92 EG civic cx rim and brake question.
Hey... Will klutch SL1 16X8.0 offset: 15 rims, work with wilwood front brake kit.
I am wanting to purchase a wilwood front brake kit for the normal spindle and rotor size of "240mm". So plain stock spindles on the 92 CX model (hatch) with 240mm rotor size.
I was told i'd have to roll the fenders and if I lower it too much front and back camber kit (already have the back camber kit)...
I really need to know if the 240mm wilwood brake kit would clear the Klutch SL1 rims in front. P.S. back is drum...P.s. I have tried to find this same question and can't!
Thanx!
Thanx!
Re: 92 EG civic cx rim and brake question.
I'm afraid the only person who can answer your question would be someone with the exact same setup. Nobody here will know if the wilwoods will fit under the Klutch wheels unless they tried it. On the Wilwood site, there's a PDF document that has all the measurements for the brake setup you are talking about. With that you can contact Klutch. My guess is that they will fit in diameter, but I can't say for sure on the back spacing. Those Klutch wheels look flat on the back face and may need to be machined to fit.
accordselux
05-19-2006 05:00 PM
