Hondata S300 V3 USB Cable?
Old 04-05-2019, 05:59 AM
jdm_special's Avatar
Default Hondata S300 V3 USB Cable?
Hey guys,
I just purchased a s300 locally and it did not come with a usb cable, I searched on the hondata website and theyre asking $30 shipped for the replacement. Do I have to go with this one or can I get other cable with the same connector ends? I believe theyre all usb 2.0. Thanks!
jdm_special is offline
Old 04-05-2019, 06:47 AM
AllMtrRex's Avatar
Default Re: Hondata S300 V3 USB Cable?
Any usb A to usb B cable will work. The hondata cables uses a ferrit bead which helps with electronic noise. I've used with, and without the ferrit bead and never had any issues.
AllMtrRex is offline
Old 04-05-2019, 07:12 AM
Go local radio shack or frys or Best Buy or any electronic store
theyll have em for like $7.99-14.99 usually
i got mine local at frys for 7.99 plus tax
KiNGDEE206 is offline
Old 04-05-2019, 12:07 PM
appreciated it guys!
Old 04-05-2019, 11:32 PM
It is essentially a USB printer cable...
JRCivic1 is offline
Old 04-06-2019, 04:52 AM
2x0
2x0's Avatar
Amazon has any USB cable you need for like $5 or less. Get a USB A to USB B, an extension adapter and a panel mounted USB port to mount somewhere on the dash so you can keep the ecu tucked away
Whole setup costs about $20
2x0 is offline
  • Ask a Question
Question Title:
Description:
