Suspension & Brakes Theory, alignment, spring rates....
suspension problem?
Old Jun 4, 2006 | 05:57 PM
ketchup!'s Avatar
Default suspension problem?
Well my car is lowered around 2.0" on ksport coilovers. Anyway whenever i make a hard left or right at a good speed I hear something scrape. It almost sounds like my front lip is scraping but I don't think I'm low enough for it to scrape on turns. Any idea of what it could be? I was thinking its my wheels rubbing in my wheel wheals. This problem never happened when I had my steelies on. Please help
Old Jun 4, 2006 | 06:50 PM
PIC Performance's Avatar
Default Re: suspension problem? (KETCHUP_MAN)
Well your steelies were probably not as wide as what you are running now. Remove the front wheels and check for scrape/rub marks in the fender wells (obviously). Also check your fenders, maybe you are rubbing up there.
if your lip is scraping, you'd see scrape marks. That *would* be the first place I'd look.
Old Jun 5, 2006 | 12:25 AM
dreww..'s Avatar
Its most likely your plastic fender lining rubbing.
Do you have mudflaps? It could be something as simple as those scraping off the ground too.
ththinh82
Suspension & Brakes
13
Nov 19, 2012 11:22 PM
88 EF Hatch
Suspension & Brakes
Aug 26, 2009 07:06 PM
mikeycivic
Suspension & Brakes
58
Aug 9, 2008 12:24 PM
broncoman74
28
Nov 10, 2003 10:55 AM
seiya
Jun 19, 2002 01:54 PM
