Suspension & Brakes Theory, alignment, spring rates....
Pics of my MILLED 25T caliper brackets, milled to much?
Old 08-29-2013, 12:49 PM
KevinEF7's Avatar
Default Pics of my MILLED 25T caliper brackets, milled to much?
hey guys, I found a good deal on a set of Integra Type-R brand new oem calipers, aswell as a set of 25T brackets, they came pre-milled for a big brake upgrade. But I almost think TO much was milled.
Can anyone confirm my measurements are correct for removing the 3.2mm off of the bracket? Or how incorrect they are.
Im hoping someone has a brake bracket laying around, either stock or already milled, and can put a caliper on the knuckle mounting pad as I did in the picture so I can figure out how much has been milled
Thanks alot guys!
Old 08-29-2013, 03:11 PM
speedjunkie_g35's Avatar
Location: Pensacola, FL and every Court House in Louisiana
Default Re: Pics of my MILLED 25T caliper brackets, milled to much?
What knuckle are you using ad what car? Crx?
Old 08-29-2013, 11:42 PM
KevinEF7's Avatar
Its the stock Crx Si knuckle, 90-91 civic ex 10.3" rotor, type-r calipers and 25t brackets
Old 08-30-2013, 07:36 AM
If I remember correctly you are suppose to remove 3mm so 3.2 should be ok. Have you tried mounting them up?
Old 08-30-2013, 12:04 PM
KevinEF7's Avatar
Im pretty sure MORE than 3.2MM was milled, thats why Im trying to find a measurement of a correctly milled, or completely stock bracket, so I can see how much was milled
No I havent tried bolting it up yet, still waitin on the brembo rotors
Old 08-30-2013, 05:58 PM
I will try and go measure mine. I have type r calipers waiting to go on my car and they are not milled. I am running Mini Cooper rotors so I shouldn't have to deal with that.
Old 08-30-2013, 06:01 PM
Nvm I have 23t brackets.
Old 08-30-2013, 06:03 PM
What is the thickness of the lip on the mounting side of the bracket?
Old 08-30-2013, 10:50 PM
KevinEF7's Avatar
I'll take 23t measurements, just the area I have the caliper on
When you say the lip on the mounting side of the bracket, I think of exactly what I pictured, so im not sure what your asking for
Old 09-01-2013, 01:36 PM
KevinEF7's Avatar
No its not clear, the depth of that side doesnt start flush.
I did figure out that they were milled 5mm, so I will be making some 2mm shims
Old 09-01-2013, 01:46 PM
KevinEF7's Avatar
This is the mesaurement another member very thankfully sent to me. Shows a difference on .200" or 5.08mm
Old 09-01-2013, 03:37 PM
Calif_Kid's Avatar
I was looking for some other info, and spotted the thread https://honda-tech.com/forums/road-racing-autocross-time-attack-19/machining-itr-calipers-2874785/ which has a little more info. - Jim
John M
04-05-2014 05:02 PM
endlesswinterco
Suspension & Brakes
05-15-2008 07:13 AM
HondaBurger
Welding / Fabrication
03-05-2007 05:45 AM
Understeer
12-15-2003 10:26 PM
philly-O
04-21-2003 09:15 AM
Quick Reply: Pics of my MILLED 25T caliper brackets, milled to much?
