Suspension & Brakes Theory, alignment, spring rates....
GC Spring rate conversion?
Old May 19, 2006 | 10:11 PM
Flava's Avatar
Default GC Spring rate conversion?
Can anyone help me out with converting these? First one is GC180.64.44 then GC200.64.58.
Old May 19, 2006 | 10:22 PM
Understeer's Avatar
Default Re: GC Spring rate conversion? (dingy)
7" free length, 2.5" ID, 250lbs/in
8" free length, 2.5" ID, 330lbs/in
Old May 19, 2006 | 10:24 PM
Flava's Avatar
Default Re: GC Spring rate conversion? (Understeer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Understeer &raquo;</TD></TR><TR><TD CLASS="quote">7" free length, 2.5" ID, 250lbs/in
8" free length, 2.5" ID, 330lbs/in</TD></TR></TABLE>
Thanks
Oh and for furture reference, how did you convert it?
Old May 19, 2006 | 10:29 PM
Understeer's Avatar
180.64.44
180/0.254=700
64/0.254=250
44x5.7=250
Old May 19, 2006 | 10:31 PM
Flava's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Understeer &raquo;</TD></TR><TR><TD CLASS="quote">180.64.44
180/0.254=700
64/0.254=250
44x5.7=250</TD></TR></TABLE>
Awesome thanks
Old May 19, 2006 | 11:14 PM
Tyson's Avatar
http://www.norcalcrx.org/tyson/coilover.html#05
How do I tell what my spring rates are?
Ground Control sells Eibach Race Springs (ERS) which are labelled by 3 different values in the following convention: length . diameter . spring rate. However, ERS will come labelled in either Metric (mm.mm.N/m) or English (inchx100.inchx100.lbs/inch) units. 180.64.61 is the same thing as 700.250.350. The conversion from Metric to English is (/.254, /.254, x5.7) "/" means "divide by", "x" means "multiply by".
DFW
Suspension & Brakes
Jun 22, 2008 04:55 PM
N20civicB18
Suspension & Brakes
Feb 22, 2006 04:44 PM
Motorgroove
Aug 10, 2004 08:40 AM
