Suspension & Brakes Theory, alignment, spring rates....
alignment
Old Feb 9, 2005 | 09:16 AM
o1f42's Avatar
Default alignment
went today to get my 98 integra aligned after installing gc coilovers and they said i needed front camber kit and offset tie rods and the estimate is over 400 bucks?? i know i dont' really need the camber kit but what are they talking about offset tie rods? do i really need this? or should i go to another shop
Old Feb 9, 2005 | 12:14 PM
FrostySol's Avatar
Default Re: alignment (o1f42)
How much did you lower it? I've never heard of the tie-rod thing before, you might be better off just taking it to another shop.
When I lowered mine on teins they just told me they couldn't do anything with the camber unless I had a kit (didn't buy one anyway) but nothing about tie-rods... The camber was the only thing out of spec after the alignment so I'm assuming that either the toe wasn't that bad on my car to begin with, or you don't really need the offset tie rods.
Old Feb 9, 2005 | 02:50 PM
EK4civichatch's Avatar
Default Re: alignment (FrostySol)
If your toe was set to spec then you shouldnt have to worry about anything. Alignment shops often only know about setting things to factory specs, and think anything else will screw you tire wear.
How much camber are you running??? If you toe is within range then you should be ok..
Old Feb 9, 2005 | 10:19 PM
Evs-One's Avatar
Solbros Owns Me
Default Re: alignment (EK4civichatch)
camber is NOT a tire wearing angle!!!!!
If toe is set correctly and you dont have an EXTREME amount of camber, you will not wear tires unevenly. I run -2* up front daily and have no tire wearing problems
Old Feb 10, 2005 | 03:28 AM
turnbuckle's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by o1f42 &raquo;</TD></TR><TR><TD CLASS="quote">went today to get my 98 integra aligned after installing gc coilovers and they said i needed front camber kit and offset tie rods...</TD></TR></TABLE>
the camber kits aren't an absolute must have but can be helpful depending on what you're doing with the car. i've been a tech for several years and have done hundreds of alignments, i've never heard of offset tie rods. the only thing that i can think of is that they might be talking about the turnbuckle type upper control arms for the rear.
evs-one is right... camber doesn't really contribute to tire wear.
-cory
Cap'N Chronic
27
Mar 29, 2011 04:32 PM
inspector01
Suspension & Brakes
13
Jun 27, 2008 04:12 PM
aSDthing
Suspension & Brakes
Nov 27, 2007 06:32 AM
ware
Suspension & Brakes
Mar 1, 2007 02:24 PM
civicdragger818
Mar 16, 2003 10:31 AM
