Binary File Transfer into Hondata SManager
Does anyone have ROMEditor4 that would load my binary file into ?
Or does anyone know how to directly use binary code from s200 system and load it into SManager file?
I have binary code off of a S200 chip tune but I need to either get it transferred to SManager before upgrading to S300 or if someone knows where the fuel table starts in the code that would be awesome. I've attached a copy of file if anyone knows where the fuel tables begin.
Thanks
Thanks
OP, in order to convert a Hondata S100/200 .bin calibration file into a S300 .skl calibration, one must use the RomEditor4 Software to load a ".bin" file into memory and then save it as a ".re4" file. Once in this format, it can be opened in SManager and can then be saved as a ".skl" calibration. Without the RE4 cable, one cannot save a ".re4" type calibration.
What I don't know how to do is to convert your ".xlsx" file into a ".bin" file so it can be loaded into RomEditor4. Do you have the original Hondata S100/200 chip ?
That really looks like it got opened in Excel and accidentally saved as an .xlsx. I’d start by opening it in Notepad then deleting the header and saving. Then go into properties and change the file extension back to .bin.
But it I don’t really know. Just spitballing.
spAdam, I don't know much about Excel or Notepad, but I do know that a Hondata ".bin" file will be a very specific size when it is saved through the software. IF it is "converted" in some other method, and the size differs... it will not open in RomEditor4.
94lsboost
Mar 26, 2005 10:30 PM
