coilover help
The coilover should work with the accord, but as for the strut itself, only the front will work. The rear will not. But the sleeve GC coilover I believe should work on the prelude strut for both front and back. But you can't take a 5th gen accord strut and GC coilover sleeves and install them in the prelude. Like I said, the front will bolt in, but not the rear. But you might be able to use the actual GC itself and use it on the prelude struts.
If anything you can give GC a call Don or Mark can help you 530-677-8600.
DCTODAR
Nov 23, 2005 11:36 PM
