- D16 idle issues. Please help
- Rattling noise coming from belts?
- AEM tru boost question
- Tuning obd2 b18c-r
- costume harness
- Efi 101: The best thing for beginning tuners.
- s300 problem
- aem v1 1040 and k20 swap?
- need help with a mini me
- question on exact duplicate rebuild and tune
- iac
- Knock Sensor Problem , Code 23 H23a P13 96 accord
- How to set timing.
- monitor afr with wideband questions PLEASE
- EMS for 97 Accord?
- Something doesn't look right to me (s300 inside)
- 91 civic distributer issues ?
- IACV ohms reading ???
- E85 max torque or detonation
- Adding secondary Knock Sensor.
- Sohc 96 civic dx upgrade advice
- P75 ecu
- ecu help
- b20 Distributors
- Aftermarket clusters
- Not EMS related, but computer related
- Map sensor wiring
- need help with tune
- Hondata/ red light/ boost spike question
- Hondatas new update
- Honda crx idle problem
- 1st Post (d15z1 questions)
- Cheapest Air/Fuel Gauge
- Ckf sensor as rpm input?
- Accel 255cc injectors
- Anyone in San Diego with a chip burner?
- Distributer problem or what?
- PCT ecu
- AEM EMS2
- Ignition Timing and A/F ratio...
- tuning primer help
- need a good tuner (and a baseman)
- D16 to B16 Swap, help needed
- B18b1 ebay dizzy help
- ECU Mods 2009 Accord Coupe V-6
- p06 ecu running vtec
- Finished build & now looking into a hondata s300.
- d16z6 motor break in tune?
- auto box with non standard ecu
- compression numbers really low and different???? help
- can someone explain the injector calibration and fuel pressure
- 97 GSR swap in a 95 Dx coupe
- ECtune gone??
- 2004 civic ex wont rev past 4k
- trouble with dsm blue-tops
- free import preformance catalog
- H22 All motor Ignition timing question
- air boost valve & turbo
- Low end power chip
- Trying to decide between S300, Neptune, eCtune
- having a lot of trouble tuning my b20 to not detonate
- HELP!! What ECU is this?
- New eCtune?
- best tning laptop
- I need the dwell Setting RSX Type S coils
- odb1 ecu w/ knock board
- p2p ecu for lsvtec??
- 99 Civic P0420 & P0430
- Hondata s300/ Rich idle (Tuned)
- 1986 Crx blacktop harness swap help??
- Fuel pump assembly horsepower rating?
- I'm really surprised that you can't use an iPhone as a standalone ecu...
- Bought a used aem ems - what harness to run it in my car(s)?
- p28 / p08 smog issue...
- ECU Problem?
- I have a couple questions
- Couple Questions
- Question on hondata s300 convert to gsr vtec
- disable chip p72
- ignition tables and dyno tuning,target AFR table
- Honda fit o2 sensor
- Automatic ECUs and TCUs
- LOOKING FOR GSR P72 CHIP
- Obd1 p72 ecu question
- Hondata: Solid Red Green light
- Does anyone know of an import tuner shop around Meridian / Jackson, Ms area?
- Information on Spoon ecu P73
- how to fix my bad ecu
- P28 Q33 transistor
- Will the Proefi CAN gauge work with an EMS4?
- What would you do if you paid for this tune? ( pics of maps inside)
- ECU revisions....
- Checking Accessories with no ECU
- Need a good basemap for b18b1 turbo
- p13 ecu
- 92 prelude revs increase when put in drive
- NEED HELP. cel codes 6,7,10,22 all being throw at the same time
- Anybody want to convert my s300 map / calibration to chrome, s200, or aem ems v1?
- K Tuning software
- access to sensor data
- ECU/Wiring question(s) for B18C1 Swap into EJ8
- b18C1 Turbo needs help.....!!
- p28 ecu swap issues,car worked fine for an hour then turns off n wont start? bad ecu?
- ECM question
- Disabling vtec pressure / NeptuneRTP
- Random Misfire all 4 cylinders
- Obd1 (civic 95) TDC sensor = camshaft
- b18b vtec conversion
- built b81c wont start..
- I have to hold my key in the start/ignition for 20 secs til my car turns on Any Help?
- 1990 civic si O2 code problems
- Non vtec to vtec engine
- 2 step on automatic car. Help!
- Double checking timing D16y8 turbo datalog file
- sanken Sk5151S data - Vtec conversion
- Unused O2 sensor damaged if left in exhaust?
- high map at idle
- 2000 civic ex obd2 not responding
- Need Basemap or map From d15z6 P2Y ECU ? to use on p28
- turbo d16z6 over heat not in the red help thanks
- chipped p28 itr map. idle hunting
- I want to know if chipping p28ecu can mess with my motor?someone with experience help
- HELP! 2001 lude SH intermittent shuts down while driving.
- Anyone tried this course? opinons?
- K20z1 I have kpro help!!!
- Neptune fuel cut off
- chipped p28 in 1995 honda accord
- CDI or COP (Inductive K-series)
- B18c1 in a 75' Mini: P72 ECU tuning options for Custom Setup
- HONDATA S300 + J&S or AEM V2 W/BOSCH KNOCK???
- boost control with nitrous/aux1
- CC light on in chipped P28
- b16a sir 2 head gasket leak... HELP!!
- Can't maintain cold idle at all
- retune question
- Pgmfi.org registration, no email
- Kpro ELD wont log Under 1.4v
- s300 in a auto odb1 ecu
- Hondata K-PRO is now $300 cheaper!
- NA/ ITB tunning.
- NepTune experience in JAX
- how good are tweaked basemaps from .com shops?
- Any recommendations for Tunning systems?
- 1995 d15z1 noise? Can someone help diagnose the problem?
- hondata s200 box not connecting
- check engine light
- 92 civic b20 showing 20 ecu code
- Tuning D16Z6 with Y8 head swap
- Det Cans / Electronic Stethoscope.
- 91 hatch d15 to d16y8?!
- Tuners-how did you get there?
- cat converter
- S300 BBG overboost at random
- Bin requst : b20 Turbo
- Help me decide which tuner to use
- Aggervating codes gettin old!!!
- B16a turbo w/ stock ECU
- Neptune RTP with Skunk2 Pro1's and 1000cc injectors idle video
- Do I need bigger injectors?
- s2k tuning questions
- Gear Compensation - Question about my tune. Why decrease fuel in 4th gear?
- H22 vw polo HELPPP start up
- P28 Basemap/tune
- Low idle when I use anything while warm
- HELP IGNITION THROTTLE CORRECTIONS
- d16y8 versus d16z6 - Which is best for tuning?
- Neptune installed!
- h23 bottom/h22 vtech head NEED HELP.
- Issues with my H22 swap..
- Awkward Idle Problem, Need suggestions.
- can i tune my single non vtec?
- PLZ Help 92 Gsr P61 ECU gone bad. What ECU to buy as a replacement??
- Interesting problem *PLEASE HELP* Car wont run!
- Want to check my chip (what/how/who?)
- Germany : Garage Werks Racing ........
- b16a sir2 vtec not engaging?? help:(
- Ask a Tuner: Interview with Kenny @ Turbogixxer Tuning
- 96 boosted civic possible Limp mode/open loop
- Computer won't open my existing tune on Kpro. FUH!
- Will OBD2A wiring harness work in an OBD2B car?
- B16 turbo breaking up before boost...
- Replaced AEM UEGO Sensor..s300 doesn't read it
- Question about high comp and tuning
- would anyone know why my exhaust gurgles and pops while idling?
- S300v2 ?
- Boost target speed table??
- WTF COULD HAVE GONE WRONG LOL
- AEM Series 2 + Stock Knock Sensor
- 1720 Board ECU NOTEC to VTEC CONVERSION
- Preface - Interview with Kenny @ Turbogixxer Tuning
- Ok guys, I'm back and we are improving.
- need help with ecu and main relay
- Need help with CEL troubleshoot CODES 43/45
- AEM wideband stays at 14.7
- How to add new ecu?
- Best Weber carb?
- 1987 civic devacing?
- Ecu ?
- Turbo civic running very rough
- help with greddy emanage ultimate
- Motec M4
- Best Place to Tap the Switched 12v?
- RDX injector battery offset for crome
- Vtec not engaging on b16a *please help, new to the forum*
- New video of Hondata's Traction Control In Action.
- honda civic type r ep3 running bad. Help.
- EGR control solenoid for 1995 Civic VX HB
- PWM boost install
- help with ecu choice and wideband setup
- aem wideband + chrome
- jdm ecu barometric sensor code 13
- 94 prelude ideling trouble shooting
- need help. my check engine lights on
- Hondata S300???
- Obd1 ecu plug
- advance tables in crome anyone know?
- chipped p75 ecu running b16 no vtec?
- Burning my own ecu chips what will it really take?
- D15B year and ECU probleme
- TDC code 8 issue, dizzy is good.
- Engine Sputters, headlights flickering while driving?
- How can I tell if my turbo car is "chipped"/tuned?
- Crespo Cams 3 bar map sensor values
- Who can chip my p28???
- s300 same p06 and same tune, different results.
- hondata and 8 injectors
- can you tell me if my ECU is socketed or chipped??
- The ECU Chipping Rundown
- what can i do with crome free?
- P72 Chip Question.. NEED HELP
- Clutch Switch - OBD2a - Pin C29
- B18C LS/VTEC B18B block running lean at full throttle
- Mpg build
- My sohc is burning oil and dont know what it is
- AEM: Ign timing drops at WOT throttle.... HELP URGENT
- Need help with IAT and ECT compensation S300
- H22 replace destributor (advices)
- AEM v1 vs. v2 Pros and cons?
- Weird Chugging Noise 1997 Manual Civic DX
- Can someone identify this sensor? 1998 Accord
- Open/Closed Loop with Code 10 for IAT on OBD1 Honda ECU
- Datalogging Real Time Neptune with Nokia Cable
- losing fuel prime
- Honda Tooth patterns.
- Help!Check engine light is on after replacing radiator.
- 00' prelude obd2-1 distributor issues
- Crome pro with anti-lag?
- Kpro ECU wont power up
- Megasquirt
- Hondata vs. Neptune
