Troubleshooting: Hondata Boost-by-gear value configuration
- Boost by gear help
Hi everyone kindly help! I have a K20z3 using hondata flashpro. Along with this, my car is ariel atom with Gt35 turbocharger. The car is running fine and properly mapped.
Recently, i installed a hondata 4 port electronic boost controller. I like to know if anyone here successfully have parameter value in the boost by gear under flashpro or kpro. I wonder if you can help and share the values in boost by gear. There are only a couple of values in boost by gear.
Thank you so
Re: Troubleshooting: Hondata Boost-by-gear value configuration
the values will be very different from car to car. You would not want to use somebody else's values. You need to go through the correct process of testing and trial and error to set yours up correctly.
