- inverter vs laptop car charger
- Crome Base Ignition tables, possible Dwell feature?
- S300 V3 PLX Wideband Digital Input and AIM MXL wiring with custom mounting in EK
- J12 Question (back to stock)
- Step retard on TurboEdit
- VSS code 17 with chipped p28 on 96 civic with a d16y7
- DIY Wideband Controller and Universal AFR sensor
- Civic Vx lean mode tune for better mpg
- 1st gen JDM B16a Harness <> USDM P28
- NPN Transistors where to get them?
- when using b16a2 IAT sensor need new iat tables?
- PWM Kit Components List?
- hondata s300 not reading sensors?
- dsm injectors
- Can't seem to update/install USB drivers on s300 V3.
- Hondata COP cutting out at high rpms
- troubleshooting afr and idle issues for b16a2
- o2 Sensor CEL when it's deleted in hondata??
- numbers on the side of OEM injectors
- Hondata s200 blinking led
- aem ems with audi cop question
- car in limp mode, code P0335 Crankshaft Position Sensor A circuit 1996 Accord LX
- Ebay Warning - Sehablaauction & PrecisionProposition
- Identifying mods done to P06 for VTEC
- Datalogin crome question
- f23a1 crome basemap?
- Guide: How To Tune and Diagnose For Emissions
- HC co2 sensors to use with neptune?
- hitting brick wall @ 5k
- Fuel Pressure in Hondata
- 97 h22a4 obd2 to obd1
- What do I need to tune my ecu?
- Crome pro v1.6.9 cel code 22 and code 26
- Hondata 200 - Replace with Basemap chip?
- High(er) voltage at sensors...
- LS Vtec acceleration problems
- Introducing Hondata S300 Version 3 and new Ios and Android app!
- D16Z6 swap into 91 CRX Si won't start PLEASE HELP
- Part throttle stumbling
- [HELP] obd1 to obd2 ECU swap
- Choosing an ecu
- Turbo d16 won't rev past 5k at wot
- AEM EMS v2 - B Series - RDX Injectors
- Difference between injector plug and pigtail OHM'S
- seemed like the right place for this
- New ECU don't pop CEL when disconnect MAP
- Please Help / check engine light problem
- how do i lean mixture in hondata s300
- tire size
- lsvtec hondata s300 tuning?
- Base map question/wideband question
- Plug Pic's....opinions welcome
- Jdm b16a with p30 cranking but not starting?
- Reputable Company who Sockets ecu?
- OBD2B TO OBD2A PINOUT HELP
- b16 with itr style IM and boltons looking for crome bin
- Mil-spec harness install help.
- Kpro D/C issue
- ecu plug connector
- what ecu do i need to use????
- aem wideband stopped reading
- Aem wbo2 wire to ecu
- Surprisingly low max duty cycle
- h22a problem. HELP
- Avc-r controller
- EFI 101 this weekend.... TURN UP!
- Demon moates for Neptune
- whats resistor RP6 for on OBD1 Honda ECU
- obd2 to obd1 2000 civic si
- Hondata s300 reset
- stock ecu open loop how does it work?
- My sparks!
- ECU Clicking cutting out when hit boost P28 D16y8 turbo
- Trouble setting timing on d16!!
- Suggestions on boost table problem.
- b20b swap and LS ecu
- Hondata S300 increased resolution?
- MTX-L Wideband Wiring Help Newb
- obd0 to 0bd1 question.
- valve Cover gasket question
- Crome pro - only able to get 4 psi from jrsc on b18c5?!
- Hondata Mac Solenoid Wire Up Elec. Newb Help!
- tuning help
- Help k20a2
- 2001 D17 TPS replacement and voltage spec.
- H22A Ticking Problems...
- Crome Tuning and Datalogging
- Ef d16z6 won't run
- Help with crome?
- Wideband questions
- Why is KPRO (ecu) not working at all now?
- Oil pump
- hondata s300 ecu turns on SOLID CEL
- aebs intake manifold with stock p2t
- doing my first swap what will i need 96accord help
- Wiring for engine harness matter?
- wiring tunerview2 hondata module... help.
- stock p06 on d15/z6 mini me
- Why is fuel value so high? Neptune Datalog Video Inside
- Solid CEL no codes s300
- Datalogging TPS Issue
- OBD2 Readiness Simulator
- Highway Cruise A/F Ratio?
- p28 injector drivers smoking
- Off-road OBD-II Healer
- 88 Honda accord stalling! Pleases help!!
- solid cel good ecu donno
- B18C fields sfc vtec controller help
- sensors inside distributor
- B18c jdm type r ??
- Oil leak B18A1
- Need advise on low idle
- F20b starting problem
- ecu help
- ECU 37820-RTZ-X52
- Innovate Wideband Defect Warning
- Voltage offset on Neptune with MTX-L Weird behavior
- Aluminum air intake or plastic ? Stock 2005 honda civic ex.
- 1997 Honda prelude H22A JDM ECU problem
- chipped p75 on h22a?
- Oil level issues
- old Dinan chip
- 2000 civic si b16a2 issue
- Ignition timing vs Static Compression.
- Is my ecu fried?
- Recommend a wideband?
- Check Engine Light Help
- oil light
- obd2 to odb1 harness question
- can hondata be reprogram for a different car
- Simple Wire harness question
- Florida Man Charged in Federal Counterfeit Case
- What tool do you use to cut ecu casing
- need ECU guide for civic 95 engine swap.
- Self Tuning / Management For Boost Help
- Need help with my 88 crx hf b18b1 swap!!!
- intake manifold making a pop sound inside
- Do I need tuned? Am I losing power?
- ECU toasted? fuel pump not priming car not turning on
- s300 issue
- Need help on buying a new motor
- Car wont start with 14.7 fuel tables.
- honda tuning supply anybody know about them?
- Why does my turbo civic wagon top out at 4500 rpm?
- Can I load hondata s300 onto my p28 ecu?
- NEW TO HONDATA
- B20B vtec NA Tuning advice?
- When throttle shuts, A/F spikes? Tip out?
- Custom Wires for LS1 coils?
- HP & Tune Question
- neptune then to crome?
- P28 MAP sensor location
- No CEL help needed please
- d16y7 head on a d16y8 block,quick question
- running higher than stock fuel pressure
- help with sensors
- 1996 Civic engine misfires,help!
- Cant figure problem out, Help!
- how flexible is stock obd2 ecu?
- Boosting a b16
- Whats better low compresion or high compresion
- V6 AEM Standalone Question
- Help Kmanager
- KPRO serial output
- Hondata S200 still worth anything??
- Wideband issues
- Tunerview II
- Burned up harness from upping fuel pressure?
- hondata s300 running rich
- Just completely failed smog at 15mph
- aem wideband failsafe and s300v2
- VSS wiring question. Pin A18
- need sst chip in LA area
- John Cui of Crome on Intel's website
- How Do I Figure Out What SoftWare Is In My Chipped P28?
- hondata S300j h23a VTEC some problems
- Motec M150 ECU, First K-Series Engine Startup
- Greddy E Manage Blue
- 89 CRX si with D16z6 vtec swap OBD0-OBD1
- AEM pro series 1 and windows 8.1
- chrome boost by gear
- access violation in crome?
- Low voltage problem possibly ELD problem
- Demon in older Neptune RTP
- Tunability of OBD0 vs OBD1 injectors (Low vs High Impedance)
- Any Known Crome / Neptune / Hondata Tuners In Greater New England As Of 2014?
- Can HDS be run at home on a pc?
- need someone with a chip burner
- H22 basemap
- hope someone will be generous
- Tuning 3 Civics - hope some will be very generous with map ski files
- Torque Converter lock up Shutter and Vibration
- hondata s300 questions
- wideband o2's and leaded race gas?
- Timing gear issue, need input asap!!!
- B18c Na mods?
- Crome P28 ecu tuning with out burning chips?
- P73 in a full gsr , any problems?
- b20 vtec help
- Compression on my ls-v
- apexi neo key problems?
- eg Honda civic si hatch power steering
- Long term effects of disabled oxygen sensors
- Correlation between AFR and ignition timing
- AEM Injector driver
- hondata s300 downloading
- boosted gsr cutting out
- Do I need timing belt maintenance?
- HELP PLEASE...Turbo GSR hitting boost cut instead of VTEC
- fuel pump sometimes doesn't prime 92 civic 1.5
- excessivley rich crome tune? table pics included.
- AEM EMS V1
- big mpg difference between 87 and 93 octane
- HELP - G23 turbo hits the wall and AFR goes mad @ 5000rpm +/-
- Air Bypass valve foam sponge ripped: AEM CAI
- turbo options
- S300 LAUNCH CONTROLL
- Starting problems
- Does having your A/C on affect your tune?
- 5200 rev limit
- Need help with weird stalling issue
- crome basemap with crower 404's
- Stupid Crome 1.6.9r2...GRRRR
- Need B20 AEM Calibration!!
- tuner in jax FL
- Haltech Platinum PRO Boxes for B, D, H and F Series Motors
- Crome not booting.. on all 3 of my computers
- chipped ECU help!!
- Carb D-Series to B-Series Converion, help please?
- Arduino Datalogger
- Valve adjustment drag?
- jdm b16a ecu
- p75 ecu obd 1 or 2?
- Hondata s300 problems. HELP PLEASE
- PW0-X00 How much money
- do b20/ls nonvtecs usually run higher egts?
- Haltech
- s300 launch conrrol problrm
- P06 MAP sensor
- Dyno Results Pictures inside
- anyone usig aem fic. please helpme out
- hondata with AEM cop system
- Super charged b20
- 5 years parked
- I'm looking for a street tuner in near orange county ca
- crank fluctuation sensor and knock sensor in neptune
- aem stage 2 stand alone vs Hondata s300
- [Help Please]
- crome gold p75
- Battery offsets 525
