- DIY ECU/PCM Replacement (no honda re-flash required)
- Closed vs open loop
- AEM wideband/P72 ECU Question
- Suggestions needed: B16/B18C1 Turbo with 7000rpm Fuel/Boost Cut Issues
- Tuning Issue? Sputtering between Gears while shifting
- p28 chipped and tuned ECU problems
- b18b1 swap ecu question.. confused
- Suggestions Needed: No power to ecu after mpfi swap
- Chipped p28 identification
- K20 Cuts In & Out When Light Throttle
- Is it possible to use an obd 1 harness with an Obd 2 ecu with a jumper harness?
- I did a swap in a 93 eg hatch
- Diagram needed
- First map on Neptune. Assistance appreciated!
- Demon with demons? Not sure..
- AEM Uego and Hondata question
- Logworks 3
- how to repair jdm p30 ecu ??
- Help w b20vtec hondata issues
- ignition tuning with Hondata
- Idle with pump gas with bosch 1700cc injectors high Impendance
- J32A in a sand rail
- Going from RC 750's to ID 1000's - Hondata S300
- constantly adjusting voltage offset
- Demon2/Neptune RTP assistance
- where to buy Wiring harness connectors?
- Can i use Apexi Vtec controler w/ hondata s300v3 just for moniter but not tuning?
- S300 base tune needed - B18, e85, FIC 1000cc's
- Innovate lc-2 question
- CRVTEC tuning advice.
- Demon 2 install question
- !!!!B Series AEM coil on plug Hondata ecu question HELP!!!
- Neptune Software Remote tuners??
- need a little brain picking here
- need opinions on what to do with my engine management
- Wideband O2 Recommendations?
- New head gasket but pumping out white smoke now
- Help! random codes thrown s300
- Running wayyy lean idle & low load...
- Dyno tune socal area
- H22A Vtec always on
- Anyone tuned on e85 successfully in cold weather?
- Acceleration enrichment
- Wideband O2 sensor
- obd1 d15b into ek
- Tuning with low CP ratio
- Fuel and spark no start
- Phearable.net
- Hondata Issues - Red Light
- Anyone experienced with Hondata willing to look over my maps?
- disabled sensors ans smog?
- egt difference between cylinders?
- 93 octane w/10% ethanol or 91 octane ethanol free?
- Car won't exceed 4K rpm need help!!!
- Question about OBD2B to OBD1 conversion
- Momentary rich afr when letting of the throttle
- wire identification. OBD2B blue dead end plug
- Help with f20b
- Honda leaking need help
- Obd0 -> Obd1 conversion o2 sensor
- Honda CRV 95 - Is my engine dead?
- Ignition cut
- Damaged p72 ecu help
- JDM H22A Vtec Problem
- 1995 acura integra will crank but wont start
- Car stutters while cruising (Hondata S300V3)
- k-tuner for 2005 rl?
- B20Z2 & B16A2 - Engine Management Question
- Smanager fuel map units
- EP3 Civic SI ECU Harness Spliced Into
- New to hondata and need help
- basemap fail stories
- Lsvtec built. New wastegate
- S300 Nitrous input help
- hi/low boost switch with flashpro
- B20v problems
- Spark plug timming
- 99 civic Ek coupe rebuild *wiring help*
- Lil knock gauge
- Tuning Timing for RaceGas
- Neptune
- Step-By-Step: CROME Tuning 101 - The Basics
- Need Assistance: Tunerview app issues result with using CROME
- Assistance Needed: Fuel pump disabled itself on S300.
- Honda Civic VX
- Sensor/injector resistance cheat?
- Need Assistance: AEM Wideband Failsafe Sensor on Haltech Sprint 500 ECU operation
- AEM CDIs > carboard/paper inside unit, aftermath dead unit
- Need Assistance:Novice Using Turbo D16z6 turbo rev limiter problems on CROME
- Need Assistance: Mihopopvtec's B20VTEC eBay Turbo Kit -What's left to get?
- Can't open bin file from 27c512 HELP
- Help check engine light blinks
- AEM EMS 1060 and AEM EPM COP problems
- Need Assistance: Autel Maxidas DS708 SD card is "unreadable"
- Is it possible to switch from 97 Accord SI-R ECU to Euro R ECU?
- S300 p06 check engine
- lean afr after vtec is engaged
- P29 ECU- How to repair damaged chip / capacitors?
- OBD2 on D15??
- Advice for tuning a P28 with Crome
- OBD1 swap issues
- Need Assistance: EPROM & CROME w/ a damaged chip - Repair options?
- OBDII IACV B23 pin controll signal.
- Map Sensor Question
- Whats this part called
- H22 Turbo Start Up Assistance Request
- knock sensor accuracy
- 05 rl how to interface with stock widebands?
- Hi I'm new here, i need help with Timing
- Wideband datalog Charts Tends to display "Spikes" in its file. Cause?
- OBD11 SYSTEMS NOT READY
- Bluetooth datalog Ectune
- Mind looking at my tables? Boosted CRX b16 T3/T4 OBD0
- Timing out of wack 96 hatch
- R18 ECU swap
- Bought a B16a2 with no O2 sensors??
- Is there a "Best" method for testing a K series ECU for functionality?
- Assistance needed: Megalog Viewer software interfaced with CROME
- where is 2014 R18 Vtec control valve solenoid??
- Assistance needed: Tuning tips on spikes in fuel map w/ differing AFRs
- Crome Basemap (Advise required)
- Assistance Needed: Experiencing trouble with PLX Wideband AFR in Hondata S300
- VAFC2 Vs. Boomslang Harness
- Suggestions Welcomed: Omega Blaze's Neptune RTP Tuning Maps
- H23A-Vtec Crome Tuning Advice
- P0133 bank 1 sensor 1 slow response
- Rich Idle... AFR 11.1
- Suggestions Needed: Turbo Honda Del Sol has a rich idle condition.
- Plx Vac/Boost with 3 map sensor, hondata connection
- Crome Gold map issues
- Table Ignition vs Actual Ignition Question (Neptune RTP)
- Civic Si 2015 ECU Swap
- Please need Gsr Crome basemap with iabs
- Hulog Plugged, car dies & Solid CEL (cant use Hulog and Ostrich at the same time)
- JDM ITR ECU??????????
- Lean running at low load B18CR
- What is the different between EM1 ECU P2T-A11 and the A12?
- first datalogging session. any suggestions
- I'm getting 15mpg!?
- Fuel Pump Wont Prime (P28 w/ Neptune RTP)
- How can I find out what ECU I have?
- Remote tuning?
- What is the standard amount of ignition timing to be used in tuning a Honda?
- Help! Ecu wiring gone wild!
- Ostrich ftdi driver for windows 10?
- Need help identifying aftermakret ECU chip..
- D16y7 Warm Start Problem
- Does engine knock disable VTEC?
- AEM Series 1 basemap
- Few Questions About Hondata S300
- Retuning turbo ek for winter driving? Or just a silly question?
- Bad idle when hot on basemap
- hondata s300 extreme lean on decel
- No Vtec after H-tune Basemap chip install
- Immobilizer on jdm d17?
- boosted integra running extreme lean at idle only
- possible knock?
- Knock gauge
- cant get freelog to work
- Q31 in ecu burnt? would this cause high idle?
- Wideband wiring for s300
- B18b Turbo Check Engine
- Clogged Cat?
- Chipped p28 on Crome with a base map tune ECU in limp mode?
- AEM wideband w/ HONDATA S300 V1
- LS basemap on chipped P28
- MAP AEM 3.5 BAR/Wideband issues
- Windows 10 & Crome??
- Choosing an ECU for my turbo build
- wired problem running lean while fully warm
- What mph should radiator fan turn off?
- ostrich windows error
- Calculating Theoretical Best Timing
- 92 Honda accord Won't stay running
- anyone using this wideband?
- I start my tuning adventure tomorrow. Quick question
- permanent mounting for Hulog and Ostrich ideas
- 93 civic starting problem
- Built H22 very rich at idle
- Ek civic with EG ECU
- VAFC2 not powering up. Please help
- b16 NA tune for 450cc injectors?
- AFR indicating rich at WOT and tip-out
- ignition break up under high boost only
- ostrich 1.0 question
- Autronic PnP
- S300 Copy Protection?
- CRX/D16Z6 wideband tuning with Crome wierdness
- Looking for SoCal tuner.
- Canīt log more than 5k
- d16z6/y8 ignition base map
- Help setting Wideband values on Crome
- Bigger Cams - Base Idle question.
- [s300]Need a map to get to the dyno.
- Obd2a engine on a Obd2b harness
- Wideband X narrowband problem.
- S300: VTEC Disengages in High RPM
- Crome pro and quad cell smart tracking
- Accord 2001 2.3 liter LX base idle screw factory reset is 0
- Info on a swap
- New (to me) toy, pgm tester.
- k24 swap hondata question
- Can't figure out my basemap?
- anyone have a y8 basemap for neptune?
- DIY Tune vs Dyno Tune
- Stock gsr map for neptune?
- Go with s300 for e-85 sensor?
- Injector scaling in neptune
- Idle problem only when I give it gas
- 2000 Honda Civic Si b16a2 question
- Chipped P28. How to Tune with Crome.
- p28 vendors?
- 1997 civic with a built b18c1 hondata s300 etest help
- 98 Honda civic hatch full exhaust
- EcTune issues.?
- Run Hondata w/o O2 sensor for few minutes?
- Need help with Ignition problem on turbo aem series 2..
- Pherable.net ecu with solid cel
- turbo b18a1 3400 redline problem
- 90 DA converted Obd1 410CC RDX injectors boosted B20B low comp
- How To Test My ECU?
- ECU Flash for SLXA Trans
- Iacv delete
- Wait...you can't reach MBT on pump gas?
- lsv turbo basemap
- air fuel gauge in neptune
- Jdm b18c idle problem help plz
- Normal IAT
- What are ECU capacitors & why it is important to replace them.
- tune for 10:1 CR on D16z6
- 0280158827 160lb /1700cc injectors and idle
- Street tuning timing
- Anyone with plx wideband? Help
- 97 civic turbo build with b18a1
- Upgrade from eCtune to What ??
- Secondary o2 sensor removal after Hondata?
- AEM Tuners in NORCAL?
- Crome 1.6.16 link broken - url inside
- EBC w/ S300 having weird problems with Smanager
- Can anyone well versed in Neptune please help me?
- making new injector wiring
- P29-T50 ecu- tuning solutions and auto to manual
- OsideTiger 660cc Injector Battery Offset
- Anyone running Type R cams...Vtec engagement point??
- Hondata Bluetooth display
- 6262 b16 32psi 550whp pump gas timing help
- built b18c turbo issue
- B20B GSR Head what now??
