K Series sensor specs, research advice needed.
I will be using KPro on a 2008 Honda Fit L15a1 engine. I an looking for the actual specs of all the sensors of the RSX and Fit sensors. If you have the actual info to share that would be swell but Id rather find the info.
Also, Kpro is made to also run D17 and F20 which both do away with the second cam timing sensor. Does anyone know if Ktuner will do the same? Only asking incase 05-06 sensors would be a better match compared to 02-04 if different at all.
Quad-Damag
05-19-2004 11:05 AM
