- backfires when trying to start after rebuild
- need help!
- fuel cutout issue
- cannot raise boost with hondata s300?
- have a miss...
- strange log please look
- GSR OBDII P72 Civic
- VERY lean just off idle to 1800rpm...
- p28 ecu chipped, fuel pump not turnjng on
- need help w/ cel code 4 ckp sensor
- burning 2l of oil every 8 months
- Evap setup/delete
- 99 honda accord issues
- LA people: Jerry or Bubba Built Tuning?
- Another CPR help
- CROME - Could not load file (Gold) Bin / Ostrich
- fuel delivery problem
- HALTECH TUNERS IN NKY/CINCI AREAS
- 02 sensor showing 0.0 voltage in Smanager?
- 1990 honda crx tdo2 to tdo1u distributor swap
- Quick question about basemap (Help!!!)
- F20B Idle Problem 3000rpm
- Fuel injectors going bad?
- Crome: (Missing) Pre-loaded Injector Battery Offsets (for non-stock injectors)
- NEW ECU - fuel pump stays on
- Any help with my gsr
- Not sure if I need re-tuned
- im comfused? ecu p72
- Can someone give me info about this ECU?
- 96accord only spark to 1 cyl?
- What ECU is needed for a LS turbo
- Question About Aem Twinfire
- Anyone use Megasquirt
- 6500rpm Misfire - eCtune
- Swapped ek hatch ac problem
- E85 still usable after sitting up?
- Help with a 1986 Integra with D16A1
- Changed dizzy, cant set base timing to 16
- Engine harness help.
- dyno tune on crome
- Random No Start VERY RANDOM
- Innovative MTX-L with Crome Pro 1.6.5 - wideband vs datalogs - offset?
- Aem ems 1 idle and misfiring problem
- Neptune issues
- populating the air/fuel table
- fuel economy
- Help tuning my jdm b16a
- ecu p73 can with old pfc fcon?
- Best ECU & fuel map for f20b (H/F2B) eg swap?
- B18C1 with CTR Type Cam issue
- Source for Extended OBD II codes?
- Chipped ECU question/suggestions.. P28..
- CTR/ITR Cams GSR Manifold S300 calibration recommendation.
- Chip p28??
- chip suddenly went bad.
- CROME GOLD TIP-IN setting?
- What should I be expecting with new basemap/chip?
- Anyone heard of a "ghost" tune??
- JDM b16a no vtech
- Few AEM EMS2 questions
- obd1 pinout shocktower
- AEM V2 Idle target base not responding
- Failed smog check need help!
- HELP F20B accord with battery drain
- AEM FIC compared to Neptune
- must fully retard distributor to sync with computer. doesnt seem right
- adjusting the fuel tables right way?
- b18c question
- Look what happened to my ECU!!
- Building a Single Cam
- Crome ECU Datalogging fix
- p06 Ecu Boosted Accord
- P28 resistors missing???
- buying new ecu. suggestions?
- chipped ecu problems?
- need input for gas tank problems.
- Boosted B18B1 Fuel Problems!
- Need help with my Sol! :'(
- S300 Password problem...
- B16a Hondata S300v2 keeps cutting out at 2K?
- ls-v stroker need help with basemap
- ECU Compatibility Chart
- DEFI BF series gauges.
- main relay clicking s300 sat for while...weird
- Tune Computer after short ram intake install?
- chipped P28 bad?
- ECU with no VSS
- Stock MAP senor, idleing, Wideband questions...
- Deciding on which tuner to return to?
- f20b eg
- AEM EMS obd2a - obd2b
- MSD 6al with Crome Pro
- AEM Coil Output ?
- B20 non vtec to vtec conversion? parts needed?
- Code 11 on obd1 ecu via Crome
- 12.5:1 84mm B18C lean then rich on CROME?
- Any experienced freelance tuners...
- Anyone use EFI live?
- Jdm b16 2nd gen
- Ignition????
- Turbo D17 wont start HELP
- how much did you pay , to fix your oil leak ?
- Help getting me going...
- b18 in eg hatch ecu quetions
- Stone gasket
- RPM based timing compensation??
- Wiring harness?!?
- O2 sensor/CYP sensor killing my gas!!
- E-manage Blue EF d16z6
- B20 vtec
- 2step question
- ecu id chipped or socketed
- Rywire sub harness help!!!!!
- TPS cutoff at 2500 rpm while idle
- Bad/broken IAT cause rich AFR?
- has anyone had issues with rywire ecu harnesses?
- AEM Series 2 base map
- Overheating after street tune
- Any thoughts on this new tool? (for cylinder heads)
- Issue with new basemap/ecu
- faulty hondata 4bar map
- AEM v1 Hesistation (Video attached)
- Ok to just use fuel cut for rev limits and anti-lag
- Ctr dynosports in modesto/ quick question
- map sensor wideband question
- 91 honda civic wont start
- Hondata Help!! Weird issue...
- Is 68mm T/B too big for this set up?
- B18C blowing black smoke at high rpm's
- T1 cam trigg, aem 1050 box tach reading half???
- A few questions about analog inputs/outputs...
- aem or s300?
- 95 civic with constant revving engine
- hondata s100 ??
- map sensor questions
- CROME PRO not logging a/f
- Hondata BBG
- Timing numbers for E85?
- CEL ON S300 DTC 9 CYLINDER SENSROR
- wot cel then limp mode Help anyone
- adjusting cold start and hot restart and idle
- results of my first tune need input
- quality guages to purchase????
- Hot Start Heatsoak - methods to reduce?
- identify these pieces, pics
- Anyone know anything about ABS computers?
- OBD2a ECU in OBD2b car..... Need some help por favor
- Vtech inop
- Best wideband to use..
- s300 or ectune for me?
- i need help with turbos??
- Chipped p28 on b18c?
- AEM and Injector Timing.
- Upgraded to newest version of Crome pro - datalogging broken:
- tunning a b18c
- hondata s300 ECT reading vs other softwares?
- straight pipe magnaflow exhaust with dc headers. good or bad?
- b16 swap issues
- worth tuning?
- Best upgrade for the price?
- Help please - Is my AEM EMS Fried???
- Tune
- where to go for a tune near wisconsin
- D16y8 questions
- 90 honda civic dx is my cap and rotor bad? getting spark at coil and igniter but not
- af ratio leans out after warm start
- AEM F/IC with 00 Prelude
- Possible to tune for MPG?
- cant shake this detonation.
- Compression Test: 20 Psi below cylinder #3
- Can someone please help me with electrical testing on my 90 civic dx? fuel pump issue
- Phearable.net mailing address
- 95 civic ex timing belt
- aem eugo/crome
- Map Sensor Question
- cam degree -10in +10ex
- No boost control, just spikes?
- looking to take out AC in my 93 integra. where to start? also other useless wiring.
- megasquirt d16z6 HELP :(
- Gsr tune? STOCK motor
- 99 civic dx sputtering, maybe o2 sensor? HELP
- neptune rtp demon, always reads im in 5th gear
- s300 led blinks
- need some help
- Does anyone know the part number for plx dm6 wideband sensor?
- P28 with B18C1 issue
- aem ems 30-6030 vtc k20
- Bosch knock sensor
- obd2b-obd1 conv. neptune ?s
- Newest S300 Beta Version Updates V2.2.5: Gear based revlimit and shiftlight
- HELP: IQ3 dash and AEM series2 problems
- Tuning program
- s300 help, high iddle, ses, safe mode
- 8 month ongoing issue with b18b1, help appreciated
- Depinning A22 when running AEM??
- freelog data logging/crome
- 98 civic 37820-p2e-326
- 94 honda civic dx d15b7
- Ectune Demon Setup file
- Problems/questions with my AEM wideband
- Hondata s300 BBG
- 1998 civic lx vss problem? What should I do to fix this?
- check engine light then no start
- p72 ecu obd1
- eManage Ultimate with AEM TwinFire CDI not triggering
- wideband/ecu
- D16z6 Fully Built Tuning Help
- help with neptune rtp demon, set up 2 step
- Fuel pressure data log data question
- S300J Boost control
- #6 cylinder missfires
- Having issues with innovate MTX-L
- Dyno tuning Portland Oregon
- D15 piston swap/upgrade?
- 4 channel pyrometer controller
- Did tuner screw up my car? Bad idle after tune.
- quick question about s300
- 2006 Jazz running rough
- Dyno Tuned GSR - 187whp on s300 (tune attached)
- 05-06 kpro on a 02 rsx????
- Tune never runs the same
- ATI Damper in Reference to Honda Pulley
- HELP!! ecu chipped?
- crome plugins tranny selection
- LC-1 Wideband install question
- immobiliser swap.
- Differences in JDM ITR ecu's? p73-003, 013, 023
- B16 + twm itb's= what ems?
- ECU/Engine Trouble! Help!
- removed radio/PCM fuse, now won't start
- h22 accord auto2manual ecu problem
- Motec M800 and stock distributor, need input
- K24 turbo hondata kpro limp mode????
- LC-1 Wiring Confirmation (s300)
- Neptune RTP?
- 00 gsr swap in 96 ls integra not running right
- HELP!!! burt part in ecu
- need help getting vtec to run off ecu in racecar
- need practical advice in tuning
- piggybacks
- Need help
- Lost on tunning
- need help on tip-in tuning from you guys!
- 94 civic hatch swap..what throttle cable do I need
- Is a tune needed when switching brands of 1000cc injectors?
- High Imped. to Low Imped.
- Help with 2 step?
- Neptune Tuning with no VSS
- S300 NEED help with wideband analog input, all i see in volts
- Best A/F meter for the money
