Suspension & Brakes Theory, alignment, spring rates....
stuff to replace
Old Sep 6, 2007 | 05:09 PM
Del Sol on Steroids's Avatar
Default stuff to replace
i found out that my lower ball joints are bad, so will replace those. What else should I replace, both front and rear, while is at the mechanics? stock lower arm.
Old Sep 6, 2007 | 05:27 PM
Guam_CiviC619's Avatar
How many miles do you have on your vehicle? What year is it? Is it lowered? Check all boots. Replace as necessary. I had a problem on my 2000 Civic (d16y7) that I wanted to troubleshoot, but never got around to it. Every now and then, upon abrupt acceleration it would "clunk" a little bit. I suspected it was the transmission. I recently did a suspension overhaul and also replaced my driveshafts with <u>new</u> units, despite the CV boots still looking in decent condition after 98,xxx miles. The problem seems to have been resolved. I checked the shafts for any torsional slack by hand and it seems there was a little play, that seemed the most likely source of the problem.
Old Sep 6, 2007 | 05:38 PM
Default Re: (Guam_CiviC619)
'94, 180000 on the odometer. bought it 2 years ago with around 17000. my car also makes a clunk noise when accelarating or decelarating. I'm want to do a overhaul but not hte entire energy suspension kit. I recently changed the axles, just to change them and found that it snapped the inner boot assembly.
norcali707
Honda Civic (2001 - 2005)
May 1, 2013 05:47 PM
dpacheco
Suspension & Brakes
Nov 1, 2010 01:52 AM
GunSamir
Oct 27, 2010 07:19 PM
BrokeLude
Jul 27, 2004 07:50 AM
Bbasso
Sep 18, 2002 04:45 PM
