steering knuckle
Subscribe
Aug 31, 2007 | 09:10 PM
trying like hell to get the lower control arm, and steering knuckle apart...don't have a puller,tried to put a block w/ plywood under loosened bolt then lower the car to get them apart.no love
Reply 0
Aug 31, 2007 | 09:57 PM
Are you trying to seperate the lower arm ball joint from the knuckle? Try one of these:
It's a ball joint or tie-rod lifter. I used it just last Weds. as a matter of fact to split all 3 ball joints to the knuckle. Maybe a half hour per a side if that. Cake. Never tried this but you can...
https://honda-tech.com/zero...age=1
Reply 0
Sep 1, 2007 | 08:32 PM
Re: (Guam_CiviC619)
i take the nut on bottom off all the way and put it back on just a few threads, turn knuckle all the way and hit LOWER CONTROL ARM only with a hammer, the impact will pop it loose, hitting up on ball joint will just damage the ball joint, usually use a pretty large hammer like a 3 pound sledge. hope this helps
Reply 0
Sep 1, 2007 | 09:22 PM
Re: (civicsix2)
https://honda-tech.com/zerothread/1912773
Reply 0
Sep 1, 2007 | 10:29 PM
Re: (Tyson)
bought one o' dem $9 dollar wakker doodles(forked), worked BUT F_UPED THE DERN CUP. Now i have to loosen the spring clip_easy- i broke that 2 par 4 the course.
Problem now is that bearing wont lose old rotor. everything(all bolts)loose, on ground, got mad whacked it one or several good ones with a hand sledge(back side)no love
ex jack leg mechanic friend of mine told me to tap around the perimeter w/ a punch,maby 30 min.?
W>T>F
Reply 0
Sep 1, 2007 | 10:32 PM
Re: (crazykarlnow)
don't want to ruin bearing spins great(like new 230,00+)
gotta git er dun
goin to WV
Reply 0
Subscribe
