- Universal vs. Stock O2 Sensors
- check engine light help
- Passing NYS inspection...help!
- Reliable tuner in the Fort Campbell area
- lsvtec ecu problem
- Need help tuning S300 on Boosted z6
- Is the car worth a tune already? Or should I wait? Mods in post
- chipping an ecu .. parts i wanna get so far, what else am i missing here
- Obd1 non-vtec sohc gas saving binary
- Overclocking obd1 ecu
- How to burn with the Ebay Top853 Programmer
- DOHC ZC Turboedit, Engine Problems
- GSR DRIVER MOTOR MOUNT HELP PLZ
- GM boost solenoid/s300 issue
- Hondata S300: fuel system error code
- OBD2 ECU
- LS EG Hatch Failed Smog at CA B.A.R. Results Posted!
- For sale
- My new scanner
- "cold" start and s300
- performance ecu chips?
- Just got a chipped( not going to mention name out of respect for a vendor)ecu
- Need help identifying ECU and checking it
- s300 and 95 honda accord
- S200 tuner needed in the bay area (located in east bay area)
- Harness problem????
- Intermittent screetch/clicking when starting the car??
- New Honda Cylinder Heads
- Innovate LC-1 ReCalibrate?
- Hondata s300 questions
- Megasquirt map
- itr bottom gsr head have p28 chrome want something new
- Pistons B16a+crank B18C6
- tps and aem ems problem
- HONDATA History
- going from obd0 to obd1, need ecu advice.
- P30 Usdm or P30 JDM ecu program?
- Cannot rotate dizzy far enough to time car
- Hondata S100 - what's it worth?
- Using Log works with IAT & ECT sensors
- Swap/ tuning Help ASAP
- shipping a obd1 ecu USPS Flat Rate Envelope Help
- Exhaust
- p28 (r49 operation?)
- NEed help
- hondata problem
- open loop for high load.. closed loop for light load BUT....
- P28 R75 & R77 burn track
- Critical Questions need answering. please HELP
- Which wideband operates better with hondata?
- .bin file basemaps? obd0 tuning?
- Crome data log
- CEL 21 After Converting p06 1720 board to Vtec
- need advice for diagnosing a smoking problem
- best tuner in socal?
- ECU Remapping services?
- s300 aem uego fail/ s300 fail
- LogWorks OT2 data logging for obdII cars
- AEM idle tune problems
- P28 ECU chipped?
- parris engine dynamics????
- Mustang dyno??
- Innova Can obd1&2 code scanner problems need HELP
- How do i make a basemap with s300 ?? 800 whp street car
- stock ls integra distributor
- which s300 basemap to use for stock coupe 99si
- turbo ignition timing and afr for mpg
- neptune/uego offset problem
- Problems with burn1
- Wiring LM2 to P28/30
- P0010 Problem
- winter tuning questions..
- traction control speed sensors?
- b18b computer question
- Radiator nipple stripped
- Code 16, Need Help Diagonosing
- grs tuning
- fresh rebuilt b16a2 .. p28 or p30
- b16b base map ITR map not working
- ITR Bin File (Crome)
- where to download crome tuning software?
- 95 turbo ls/vtec coupe still wont start w/video
- P2P or P2T? What to do.
- Programs for Tuning
- Lookin for mechanic in milpitas/ fremont area CA
- msd 6al or msd scl box (gsr turbo set up)
- s300 and chip burnign question
- datalogging/livetuning with a MAC?????
- Hondata Calibration Data for DW Injectors
- Started tuning my built b16 today questions
- 95 civic b16 engine fell
- d16y8 very high cold idle
- Honda/ tuning/ diagnostic/ informing Android apps
- Is Passwardjdm.com Reliable
- 2 step help asap please
- ecu question
- what kind of cams are these?
- hondata help please read ??
- Eg ls swap w/ auto ecu...redline at 6k??
- AEM ems 30-1000 box help
- My OBD0 LCD project short vid
- S200 question(s)
- TWM itbs TPS in s300 help
- How do I check timing on megasquirt
- chipped ecu tuning question
- Disabled 02 sensor but still a cel #1
- best upgrade for my prelude
- OBDO, OBDO1 AND OBDO2
- Hondata S300 on a ITR 98 spec
- help hondata with tps setting
- NTK L2H2 Wideband Gauge?
- Whats the failure rate of Hulog
- ls/vtec question
- honda civic 2000 dx motor shakes like hell
- CTR map
- What basemap should I run? b16a Sir2, 93 hatch
- Calling PowerFC Users
- need a lil accord tip...
- Crome Disable ELD any effect?
- chipped p28 thats got issues
- ECU chips
- J's racing ecu
- Can Vtec set to open 2 time with CROME
- Master battery cut off and ems?
- b16a base maps
- wideband readings with exhaust clamp
- P28-G01 C18 Blow..check engine light
- Need help with aem boost solenoid
- PGMfi RTP how to load program to NSVRAM
- k-series ecu
- anyone teach tunning lessons?
- Neptune board install
- AEM EMS, S300, sensors, and the meaning of life...
- 95 EX still won't start, losing hope
- tuning options for obd2 97 honda civic?
- CEL 41 after Chipping/converting p06 ecu
- injector swap on tuned motor..
- P06 r67
- B20 basemap
- wideband tuning question? please
- anyone have a chrome bin for a 95 B18C ?
- Disable o2 sensor or no on p28 chipped ecu?
- Is Crome Dead?
- is my ecu chipped
- Harness problems
- Help need, try to build own b-series simulator
- s100 chips reusable?
- Neptune,crome,s300,demon,ectune
- Chipping p72 vs P75
- Where do these wires go?
- P28 re-worked to run IABS
- AEM UEGO Glitch
- help with p72 running a y8
- is there a how to guide on tuneing the s300?
- passing vehicle emission with a POWER FC
- Identify this map sensor
- Request Before and After tune with new cam
- jdm d15b rebuild help
- d15z1 ecu options
- P0F-004 H22a ECU..can it re-chip?
- FPR Fuel Pressure Regulator
- Crome Pro Street Tune....Anyone intrested?
- B&M Comman Flo Fuel Modifier
- TPS voltage question
- Where to buy RFI shielding for wiring ?
- What standard AFR tuning for honda
- H22a used p30-010 ecu error code 16
- Why is my AFR reading all weird in Neptune?
- Help on K20A crank and cam trigger wheels
- Easy wiring questions.... just 2 easy sleazy ones!
- ecu # 37820-P6WY-A50 what ecu is this?!
- Ngk wideband with Ectune
- OBD2 - OBD1?
- Good place to get stock ecu
- No added features on Stock p28 basemap "Crome"
- Breaking up around 4-6k
- Burning Chips with NepTune RTP?
- H22 timing
- APEXI PFC QUESTIONS
- Hondata Mac compatible?
- Afc to tune ?
- OBD1 to OBD2a
- 240 cc on turbo lsv
- help required with a p30 ecu
- raychem wire coverings
- hooking innovate lc1 wideband to hondata s300
- SLR CHip!?!?!?!
- ECU's
- Converting and chipping a P06 ecu
- AIR/fuel problem (crome tuning)
- P72 chip in P28?????HELP ME!!!!!!!!!!!! (GSR SWAP)
- is it ok to put 16 volts to hondata s300?
- Inquiry: Hondata S300 basemap availability for a D16y7 or D16y8
- Installing inductive tach with no plug wires?
- moates demon question
- Need suggestions: Starting car after warmed up M&W, 1D1000
- anyone using the aem v2 ?
- New to Tuning/ Engine managment
- Where to source out new ecu pins.
- having trouble getting hondata s300 software installed on my laptop
- what do you guys think is the most reliable fuel pressure gauge?
- Hondata or Neptune?
- E85 Lambda targets
- phearable chipped ecu
- NGK Powerdex
- AEM V1 vs Hondata S300
- Can you tune for nitrous on Crome? (D16Z6)
- Fuel cut on deceleration on a P28?
- Distributor question
- Fuel/Timing Maps
- Best Tunning Shops in KY OH area??
- help tuning B20VTEC wit Pro2s
- AEM V2 ECU FOR S2000 ON A RSX HARNESS? (KSWAP)
- spark flame front speed
- Neptune Question??
- can someone teach me what the cam gear does to the permance of a sohc vtec engine?
- What to use for obd 2 B18B1
- ZDYNE Software
- NEW From Sema 2010 - Innovate MTX-L ALL IN ONE WIDEBAND GAUGE
- Blox Intake Manifold on a GSR
- Tuning single cam with bolt ons
- Looking for a good tuning book
- eCtune - People waiting on licenses
- AEM Sync issue / cutting out?
- JDM GSR SMallbox ECU!?..WTB!
- P06 or P28 chiped with chrome
- tuneing
- B16a P30 basemap, engine stall 2xxx rpm?
- engine cleaner
- Vtec controller
- honda ecu question
- can you use emanage and make it reliable
- kmanager reads ecu online ignition off when key is in 2nd notch
- Neptune chip from ecu to rtp file ?
- Hondata Kpro boost by gear setup questions...
- could somebody tell me...
- lc1 wiring cant figure it out i searched LOTS
- Chrome wideband tunner
- freelog and aem uego
- strange issue
- hondata s300 base tune?
- HELP! P2E d16y7 ECU driving weird.
- Dyno tunning shops in San Jose CA?
- Crome,Neptune...anti lag features??
- ectune and boost controller questions
- good place to get soldering supplies
- D16y8 head shaved
- Nickel in 2.4L Accord Engine
- crome dyno tools, how does it work?
- ECtune idle problems
