PDA
View Full Version : Engine Management and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 [31] 32
  1. ID this ecu?
  2. What type of tuning software should ! use if turboing a d16 non vtec?
  3. Hondata S200
  4. B18 Afc Neo Help!
  5. Help troubleshooting ECU check engine circuit
  6. Which tuning software?
  7. Which Engine Management for 99 Civic EX AUTOMATIC with Greddy Kit (TD04)?
  8. k20a ecu diagram
  9. Question about phearable.net
  10. 3rd or 4th gear pull on dyno, which is better?
  11. Quick Question on timing
  12. Fuel Pressure question - hondata
  13. P73 + Knock Sensor + LS VTEC = YES or NO?
  14. vtec controlers
  15. help my gsr
  16. crome wont let me change my 2 step
  17. Full throttle shift on s300
  18. cant get a hold of zdye?
  19. Strange Crome Problems, Need help desperately!
  20. crome.. denso 720s
  21. Crome Uberdata AFR Chart Graph Table Picture
  22. wat the caused of white smoke when start up
  23. i need a help on my d15b stock engine
  24. LS/VTEC NA with listed mods. Surely a s300 basemap out there
  25. need help with terminal pin
  26. Neptune RTP -- H22A JDM basemap needed??
  27. somebody please confirm this
  28. Chip Problem
  29. TPS sensor maxes out at 89%
  30. sites for good basemaps
  31. neptune variable 2 step?
  32. Need Some Help
  33. hondata pwm boost control w/ hi-low switch
  34. TPS based tuning
  35. O2 voltage sanity check
  36. Tuner Directory
  37. ::::CODE READERS NEEDED::::APPLY INSIDE!
  38. Ectune and Percision Injectors
  39. Tuning and Honda 0101000111101011101???
  40. Can A tune be made w/o Air Intake sensor?
  41. Mugen N1 for S300 (DC2)
  42. Romulator-Program relationship?
  43. Hondata s200 cutting out?
  44. need help s300 datalogging
  45. PM6 tune with Turbo Edit???
  46. i have a important question please look
  47. need help with motec
  48. Fuel Injector Identification
  49. What kind of ECU is this?
  50. B18C swap
  51. tuning itbs
  52. s300 tps
  53. R54 S300 Install in a P28
  54. Car was tuned on crome with a 2 step... how can I go about changing my 2 step RPM?
  55. neptune question- datalogging stops mid runs??
  56. Need an all motor k series basemap
  57. ITB bin file anyone?
  58. Neptune
  59. hondata s300 nitrous wiring
  60. need help with crome basemap
  61. vtec cut off and check engine light
  62. THROTTLE BODY
  63. Idling problem when light is on and A/C is off (Power FC)
  64. hondata s200 problem code
  65. hondata boost control solenoid
  66. AFC + Hondata Flash + N/A = ???
  67. Greddy e-01 HELP! wiring!
  68. Help wiring aem 3.5 bar map sensor.....
  69. obd2 hondata?
  70. break up during deceleration
  71. OBD1 PR4 issues
  72. GReddy Ultimate Map (K20a2)
  73. P13
  74. Dyno's in CHicagoland area?
  75. ecu id
  76. ECU fuse problem.
  77. car wont stay running
  78. problems after chrome pro tune
  79. Hondata S200 Questions
  80. neptune boost control
  81. VSS issue needs resolution!
  82. Is this site reliable as a comparison?
  83. Best set-up for Hondata Reflash
  84. tach jump with s300 and jdm cluster
  85. where is a good place to buy a heat gun for shrink wrap
  86. Switched to Hondata now VTEC randomly won't engage.
  87. What are my options?
  88. after switching to a chipped ecu car throws IACV code and idles speraticly
  89. i need help on rebuilding a stock engine with aftermarket parts for a better fuel economy and perfor
  90. Can you chip a accord ecu?
  91. chipping obd1 P72 help
  92. fuel maps
  93. Car won't start help!
  94. FUEL EFFICIENCY Forum?
  95. help finding a good tuning shop
  96. P73 EDM ECU Question
  97. looking for a tuning shop
  98. s300 base for GSR turbo
  99. S300 now VTEC sounds non existent?
  100. Propane conversion
  101. whats your advice on this tune?
  102. obd0 question
  103. Greddy E-Manage
  104. p75 chipping issue
  105. How To Disconnect Wire From PCM Terminal
  106. Who is the best AEM Tuner in Washington/Oregon
  107. Timing belt 1990 Acura Intergra.. Skips, on intake cam!!!
  108. What AFR should I be seeing?
  109. hds software
  110. look for fuel map for a civic type r
  111. hondata help
  112. New to honda...08 Accord piggybacks/chips?
  113. ems whos using it
  114. E85 Honda Civic Conversion Kit.....
  115. AEM EMS problems!
  116. KPRO tuners in South Florida???
  117. E85 tuner in midwest
  118. the truth about the Mac boost solenoid?
  119. Radiator coolant
  120. idle surging.... please help!
  121. 1 kpro ecu running 2 diffrent tunes?
  122. I need help with the P72 base map to run Type-S H22 on Neptune RTP
  123. Another wiring issue...need intelligent help. CKP sensor issue..check inside
  124. electric spray on ecu?
  125. <<<HAHAHA too funny- Check this out tuning 101 at its worst!>>>
  126. need help
  127. Tuning problem p28 s300
  128. hey guys I want to tune my car on crome but all my friends say that you do not have absolute control
  129. ECU ls 98
  130. 4 pin connector! HELP!
  131. S300 VTEC problems when accelerating, link to .skl and datalog
  132. Kro with twm itb.
  133. What do you think of this timing map?
  134. b20/vtec rev limit
  135. Issues Transferring tuned map to chip (Hondata S200)
  136. Anybody know where to buy autometer sending units, just the units?
  137. Neptune = won't start
  138. Wideband opinions
  139. Alternator plug- motec install
  140. s300 obdo?
  141. Hondata S200 on a P30....have a half dead cylinder #3, another ecu fixes the issue
  142. MY BROKEN 1992 HONDA ACCORD...PLEASE HELP
  143. How do I fix my broken hondata s300?
  144. Difference between s200 and s300
  145. looking for tune
  146. Need a tuning solution Automatic obd2 FI, AEM 30-1911 ???
  147. No throttle response?
  148. hondata s 300 question
  149. DFI GEN 7 tuner??
  150. Apexi VAFC v2 - having an issue
  151. s300 boost control stopped working....wtf
  152. ecu fuse blows
  153. cant register on pgmfi.
  154. Phearable kit-Location for resistor? Can't find r54. Teg...P73
  155. Trouble with Freelog/Hulog
  156. Power dies after 5500rpm, d16 with s300.
  157. help with my car pls asap
  158. How do you guys feel about Motec?
  159. dyno tune in CA?
  160. PR3 ECU
  161. plx and s300 problemsjust bought a plx sm-afr. hooked it up through the eld and ground to the batter
  162. Running VTEC off a shift light? TRUE or FALSE
  163. Shawn Church now tuning in San Diego
  164. burned q31 on a P30
  165. how has type r base map?
  166. Several Questions Regarding Hondata s200 tuning package.
  167. Codes bypassed
  168. What would cause erratic map sensor readings? Bent valve maybe?
  169. s300- did i get everything i need?
  170. s300 with hi/low boost switch and pwm controlled
  171. JDM H22a 345cc PH Injector Latency
  172. looking for 92-95 cx/vx bin that i can use in a p05 dx ecu
  173. AEM S2000 maps
  174. crome tuned issue leans out at 5psi regardless of rpm
  175. s300 problem downloading the tune from ecu
  176. Working on HondataS300 basemap & having problems...
  177. *Request* list of Gm vehicles that carry 3 bar map sensors
  178. Neputune tuner in Austin?
  179. High altitude and tuning the timing map
  180. trouble programming ostrich 2.0
  181. Solid CEL with Ostrich 2.0, wtf?
  182. JDM Integra Base map
  183. "hyperducktuning"
  184. Having issue with HONDATA S300.
  185. Laptop minimum Requirements for tunning?
  186. injector help
  187. greedy e-m or s300?
  188. AEM vs. Hondata S300
  189. Stalling motor when A/C turned on after being tuned w/ aem 3010
  190. apexi power fc
  191. engine dies when running with a/c
  192. hondata s300 usb driver help
  193. messy tables
  194. Copy ecu chip without removing it?
  195. My distributor has to be all the way advanced to get 16* with Hondata S300
  196. 1G B16A - activate VTEC sooner
  197. Engine Light reads P1106 please help
  198. bogging when shifting gears turbo 96 integra , help trouble shoot..
  199. Cannot erase my 27SF512 chip from phearable.net?
  200. phearable
  201. question about crome
  202. AEM 5 bar map with K-manager
  203. AEM Jumper setting question.
  204. Built&boosted B16 Ignition timing for 9:1 CR
  205. S300
  206. crome plugins
  207. K24 turbo (kpro) - ignition timing? - RPM?
  208. p28 on built ls vtec what ecu do I go with
  209. Hondata problem s200
  210. AVCR or Greddy solinoid usable with S300?
  211. HONDA WIRE GURU WANTED: EG, C101, C102, C103, and C304..PINOUTS needed, like yesterday
  212. p30 tuning help!!!
  213. ECU Help....RPMs not working!!
  214. Need a source for learning ECU
  215. obd2b auto b20b ecu
  216. Can you use this to hook up your ECU and datalog with?
  217. civic dx rev limiter
  218. what scan tool?
  219. i feel like this is a noobie question
  220. aem 1010 box eating dizzys and now wont rev past 4200
  221. aem ems?
  222. CTR ecu And California?
  223. zydyne gold secu
  224. CODE 22
  225. s300 Lambda Conversion Table
  226. Map Sensor?????
  227. need help asap!!! check light, car miss fire at 4,000 RPM
  228. Ecu help?
  229. Aem ems and Pioneer headunit?
  230. What is needed to tune my motor? (searched)
  231. Pure-Tuning
  232. Accelerometers / G sensors vs RPM? Also the Gtech, RSM, Power meter thread!
  233. Having issue with LC1 and Crome Pro
  234. ECU A11 - s300 boost solenoid
  235. starting from basics
  236. need basemap for h22
  237. Is there a plugin for Crome Pro to use the ELD input for Wideband??
  238. s300 help
  239. which timing marks do I use on crank when using "set timing" feature on Hondata S300
  240. Can I power my LC1 from the ECU's 12v and ground wires for the 4 wire O2 sensor?
  241. Fuel Sys. No Prime After Chipping
  242. s300 datalogging problem
  243. gm 3 bar in s300
  244. B20 Obd0 swap Q's
  245. lack of vtec..Code 21, wiring intact..wtf?
  246. Best .bin dump for Honda's? I need a couple different ones.
  247. Using both egt and afr to tune?
  248. Can you use Burn1 with Hondata s200?
  249. Secondary o2 sensor wiring.
  250. Am I doing something wrong in CromePro datalogging?
