00 integra suspension set up for heavy audio equipment?
hello. i have the 2000ls integra i got the pioneer primer 3000 watt speakers which are going to be installed and two amps to run all interior and rear pioneers 12's
with all this extra weight am i going to have to do anything to suspension?
Re: 00 integra suspension set up for heavy audio equipment?
what shocks and spring set up recommended for the 00 integra i want to do a 1.5 - 1.75 in drop give or take maybe more in front than rear due to weight of sount system
Stagg SHS 2 Rear Shocks Struts Acura Integra 94 95 96 97 98 99 00 01 | eBay
Stagg SHS 2 Front Shocks Acura Integra 94 95 96 97 98 99 00 01 | eBay
here are two links. do you think these will be good enough for my suspension set up? or junk ?
Cool Cool Island Breezes. BOY-EE
Buy tein street basis or street advance coilovers from thmotorsports. Raise the back up higher to account for more weight.
ok i looked at the tein u suggested i like them what would i do for the top buy new top hat? or use what i have stock? is this all needed to lower 1.5 - 1.75 inches. i do not want my wheels all cocked in or out either i just want them like oem
200-300 LB is significant.
You'd re-use your OEM top hats with the Teins, OP. The damper adjustments on the street advance may come in handy to you. I believe they're only like $75 more than the SB's.
I know this is an old thread but I never got the coilovers, I replaced front shocks with OEM replacements. I plan to do the same with rear, but is there a spacer or something I can put on top of the shock to raise the rear a bit to prevent the sagging from my woofers. Thanks
