PDA
View Full Version : Engine Management and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 [18] 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. target lambda for e85 in racing application
  2. chipped p28 and no rpms
  3. Running lean in Vtec!
  4. plx d-5 not reading with s300 or on gauge?..pics
  5. ERL 5 Point Girdle
  6. d16y8 turbo and auto to manual wiring
  7. Bin file needed
  8. Denso b16 o2 sensor pinout please
  9. Stock Map Fuel Maps
  10. Not tuning vs tuning
  11. stock ecu
  12. Motor break in question
  13. B20Vtec Hot engine won't start.
  14. Chipped P72 Looking for street tune
  15. making a wire harness. what to remove, what needs to stay?
  16. Question Regarding Crome
  17. Neptune RTP Issues
  18. S300 b20vtec map
  19. crome 1.6.0
  20. Just got a 91 hatch w/b16a2 swap.....
  21. 89CRX dx Build, Throwing Code 8
  22. Help registering on to Hondata.com
  23. NepTune RTP Question
  24. Hondata issue
  25. Swap out intake manifolds
  26. S200 Hondata question. Fuel Econ question.
  27. tuning my aem ems
  28. Crome pro ecu code 24
  29. hondata and liberty tranny
  30. HELP! p06 vtec conversion now car doesn't run right.
  31. deka siemens 630 cc and Neptune
  32. L2H2 and S300
  33. how to hook up my temp gauge b16a
  34. Greddy Emanage Ultimate on a 97 Civic
  35. What kind of sensor does this fit?
  36. B18C JRSC S300 Launch Control
  37. B16a Smoking Randomly?
  38. Does anyone recognize what chip this is?
  39. tuners around philly, need help
  40. B18c1 won't start... Searched all day sorry gotta post.
  41. Need Help Finding Pin Out Description
  42. Diagnostic software/ dpf regeneration ?
  43. 91 civic w/ jdm ITR obdII tunning?
  44. anyone ever use richtuned dyno tuned chips?
  45. C.O.P Coil packs, how long do they last?
  46. PLEASE HELP me with my b16a
  47. b16a vtec problem
  48. can i use a automatic intake mani on a manual car
  49. S2000 - RPM Driver Questions - S2000 Engine in a kitcar
  50. b16a pressure plate torque???
  51. s300 issues
  52. Help with my new Prelude ECU issues ...
  53. Response by OEM ECU if see misfires? -Faulty Crankshaft Speed Fluctuation Sensor(CKP)
  54. OBD II ECU in a '95 Civic EX: Worth it or not?
  55. good unichip tuner in socal
  56. s300 2 step?
  57. my smanager is buggin out with the floating point division by zero in the display
  58. what map in p28 for b16a2 ??
  59. s300 Help??
  60. Stage 3 ECU question, FNG here
  61. D16Y7 TUNE AND BUILD
  62. What STOCK ECU to run on my B16A??
  63. all motor tuning vs forced induction tuning
  64. NepTune RTP/PMW boost Tuning questions.
  65. 1995 B16A to 1990 Integra
  66. Question: Setting up datalogging on s300
  67. trying to get my aem ems to work
  68. O2 sensor.
  69. anyone seen this in s300?
  70. hondata ?
  71. single cam boost
  72. knock off 255lph pumps are junk.
  73. 2000 Honda Passport
  74. ek9 type r power loss from header and cat back
  75. Starter Engaging while engine running
  76. NepTune shift indicator
  77. Removing Top Speed Governor on NepTUNE?
  78. will headers really make a big hp
  79. Tuning noob, need advice
  80. Need help w/ identification. Piggyback system?
  81. mini me tune
  82. datalogging wb caused an issue
  83. Surging B16A...paid lots to fix...still a issue
  84. a vtec enabled p06 and hondata?
  85. Stinky exhaust
  86. Retarded 2 step FTW
  87. How lean on low compression NA?
  88. having break up in boost
  89. A Few Questions About Tuning With Crome
  90. PCB-N51 immobilizer help
  91. Header question
  92. Creating the fastest ek4 civic
  93. d15b vtec timing issues help!!!!
  94. all motor tuning
  95. Know Where To Get ECU Circuit Schematics?
  96. S300 launch control setup with e85
  97. Dialing in anti-lag/2-step
  98. Cylinder misfire trouble
  99. wiring in new injector plugs
  100. I cant handle ectune lisencing anymore
  101. h22 wont start
  102. Tuned on crome two step not working??
  103. spun bearing/ crank question..
  104. Automatic Tuning solution.
  105. chrome tuners in PA
  106. How to convert s300 tunes to s200
  107. Convert Crome P72-base to P30-base
  108. Scangauge
  109. noob question please help freelog with crome
  110. Can you activate and progressively control a water/meth system using s300?
  111. cant tune s300 , IAT reads 129.4 degress F
  112. sensor question?
  113. 1994 Integra HELP!
  114. Using crome to change 450cc to 880cc
  115. F20B ECU tuning.... any other things need to change
  116. NOOB Desprite Need of Help. NOOB
  117. -----------GM Intake Air Temperature, IAT, Sensor with Neptune or Ectune-------------
  118. Engine sputter?
  119. itr in 97 civic LEAN issue and 3bar MAP sensor questions? HELP
  120. oops
  121. P72 IAB A17 Problems
  122. How to get good tuning practice
  123. Ecu mapping hondata s300
  124. Rhode Island
  125. LS vtec timming.... HELLPPPP!!!!!!
  126. VTEC pressure switch plugged on new motor
  127. LS-V idle problem
  128. AEM 1070 compatable in ep3?
  129. Tuning from anywhere by using internet
  130. B16 MPG Build
  131. header for 01 accord?
  132. Can someone disable launch crontol for me?
  133. Apexi power fc or S300?
  134. B20 Base Map?
  135. Import DPS dyno readings
  136. looking for hondata street tuner around philly
  137. HELP.........Integra Type-R Turbo Water Temp to hot
  138. Whats up with these two ECU's? Pics inside...
  139. NEW - Coil On Plug for Hondata s300 users is finally here!!!
  140. switching ecu's p28 to Po7
  141. Fuel Cut on Deceleration Neptune RTP
  142. how to open .BIN file
  143. open wastegate and wideband readings
  144. crome vs hondata s200?
  145. 98 accord 2.3l v-tec timing?
  146. b18b help
  147. Mode 6 Data Definitions for OBD II online
  148. H.O.A.R. (Honda Owners Against Ricers)
  149. omnipower 2.5bar map sensor info needed
  150. E85
  151. obdo pm6 ecu chip questions for a d series
  152. Type r ecu in em1?
  153. Taking the plunge..
  154. car wont start after head gasket replaced
  155. Seeking any obd0 tuner in the Bay Area
  156. Attempting to fit an MSD ignition system 7 blaster coil
  157. Best means of 2-step for DC2?????
  158. hondata s200 wont start
  159. New chip throwing codes
  160. a few problems with partial throttle and cold start after tune with hondata s300
  161. Integra 92 xsi injector & ecu problem
  162. Drunken rant on Serial and USB to Serial
  163. Custom wiring harness for GE Fit and AEM F/IC
  164. What parts do I need
  165. RSX-S vs. K-Pro ECU help
  166. smanager compatable with moates??
  167. NOOB post: which chip kit
  168. were to get a base tune?
  169. Need a tuner
  170. Hondata S300 with P28 ECU
  171. tuners in PA
  172. S100 Dead Time Calibration
  173. hondata questions??
  174. s300 andd fire spittin awesomeness?!
  175. knock monitor
  176. Use ELMSCAN 5 Compact USB scanner to interface OBD ECU
  177. tuners in california
  178. Where to get car tuned in madison,WI
  179. bidirectional scan tool
  180. s300 injector problem
  181. dyno station and tuning
  182. Help with chip choice
  183. how to read a tuned chip?
  184. Identifying OEM Distributor??????
  185. S300 setup questions
  186. How to get crome at home
  187. Very rich start in hot weather
  188. anyone with master level knowledge on the hondata s300?
  189. AEM Series 2 base cal
  190. eCtune website for sale - Is it gone?
  191. HONDATA S300 or APXEI VAFC2
  192. blackworks racing 4bar MAP & hondata s300
  193. OBD0 PM6 already chipped?
  194. Hondata 4bar map
  195. Dyno tuning in Midwest?
  196. I NEED HELP! I have ob2 engine and obd 1 car. what ecu should i use?
  197. Ceramic coated or stainless steel headers???
  198. OBD2 and Engine Maintenance Light
  199. Car wont start.
  200. ANYONE left in MD to tune NEPTUNE??
  201. voltage regulator test procedure
  202. Ls vtec turbo startup
  203. lm-2 needed to street tune with neptune or s300?
  204. FMU JRSC problem?
  205. EG H22 Swap, CEL code 1 and code 43 problem. Help please.
  206. tuners in europe?
  207. HELP.........Hondata S300 and 1100 Bosch Fuel Injectors Problem
  208. any other options than hondata ?
  209. ep3 Civic si 02 Intake options?
  210. ecu issue
  211. hondata s300 and id 1000CC
  212. burnt main board capacitor
  213. WIDE BAND CHOICES
  214. Which ecm should i use with a B20z2 swap in a 1998 civic
  215. Afr on wideband
  216. ecu chip question
  217. B16 Swap problem
  218. new to crome tuning
  219. CROME question on ypipe tuning
  220. Aem v2 bugs néed help with
  221. TPS HELP
  222. Fan switch Ectune/Neptune
  223. Sputtering Turbo GSR
  224. 01 Accord Engine run bad
  225. Delete o2 sensors?
  226. Neptune or Not?? help
  227. cel on chipped ecu
  228. Virgin p06?
  229. SLC DIY
  230. Injector questions
  231. VTEC engaging way too late. Need advice.
  232. car idling high after phearable diy chipping kit install
  233. 2000 civic help 4k rev issue
  234. Gsr Ecu or b16? Help!
  235. h22 basemap
  236. rough idle, and miss at lower RPM
  237. Honda ecu 4 non honda
  238. noob question reguarding launch control/crome
  239. Delaware -New Castle area or close
  240. Turbo Integra AEM EMS tune Question/Help
  241. built gsr,doesnt stay running,rough&jumpy idle
  242. how to re-chip JDM B16A EG6 ECU (OBD1 P30)
  243. Load bearing dyno locations
  244. High idle after tune.
  245. Obd1 Accord / Prelude ecu plugs
  246. CEL in 99si
  247. Trouble getting speed limiter to work
  248. Where can i find Crome Plugins?
  249. OBD2b Integra w/obd1 ECU and jumper harness
  250. went to tune. car wont start
