Rear Control Arms Fitment
I have the Skunk2 Rear Control Arms ( 542-05-0115 ) for my Civic coupe 2000.
Will 94-01 Integra Rear Trailing Arms fit onto it? (Rear brake disc conversion)
Ek Forever y0!
Re: Rear Control Arms Fitment
I'm using rear integra trailing arms. You need to swap over your civic toe adjustment thingies, and use an LCA for your civic. So yes, the skunk2 control arms will work fine.
The Grumpiest
5 minutes of searching. it's not like no one has ever asked these questions before.
DA trailing arms work, the bushings are different in terms of the outer diameter of the bushing, all it means is that you have to use '90 - '93 Integra trailing arm bushings in '90 - '93 Integra trailing arms regardless of the vehicle they are going on.
So far as I know DA calipers are the same as DC calipers so you shouldn't have any trouble swapping them over.
deftones0817
09-01-2002 02:28 PM
