Suspension & Brakes Theory, alignment, spring rates....
Spring Rate
Old Aug 21, 2007 | 08:55 AM
ware's Avatar
Default Spring Rate
i dont know my spring rate on my coilovers, but they have this number printed on them
0700.2.50.008 .. any help?
Old Aug 21, 2007 | 04:03 PM
PIC Performance's Avatar
Default Re: Spring Rate (ware)
looks like 7" free length, 2.5" inner diameter, 8kg/mm springs. Who's coilovers?
Old Aug 21, 2007 | 07:19 PM
ware's Avatar
Default Re: Spring Rate (PIC Performance)
well i they are my coilovers.. lol .. i don't know the manufacture.. they don't have nothing but those numbers on them and i bought the car with them on like that. they're purple though
Old Aug 21, 2007 | 11:53 PM
AMR Engineering's Avatar
Yah, agreed, most likely a 8k spring which is about 450lbs. That is just a number off the top of my head. Don't quote me on that.
Old Aug 22, 2007 | 05:32 AM
gabebauman's Avatar
Default Re: Spring Rate (AMR Engineering)
Ah...that's it...8k.
8x55.88=447
Are all four springs that rate?
My old skunk2 coilovers were 447F/335R. 8K/6K
Old Aug 22, 2007 | 06:04 AM
b20beast978's Avatar
wo would the the stiffer spring 8k go in the front or the rear?
Old Aug 22, 2007 | 06:40 AM
gabebauman's Avatar
Default Re: (b20beast978)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ware &raquo;</TD></TR><TR><TD CLASS="quote">
and how does that ride?
EDIT: my fronts are 559 and rear is 447.. i think, are my springs reversed?</TD></TR></TABLE>
So you have 10kF/8kR. That is a really stiff setup for street/daily driving. My old Skunk2 setup was 8k/6k = 447F/335R with KYB AGX shocks...and it was a tad rough.
But now with my Koni/GC setup...450F/400R...the shocks actually dampen the springs so my ride is a lot nicer.
It's typical to have the higher rate in the front due to the increased weight of the engine up there. Road Racers and Autocrossers tend to use the higher rate in the rear for better rotation. It's best to stay with a higher rate in the front if you're not racing.
Them stock shocks are never gonna be able to dampen them stiff springs. Off the shelf Koni Yellows are rated up to 600lbs before they need to be re-valved to accommodate a stiffer springrate.
Old Aug 22, 2007 | 06:15 PM
ware's Avatar
Default Re: (gabebauman)
i have .008 in the rear and .010 in the front.. so would some new shocks help out my ride quality?
Old Aug 23, 2007 | 05:51 AM
gabebauman's Avatar
Default Re: (ware)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ware &raquo;</TD></TR><TR><TD CLASS="quote">i have .008 in the rear and .010 in the front.. so would some new shocks help out my ride quality?</TD></TR></TABLE>
Yeah...get some Koni Yellas
http://www.hondamarketplace.co...35513
Old Aug 23, 2007 | 07:57 AM
excivicboy96's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman &raquo;</TD></TR><TR><TD CLASS="quote">
Them stock shocks are never gonna be able to dampen them stiff springs. Off the shelf Koni Yellows are rated up to 600lbs before they need to be re-valved to accommodate a stiffer springrate.</TD></TR></TABLE>
Gabe may I ask why you run higher rates in the front when you do quite a bit of auto-x? Or does the bar make up for it?
Old Aug 23, 2007 | 08:36 AM
gabebauman's Avatar
Default Re: (excivicboy96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by excivicboy96 &raquo;</TD></TR><TR><TD CLASS="quote">
Gabe may I ask why you run higher rates in the front when you do quite a bit of auto-x? Or does the bar make up for it?</TD></TR></TABLE>
I wanted the car to be neutral as possible but still have some oversteer when I need it. Anybody that drives my car at a solo event is always very happy with how nimble it is.
Old Aug 23, 2007 | 09:17 AM
ware's Avatar
is there more than 1 version of the koni? .. meaning the sport, ? ,? ,? .. or is the sport just the best one?
Old Aug 23, 2007 | 04:36 PM
I wanted the car to be neutral as possible but still have some oversteer when I need it. Anybody that drives my car at a solo event is always very happy with how nimble it is.</TD></TR></TABLE>
Is the overteer annoying or can you control it most of the time? I was thinking of a setup similar to yours.
Old Aug 23, 2007 | 05:40 PM
gabebauman's Avatar
Default Re: (ware)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ware &raquo;</TD></TR><TR><TD CLASS="quote">is there more than 1 version of the koni? .. meaning the sport, ? ,? ,? .. or is the sport just the best one?</TD></TR></TABLE>
http://www.koni-na.com/index.cfm?
Is the overteer annoying or can you control it most of the time?</TD></TR></TABLE>
Very controllable.
Old Aug 23, 2007 | 05:49 PM
1991EX's Avatar
http://www.ajusa.com/cgi-bin/s...835ac
KONI Yellows
free shipping and handling.
raverx3m
Suspension & Brakes
Mar 30, 2016 04:25 PM
Emerica
Suspension & Brakes
Oct 11, 2007 10:52 AM
bmoua
Jul 22, 2007 05:24 PM
Captain Spock
18
Oct 12, 2006 04:17 PM
crxmadman
Suspension & Brakes
Oct 10, 2005 02:15 PM
