PDA
View Full Version : Engine Management and Tuning
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 [14] 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32
  1. New xtreme hulog will not connect to laptop
  2. Been out of the scene for a while...
  3. what jumper harness do I need?
  4. Wanted: AEM tuning Course
  5. where to get new pins and crimpping tool
  6. 07 J35a9 in sand rail
  7. Tuning methods VE vs.... the other one?
  8. stock-ish lsv and neptune
  9. 1997 Civic chip?
  10. Hondata Traction Control
  11. Had fuel pump & more replaced and now MPGs way down...HELP
  12. Can a ecu tuned on chrome be re-tuned? (noob)
  13. k20 turbo injecter problem
  14. s300 hondata cpr wont datalog?
  15. Need D16z6 Turbo base map
  16. EcTune... what a joke!
  17. Download crome onto MAC
  18. ITB running map base idling in high load?
  19. Tunerview RD1 and Crome ECU
  20. B20 no power after 7k, No Fuel Pressure Regulator
  21. car will idle but not drive
  22. ecu for my car
  23. Autometer AFR Guage help?
  24. best ecu swap choice
  25. P13 or P72 in h23a vtec?
  26. Still a bit confused on what I need...
  27. Exporting S300 DATALOGS
  28. how much will elevation and weather difference affect a tune?
  29. AE enrichment, spark retardation questions
  30. Who has good basemaps?
  31. dataloggin with crome
  32. Where can I find this AEM harness pins
  33. Read/Writing to AEM EMS out of car?
  34. dyno tune
  35. Help bad injector driver....
  36. Carbon deposit build after WOT question ??
  37. looking for a chip/tune for a B16a engine
  38. new crome 1.6.5
  39. ecu for turbo b20 auto
  40. Thought it was the MAP sensor.
  41. Anyone good at reading crome datalogs?
  42. Base mapping 1000cc injectors...
  43. Just switch to e85 & beggining to tune for it
  44. Tuning Timing...
  45. d16z6... new to the game. wat should I do?
  46. ectune ebc solenoid ecu work?
  47. What do I need to change my timing belt?
  48. P28 chipping issues.
  49. random lean
  50. Suggestions Needed: Is it time for COP for this D16 Turbo build?
  51. Help with ecu suggestion.
  52. Timing troubles...KPRO??
  53. What does this chip do?
  54. P72 Chipping??
  55. Atmospheric Pressure at Part Throttle?
  56. P75 6200rpm fuel cut?ap
  57. Tuning a 94 civic gsr turbo swap
  58. OBD2B->OBD1 harness and EVAP control
  59. wide band reading
  60. 98 civic built lsv with chipped p28 question
  61. anyone know someone who chips ecus??
  62. h22a ecu tuning versus b18c gsr
  63. d15b question
  64. h22a1 hondata basemap?
  65. hondata questions about ROMs
  66. lc1 with db gauge into s300 issues
  67. MAC Solenoid Valve and Neptune...
  68. buying used p28 neptune rtp question?
  69. No Spark, Underdash harness issue. obd1 setup
  70. ANYONE TRIED DASHCOMMAND
  71. Idle/Tune questions
  72. Freelog and data logging the stock ecu
  73. MEFI 5 can it be tuned? any info?
  74. Hondata S100 P72 in D16y8?
  75. *** NEW AEM WIDEBAND/BOOST GAUGE & FAILSAFE GAUGE ALL IN ONE ***
  76. Savannah, ga tuning
  77. B20 with B16 head build... Software questions
  78. Wire jdm b18c into my 96 civic cx first swap need help?
  79. How to check my basemap on SST chip
  80. Do h22s require different tunes?
  81. eg lsi to b18c4 conversion making a b18c4 map for p28?
  82. OBD0 to OBD1 Conversion Blinking Check Engine Light
  83. Am I gettin smoke blown up my ass? :/
  84. Afr reading different
  85. Overheating Protection Help
  86. AE, cold start enrichments, and base fuel enrichments for ectune.
  87. tuning a6/y8 mini-me for gas mileage
  88. Air intake question
  89. JDM$h1t.com ecu chips
  90. Help 1991 CRX
  91. Bisimoto tuning or Church automotoive tuning?
  92. what motor mount do i need for my jdm b16a in my 92 integra?
  93. what size injectors
  94. Help with Hondata CPR kit.
  95. 4-2-1 Header choice for 99 Si
  96. needed: 2002 honda odyssey ecu pinout
  97. Motor swap z6 bottom y8 timing issues
  98. loading a map on a 95 prelude stock ecu
  99. 1040 t1 trigger aem twin no rpm or stat sync
  100. Sourcing a P73 basemap to work off of.
  101. NEED HELP: TPS problem
  102. hondata s300 real or fake (pic)
  103. head gasket changing
  104. what is this component on my ecu?
  105. D16z6 injectors
  106. tunning
  107. B18B BASE VS B20 BASE... BOTH STOCK
  108. Latest CROME PRO release: issues...
  109. Interested in VSS on MS2? Look here.
  110. help with tune
  111. Where is the canister purge valve on a 97 civic dx?
  112. s300/ecu problems.
  113. pr-9 manifold?
  114. Is this P30 ECU chipped?
  115. 98 civic with h22a engine... what ecu?
  116. FPR modification
  117. does AEM wideband sensor fit Innovate MTX-L ?
  118. New NepTune user, some issues
  119. High load idle (column7-9)
  120. F23, 4spd auto w/A54 ecm. NEED pin-out and bare necessity wiring
  121. First Swap, Need a little help
  122. Questions about tuning an auto prelude!!!
  123. wire wideband to hondata s300
  124. Looking to buy wideband-leaning towards Innovate LM-2. Any current users?
  125. Help with CEL 43?
  126. H23a VTEC tuning basemap crome
  127. zc sohc on jrsc 7psi
  128. got back from dyno odd results
  129. s2000,rsx coils connectors
  130. Hondata s300 BOOST by GEAR *refuses* to work =\
  131. Y8 timing tuning
  132. valve adjustment
  133. Car registered in arizona, just got a CA ref ticket
  134. Chipped P28 A/C Air Conditioning, cycles really long!
  135. what laptop are you using?
  136. S300 Maps B16A,CTR Pistons, Pro1 Cams
  137. Air/Fuel ratios like to stay lean after driving for a period of time
  138. needing some help with sol
  139. ej speed limiter
  140. AFR during 2 step/anti lag
  141. AEM intake and throttle body spacer help
  142. will I need a re-tune??
  143. K20 swap guide
  144. what can be used to tune a automatic integra
  145. Odd fuel signal problem?
  146. broken nrg fuel pressure gauge fitting
  147. quick ECU question PW0 with pictures
  148. ECU Help - B18c, P73, Hondata S200
  149. Honda VTEC Engine?
  150. DYNO tunning in missiouri???
  151. Question for Injector Dynamic 1000's
  152. 02 input D14 Capacitor question
  153. Finally got my fuel maps where my car pulls hardest
  154. Look over this map and datalog for b16a2
  155. Determining Data link Connector
  156. Ef9_trymes prologue to tuning(my log) inputs needed!!
  157. Jdm p30 vs chipped p28 with p30 basemap on lsvtec
  158. AEM 1040+ OEM dizzy=no start but autozone junk dizzy will run it just break up????
  159. Wtb hondata or chrome for b16 turbo have new iPad to trade
  160. CromePro, need a minime z6/y7 bin
  161. E85 thread!?!?!?!?!
  162. engine tuning question
  163. Unable to read CEL Code after swap [Data Link Connector problem]
  164. ef si harness
  165. code 23 - obd1 P72 ecu - false knock signal
  166. HELP
  167. need help wiring a map sensor.
  168. Using 8 injectors with hondata s300
  169. TPS keeps going crazy... ugghhh!!!
  170. Stock CTR/ITR basemap for USDM P28 ECU
  171. CROME AUTO ADJUST
  172. Hondata S300 in limp mode?
  173. kpro not letting me upload
  174. NEWS: HONDATA Will Be Offering Traction Control for S300, K-Pro & FlashPro!!!!!
  175. Ek wont go over 4k Rpm's.
  176. Need help with ebc in ectune
  177. honda crx dies when warm
  178. Can't tune real time with Crome Pro
  179. HELP!!! cel's everywhere!!
  180. Kseries coils pin part #
  181. Where to mount crane ps92 coil
  182. hondata for mac
  183. While DataLog/map tracing I idle in the 2-3 columns??
  184. Help: Weird Ignition "Misfire"
  185. Chipped ecu
  186. TPS ground volts question
  187. only able to tune WOT????
  188. B20 in ek
  189. 1995 Civic EG Hatch with B18CR checking for codes, need help.
  190. B series Block
  191. any chance somone has Power enterprise fop feed 850cc dead times??
  192. How to Fix Solid CEL Main Relay Issues
  193. Crome pro gold bin not data logging or cell tracing.
  194. LC-1 serial adapter not being found?
  195. Questions about the ECU#: 37820-P29-000 JDM ..!!
  196. LC-1 DB guage wiring question.
  197. Fueltech EMS
  198. turbo d16 5 speed w/auto ECU???
  199. eCtune License
  200. pr4 ecu trouble codes
  201. ECU Question (picture) p75-a01
  202. AEM EMS + PA Emissions
  203. Vtec not engaging ( ectune)
  204. Trying to lower boost from 14 psi to 10 psi on s300
  205. Best chip for socketed P28 ECU for B16A JDM engine
  206. Need Help, LS/B20 Turbo
  207. Chipping an Automatic?
  208. MD Who does eprom chip tunes
  209. need wideband o2 sensor?
  210. RomEditor V3 wanted
  211. New to Honda tuning
  212. Heat wrapping my Mugen header.
  213. p30 ecu tuneable?
  214. Car continues to go full rich above 6k rpm
  215. 92 VX Hondata?
  216. Manual chipped p28 throwing code 19.. Yes it's a MANUAL ecu
  217. Need help! harness name
  218. knock sensor & crankshaft position sensor..?
  219. p28 ecu and tunning questions
  220. b16 ecu help
  221. New injectors..Retune??
  222. New motor build, need help with initial idle
  223. EGR...I can't have one 3-stage vtec
  224. 2004 Manual Engine LED light not coming on
  225. Central California Tuners?
  226. crome pro Gold base fuel multi???
  227. VAFC on a Auto y8 Mini Me? Any first hand experience out there?
  228. jun type r ecu p73
  229. Sequential Fire vs Batch Fire
  230. Reputable tuner near KY,IN,OH
  231. Solid CEL on every map besides p28
  232. Need tuning help s300
  233. neptune vs. crome pro
  234. Tune changes when the headlight are turned on
  235. EVAP Purge Valve & STFT
  236. strange TPS issue
  237. Crome 1.6.3 with freelog?
  238. vss/2step question
  239. chip burner?
  240. Crome & hulog no longer datalogging
  241. 14.9-15.1 too lean?
  242. tuners in new england???
  243. Hondata Ventuli
  244. Every Map Going Super Rich No Matter What The Settings
  245. having a lil trouble here
  246. Help. ectune licensed ordered, trying to connect.
  247. C27 valves
  248. LOOKIN FOR ROD BOLT TORQUE SPECS
  249. indiana tuners or speed shops?
  250. 12v Switched Source, engine compartment, wiring LC-1
