Alignment issues...?
For all the coilovers set up'ers out there, do you guys get your car aligned everytime you adjust your height? I know that when you adjust your height the toe will change. How do you guys cope with this? I know most of the people don't get their toe aligned after adjusting their car.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98BabiGs-T »</TD></TR><TR><TD CLASS="quote">For all the coilovers set up'ers out there, do you guys get your car aligned everytime you adjust your height? I know that when you adjust your height the toe will change. How do you guys cope with this? I know most of the people don't get their toe aligned after adjusting their car.</TD></TR></TABLE>
The trick is to get it at the height you want it, and then leave it alone. I know it sucks but thats how it is. Then next time you do suspension work (that will require an alignment), you can change it again...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by garrettej8 »</TD></TR><TR><TD CLASS="quote">I had omni full coilovers put on and the alignment was perfect. I lowered the front down another inch after the install and the alignment is still perfect.</TD></TR></TABLE>
And this is after you had it up on a rack and checked by the alignment tech?
Or are you just eyeballing it?
it may drive straight but depending on how low u went the suspension changes affected youre toe by atleast 50 degrees and youre camber by approx. 1.5 degrees.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by liquid:cooled »</TD></TR><TR><TD CLASS="quote">affected youre toe by atleast 50 degrees</TD></TR></TABLE>
50 degrees of toe? Wow. He must be driving sideways.
jxhxb
Suspension & Brakes
Jan 9, 2009 10:51 AM
EL'ation
Sep 28, 2002 01:11 PM
