that is logged is incorrect
- Random ass question about poor man r computer set up
- Custom chips
- OBD2 Code 1491 Insufficient Lift -recurring '97 Accord Fed/Auto
- S300 datalog problem PLEASE HELP UNPRIDICTABLE
- looking for old hondata software.
- B16A3 Block "FOR SALE"
- code 30
- How to tell if my hondata s200 has the boost option?
- tuning in az
- what different between oil catch tank vs air breather tank?
- aem wideband problems or fuel problems?
- H22a wont go past 2K RPM(2000 RPM)
- help on tuning
- helping wiring switch with s300
- tps code only comes on in vtec? help
- wire tuck help please!!!
- hondata s300 question
- Need Turboedit basemap for pm7 that won't trigger code13
- looking for a map to run
- ((((((((PLEASE HELP CHECK ENGINE LIGHT PROBLEM)))))))
- AEM Software..?
- adjusting cam gears
- AEM EMS vtec question...
- innovative AF not working now with s300
- do i post calibration and datalog here??
- SAFC on 94 prelude H22
- how to chip p08??
- i need some tips!!!!!
- innovates wideband
- 83hp Gain from an AIR FILTER lol
- turbod crx with boost crep
- ECU Identification
- Editing w/crome after tuned w/crome pro?
- throttle position sensor
- safc2 won't hold settings
- VSS eror code s300
- factory knock sensor information/specifications
- Need help, car leaned out
- Does anyone know why Ferrea Roller Rockers cancel Vtec
- Hondata S300 not reading the same boost levels as guage!? Hondata Guru's please chime in!
- b20vtec crx My check engine light
- good tuning solution for a newbie/forced to be self tuner
- help
- s300 smanager virus detected?
- s300 tuning BAHAMAS
- ECU obd2 tuning vs emissions question. Please help
- Hondata S300 Autotune How Too?
- s300 basemap needed
- b16 tuning
- tuning h22a afr's
- cel with crome- stumpd
- Getting started to datalog with an already existing tune
- ►Shops with job openings?►
- idle fluctuation
- can a 92-95 manifold 96-98 motor
- hondata help
- Car wont rev past 2k on hondata, s200, s300 or chrome pro
- base map for b20vtec??
- need help starting problem
- ls/vtec tune?
- moats ostrch,burn1 hulog
- vacume hose diagram
- ecu problemmmm need help please
- communicating with a jdm obd2a p73 in an american civic
- multiple s300 questions (launch control, idle, wideband)
- Who has tried richer afr's (~12.5)?
- Help me street tune my b18c!!
- Virginia emission with S300
- tuning question
- what to use to clean the ECU circuit board???
- Which ecu????
- Problem with harness in ek4, please help
- wire tuck/ hondata problem !!!
- Hondata s300 install issues.
- understanding the ecu
- BEST ECU AND PROGRAMS?
- how do u put a air fuel ratios on civic coupe
- blue tooth connection to neptune rtp?
- SMOG HELP WITH CAMS
- p06 i need chipped and uberdata set up
- about to install hondata s300 in to p28.....
- OBDO TUNING OPTIONS
- Chipped P08 ECU
- Uberdata CEL 3 Motorolla 2.5 HELP!
- lost my burn settings ie chip start ect
- need Help doing the resistor fix for the O2 CEL???
- is jdmshit chip any good from ebay?
- Help choosing an ECU for LS VTEC
- p06 conversion
- need info. regarding chips. plz help
- Tuning...dyno v. street?
- PR4 ECU chipping question
- AEM EMS 1020 Shift light
- vafc question
- lm1 placement and usage..
- Ethanol emission test fail. Nox through the roof!
- Engine management upon engine start-up guidence?
- best ecu?
- Wideband wiring issue
- Hondata S300 drivers
- tuning for 08 Si?
- What sensors can be deleted on crome?
- boost by gear on neptune?
- Making less power on bigger block.. Suggestions?
- crome question need help
- EcTune !!!!!!!
- PR3 ECU with a real Mugen Chip or not?
- J&S Ultra Safeguard tuning help...
- Basis for tuning.
- were to get data logging connector
- xenocron 3 bar and TE
- k-pro & emissions
- MAP Sensor Wiring on 1992 Hatch
- Tuning gurus!!! check this situation please!!!
- PC OBD2 reader on ebay?
- Who has ever seen this reprogrammable ecu???
- LS motor, OBD0-OBD1, CromeGold, a/f won't remain consistent....WTF!
- Hondata S300: Entering different injector sizes
- Engine Replacement 2001 Honda Civic EX
- pr4 ecu
- Hondata S200, Crome, Ostrich compatibility....
- ecu socketing help
- p72 ecu w/ hondata s200 problem
- B18 type-r with buddy club stage 4 cams
- 93 honda civic si igniton problems
- Noob question about ECU tuning
- d16z6 wiring to a 94 del sol
- Still Stumped - WOT causes fuel cut??
- Chip tuners in Ohio?
- Vi-Pec
- i got f@#ked need help
- Oxgen sensor 02 sensor voltage reading? Possible cause of bad MPG?
- Stock GSR With ITR cams
- obd0 to obd1 coversion. what do i need?
- issues with crome/disabling O2
- DIY external distributor
- Universal 12 tooth trigger wheels?
- stupid annoying idle problem please help
- boost control on neptune?
- crome problems
- DIYMIKE How to: Chip your own ECU
- Chicago Land Area
- AEM EMS 3100 Question with dash lights
- Oem crank sensor and aem
- what is this wire used for: D5 "brake switch"
- neptune question.
- AEM o2 sensor cal table way off??? wtf
- ITR ecu
- Hondata s200 code 1 oxygen sensor?
- chip for 1991 crx
- question for you chrome guys
- hondata s300 not getting power
- Difference between Old AEM EMS 1020 vs NEW 1060
- neptune question
- need some wiring info on ODB2a ecu
- Unplugging VAFCII
- wiring vtec gsr
- ngk powerdex
- Hondata 4B to Neptune or S300 on P74 questions
- Problems tuning a quad throttle setup
- Need Help With Greddy Emanage Blue
- Can I use my B16 map to start a B18C?
- 3300+ RPM Sputter
- noob question- universal efi tuning software?
- car bogs out in 1st gear.
- Auto tuning device
- Boosted B20b
- chipping ecus
- ecu acting wierd
- Hondata S200 to S300, transfering a tune.
- plx 250 wideband
- Kpro on a mac
- dataloging
- What Ignition System upgrades are compatiable with Crome?
- Please help me identify that the right ECU is in my car **PICS**
- Omni power 4 bar???????
- I will be in NY and surrounding tuning
- what type of injection does use p30ecu
- all motor d16z6 p29 build 12:1 Compression
- AEM FIC, anyone using one??
- Laptop not detecting S300??
- need help with aem ems and 3.5 bar map install
- any where in san francisco that does basemaps for hondata
- VAFC2 on a d16y8
- question about AFC's
- Why am I getting CEL code #1?
- Tuners in NJ??
- Emanage Injector Wiring *asap help*
- Honda s300 Display Screen Layouts
- TunerView Issues????
- help!! gsr not running right
- Setup is running and idling rich, I need guidance (Crome)
- hondata s200 help
- OBD2B to OBD2A ECU JUMPER harness
- 2nd new laptop to not run Hondata s300... Lovely...
- Washington State or Oregon Honda tuners
- lean afr on start up runing S300
- s300 and gm 3 bar map sensor??
- ob2b to motec harness
- question about Ostrich 2.0
- Timing at high boost
- p28-m51 ecu?
- recomended engine management?
- VAFCs worth it?
- Car runs super lean after WOT?? Idea's welcome
- h22 civic swap
- Hondata S100 Chipped P28
- hondata s200 users,, please help
