Camber adjust on coilovers
Old Member
What is it for?
Ok, let me ask it another way. When installing coilovers, do we or should we adjust them? If we do or should, should adjusting camber require special alignment tools, which most car owner would not have at home.
Also, why is the adjustment only on the front and not the rear coilovers? On Hondas, it's the rear that need some camber adjustments, correct?
Cool Cool Island Breezes. BOY-EE
Re: Camber adjust on coilovers
You cant camber adjust a multilink or double wishbone suspension with camber plates. That's why Honda rear coilovers don't have it.
Newer Hondas have McPherson strut suspensions up front. You can camber adjust those via top hats.
What kind of car do you own, OP?
You can't adjust camber by itself or you will throw off all otheralignment angles. You need to get the car aligned.
I'm almost 100% that the 2010 uses double wishbones. You cannot adjust camber with your coilover top hat. You need to buy camber control ball joints or arms.
But...you don't really need or want a camber kit. Maybe for the rears if you're really concerned...but still probably not.
Old Member
I just found out the for the application (2010 Accord), the coilovers does not have camber adjustment plate. It was listed in the description and pics, but I didn't know that it did not apply. It made no indications on the description.
Moving forward..Going Low - soon.
Ghetto Racing
09-19-2001 06:22 AM
