Suspension Q please help.
found these struts, shocks, and coilovers set here on ebay...just needing opinions see if their any good or whatnot thanks.
http://cgi.ebay.com/ebaymotors...wItem
and will i need a camber kit?
i have 17's and i plan on lowering it 2.7 in the front..and 2.9 in the rear.
thanks.
thanks.
Re: Suspension Q please help. (vtec99ej)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec99ej »</TD></TR><TR><TD CLASS="quote">found these struts, shocks, and coilovers set here on ebay...just needing opinions see if their any good or whatnot thanks.
A quick search found these ...
https://honda-tech.com/zerothread?id=1534130
https://honda-tech.com/zerothread?id=1188168
https://honda-tech.com/zerothread?id=1803371
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec99ej »</TD></TR><TR><TD CLASS="quote">and will i need a camber kit?
thanks.
that's probably too low for that kit, and most others. Whether or not you need a camber kit or not depends on a few factors. the short answer is probably not, as long as you get a good alignment done (i.e. toe settings set to zero)
thanks.
