- B16 Stock 7psi boosted MAP needed
- P28 on Non-Vtec?
- Pros and Cons of CROME PRO...
- Distributor mess
- LS EK - auto power..?
- TURBO BUILD WHATS MISSING.
- in need of a stock CRX SI tune .bin file
- Input OEM or Flowtest Rating for Injector Size?
- dsm injector offsets in crome which is black tops and which is blue tops?
- help me out im in final stage
- About Hondata SManager: Setting Idle
- alternate ways to sync timing - AEM
- Chip for a 99 Si? Stock.
- datalogging cables
- wiring harness issues 98 civic, LS swap
- Honda Civic Turbo
- Wiring of LC-1
- help with neptune
- p28 chip i.d. help
- Official S300 stock P2P D16y8 calibration?
- ECU malfunction code
- Help: My integra boggs on acceleration..?
- Need fuel injector help asap
- Sort of a newb to the tuning world, getting ready to buy my own software: Ectune Pro
- JDM H23 VTEC (Blue Top) Dyno Results
- Reading an article from Hondata about tuning basics
- Hondata s100 launch control
- Prelude wont fire!
- obd2a to obd1 jumper harness
- P1300 Random Misfire Code - No CEL?
- what ecu is this?
- What will be my best set up for two step?
- Can't idle on crome pro
- Aem version 2 ems??
- Northeast Tuners??
- Good Reading For Tuners - Updated Link
- Ignition break-up
- Hayame Catback exhaust
- Toyota 2AZFE AEM Issues
- obd0-1 conversion i want to ad an engine light but how?
- Dyno
- Idling Issues
- OL idle is perfect, CL terrible?
- PLZ HELP ME WITH THE distributor
- why did this piston melt?
- Intake tuning
- PLX A/F gauge differs from Dyno readout
- Dyno Tune??
- P2P c12 what sensors? dx ex minime
- Innovative MTX-L
- k24a2 ecu without the drive by wire
- Crome tuner in Phoenix
- Tuning question
- Lack of power :/
- What would cause injectors not to pulse
- Integra turbo high boost 32 PSI which Headgasket??????
- ID1000s and S300 running super rich
- bouncing afr on a bone stock set up??
- do we need to tuning if adding cai and exhaust?
- 2.5 or 3 bar sencor ??
- p72 chipped ecu
- b16 idle prob and no vtech help!
- Pocket Programmer 2 Settings
- What Coils to Use With Hondata CPR???
- tuning apexi vtec controller
- idle setting
- eCtune's web site ?
- H22A/F22B PCM?
- Fuel offsets
- Turbo aem fic maps... Help!!
- Odyssey Idle Air Management Issues
- Newbie needs help
- s300 and three stage vtec questions
- poll: 2012 best tuning software
- OBD2B chassis, OBD1 GSR motor and ECU
- Tuning tutorials video how to's
- Help me find ECU diagram
- Advancing Ignition Timing after ECU tuning
- few crome Pro questions
- DC2R ECU, Immoboliser and Control Unit
- RD-1 questions.....
- I need help. Tuning/injector error.
- S300 V.2, A2W and water temp compensation
- WHERE CAN I GET A GOOD DEAL ON CROME DEALER LICENSE?
- Looking for a AEM tuner around Memphis, TN
- B18B Leaking oil where VTEC solenoid WOULD go
- Anyone having problems with Crome and the demon?
- Which ecu do I need for B18c7
- Resistor box wired up, but not connected?
- obd1 tuning for boost setup
- p28 or p72?
- Flushing and replacing the fluids in my car?
- Flushing and replacing all fluids in my car
- B18A1 Issues
- Hondata S300 not stayin live
- Tuner view 2 need help please.
- d16y8 auto chipped ECU?
- AEM short ram intake?
- Engine swap , b18b1 on a 92 honda civic si hb
- CEL and ABS lights when plugging in OBD1 ECU
- cant get engine code.
- S300 wont log
- s300 in auto p28
- AEM Series 2 - low-cam and high cam fuel
- B18c4 Starting problems help
- AEM ems fuel injector question?
- S300 Datalogs
- NEED Help! Choosing injectors B16a3 DOHC DelSol
- Help
- turbo sohc
- rpm stuck!
- s300 Vss Issue.
- learning to tune
- PLX Wideband Going Nuts!
- tuning newb in need of advice
- Possible Wireing problems for hondata
- B16A second gen. Help me out with a map to run with
- Swap Issue - A/F Question
- T1 Ultimate Ignition Kit:Looking for Reviews
- Car Wont Pass 4k Rpms...
- Vtec Oil problem.
- water/meth fail safes
- s300 help
- Generic tuning ?'s from a first timer
- S300 no boost option on boosted car.
- VSS in S300 reading low?
- What's needed to use chrome
- Need f22b tuning help.
- P28 chipped with S200
- P72 tuning quiestions
- Weird Issue on Neptune RTP
- B16/B18 hybrid N/A run-in map - S300 (request)
- Trying to understand low/high impedance
- Need help passing state inspection
- 2 Step Launch/Launch Control?
- aem ems 1060 coil driver
- d15b7 piston rings Help
- engine swap troubles
- custom wire harness?
- OBD1 Cam/Crank Pins
- car wont start code 6 issue
- VTEC pressure switch trick
- S300 Boost by gear help
- Propane not injected still use cop and ctrls.
- Need a quick Look at this .bin file
- Force open loop on odb1
- biggest injectors on a chipped ecu
- Hondata s300 and AEM injector driver questions
- hondata s300 full throttle shift help
- need help on vafc pinout for a j swapped 95 civic
- aem 30-6040 map for stock d16z6
- Help: AEM 30-1000/Nitrous stops working after key off
- Need recommendations on tuning a jdm gsr
- How do I reflash my chipped p28?
- Crome 1.6.2 Expired
- car misfires/ stutters when horn pressed Wtf?
- Turbo GSR Basemap S300
- AEM tech support
- Chipped p28 reverting to stock tune?
- O2 sensor replacement with wideband
- 95 Honda Civic and Nissan Steaga
- dataloging using demon and crome pro
- FIC easy tune box !!
- What do you think about this map??
- obd2a d16y7 tuning help
- DES MOINES TUNING SHOP
- CROME Pro Can't log TPS voltage
- I need a new b20 map for my pm6
- installtion M&W PRO10 ignition
- How Much is a Non-VTEC D15 with 141K Miles?
- S200 Need "magic" hondata cord?
- S300/code 9 issue!
- what do i need for CROME TUNING!?
- What AEM ecu is that?
- UEGO install S300- what settings need changed?
- Hondata S300 Version 2
- Aem ems question
- Chiped p28 problem
- Integra LS + P06 ECU - How to set up basemap in Crome?
- 4 egt's vs 4 widebands high boost turbo setup
- Bad Hulog?
- Why is OBD2 so evil for tuning?
- what's a good Honda diagnostic tool?
- Tuning with vafc and aem wideband airfuel gauge?
- s300 tps parameters help for itb
- all in the tune?
- obd2a tuning options?
- 6 Inputs for Voltage/Lambda Conversion Table (s300)
- Twin Boost Solenoid's
- more whp
- methanol injection ignition map shape (boosted application)
- Crome timing/map conflict??
- does anyone know what chip socket this is for?
- GSR headers issue
- cam signal, ecu side?
- Universal AEM EMS A/C prob in 1995 civic
- Advice on system with drivablity and OBD2 emissons concerns
- B16 turbo del sol.Injectors? What kind
- P28 solid CEL but runs perfect?
- Can I tune this ecu for turbo?
- LS rods + pm6 pistons in ZC'dohc, a few questions
- CROME v1.6.2 Complete User's Manual Input
- AEM COP Conversion
- Aem Ems Help...
- Some OBD0 questions...
- e85 cold start
- learn how to tune
- Autronic SM2 and MSD Billet Distributor
- Hondata CPR not synching up
- Convertions
- Ebay Knock sensors
- s300 not showing up when plugged into laptop
- hondata s300 tuning ugnition tables
- hondata s300 problem the engine not start help
- making a wire harness...does lengthening wires affect performance
- Voltage dropping at idle under load
- bay area tuners
- I think some fool has used the red key
- chip burning, will this work?
- obd0 to obd1 + o2 sensor
- AEM UEGO was working now its not
- Socal tuners?
- Target AFR under WOT for N/A
- How much hp will a gsr block hold? Do you need the plastic timing cover for timing?
- help with block rebuild
- Turboedit solid CEL
- possible crome iacv issue?
- h22a dyno #'s tuned by Dardantuning
- EManage options harness questions.
- B20B/GSR head... ECU PowerFc Knock count
- Z6 or y8 intake mani of d16y7?
- Tuning Crome P30
- Stock p28 running a b16
- hondata s300 rev limit
- p28 ECU help!
- Coolant temp sensors...
- partial throttle tuning help
- neptune to rom
- Switched gm3bar to stock map sensor Help
- tuning help
- 2006 honda pilot p2647 code
- P28 Worth it?
- Tachometer and ECU disagree
- "HIGH CAM MAP" on Crome pro.
- Im in NEED OF A TUNE
- Quick Innovative LC-1 Wiring Help
- problem with " moving idle speed "
- S200 Question
- Ectune
