Suspension & Brakes Theory, alignment, spring rates....
DA & EF Coilover compatibility
Old Nov 20, 2008 | 01:26 AM
mrpoi808's Avatar
Default DA & EF Coilover compatibility
I just purchased a set of skunk2 pro-c for my crx, but given the fact that I swapped out my drums for discs off of a 93 integra, i bolted up the coilovers and have an issue with them being too short, so my questions is would i have a similar problem in the front being too long if I was to go ahead and purchase a full-coilover set for a 93 integra and have that installed on my crx?
Old Nov 20, 2008 | 03:15 AM
Targa250R's Avatar
be professional
No, you don't.
A brake conversion and coilovers have nothing to do with each other.
No, but the rears will be incorrect lengths.
Old Nov 20, 2008 | 03:18 AM
MSchu's Avatar
My Name is Nobody
You can also have perches built for your rear to run shorter set ups... I have seen this many times on DA/DB chassis
Old Nov 26, 2008 | 11:59 PM
pinks11's Avatar
ive had a pair of rear trailing arms from a dc on my ef before, and the shocks bolt up. you shouldnt have a problem with any clearance issues.
Old Nov 27, 2008 | 01:35 AM
96accordsir's Avatar
i got da tein basics on my ef and they are slammed all the way and the front is low like i like and the rear is so high that there is a gap between the tires and wells. ill trade you im looking to trade them for ef ones so i can slam the rear?
Fre$hlyLurkin
Apr 12, 2011 06:06 PM
iheartmyej8
Nov 23, 2008 07:55 AM
jackson_GeeSeR
May 12, 2003 02:31 PM
