Suspension & Brakes Theory, alignment, spring rates....
Help with Function7's
Old Sep 6, 2007 | 10:45 AM
blazin415's Avatar
Default Help with Function7's
Old Sep 6, 2007 | 04:15 PM
Guam_CiviC619's Avatar
Why wouldn't you be able to use them?
Old Sep 6, 2007 | 06:50 PM
BlueIntegraBoy's Avatar
Default Re: Help with Function7's (blazin415)
Yes, Function7 does make LCAs for 92-95 Civics/94-01 Integras.
Old Sep 6, 2007 | 07:46 PM
DavidR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blazin415 &raquo;</TD></TR><TR><TD CLASS="quote">i have a 92 civic with tokico illuminas and stock lca, would i be able to use fucntion7 rear lca with my shocks? planning to go with the itr sway setup...</TD></TR></TABLE>
Of course you would be able to use the Function7 LCAs.
Old Sep 7, 2007 | 03:02 PM
blazin415's Avatar
my friend got sume illuminas and he couldn't fit the oem type rear lca onto his car, thats why i asked.
Old Sep 7, 2007 | 07:32 PM
09civichatch[BRS]'s Avatar
Default Re: (blazin415)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blazin415 &raquo;</TD></TR><TR><TD CLASS="quote">my friend got sume illuminas and he couldn't fit the oem type rear lca onto his car, thats why i asked.</TD></TR></TABLE>
ITR LCA
non ITR LCA
Old Sep 7, 2007 | 09:44 PM
Stoich EG2's Avatar
you sure he ordered the right ones? 92-95 civics and integras differ from 96-00 civics
Old Sep 9, 2007 | 06:51 PM
beav's Avatar
Default Re: (Stoich EG2)
if he had type r control arms, he needed illuminas for a type r. the type r lca is way different...like the one pictured above. if you have stock lcas and your illuminas fit on them now..then you order F7s with the same design as your lcas.
when you get the itr sway bar, you can use stock endlinks ITR endlinks, but you will only be able to use the center mounting hole on the F7 arms. if you want to use the soft or hard mounting hole, you will need to upgrade to adjustable endlinks. most people use hemi style spherical ball joint endlinks, but they can get quite lound and rattly if not proporly installed, or after continuous wear.
Old Sep 11, 2007 | 07:11 PM
DavidR's Avatar
This all depends on which rear shocks he's got.
If he got 92-95 civic shocks, there is no reason they didn't fit.
If he got 96-00 Civic shocks, the lower bushing on the stock LCA is too wide, and they would not fit.
If he got ITR style shocks, no way to make that fit with stock Civic LCAs.
In the first two cases, Function7 has an LCA that will fit. If he has EK rear shocks on an EG, no one has a bolt on option that will fit.
Old Sep 17, 2007 | 11:49 AM
blazin415's Avatar
Default Re: (DavidR)
so i will be good with the specific function7 made for usdm civic to use itr sway bar right?
Old Sep 17, 2007 | 12:24 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Sure, I'm using an ITR rear swaybar with my stock non-R LCA's, no problems.
Jimmy
Jul 24, 2007 07:14 PM
94teggieGSR
Apr 21, 2006 07:46 AM
kefka
11
Jun 24, 2005 12:58 PM
Civic138
Mar 15, 2005 05:17 AM
. o 69 o .
Sep 9, 2003 06:03 PM
