Suspension & Brakes Theory, alignment, spring rates....
Suspension setup?
Old Jan 25, 2005 | 06:39 PM
EKIM NART's Avatar
Default Suspension setup?
i have a 90 civic sedan in which i did a 90 integra ls suspension swap front and rear. i was just wondering what will be the best setup for my daily driver. should i get civic struts with integra springs, or should i get integra struts with civic springs. just want to know the pros and cons of each setup.
Old Jan 26, 2005 | 04:38 AM
.RJ's Avatar
.RJ
Default Re: Suspension setup? (Ef2Ls)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ef2Ls &raquo;</TD></TR><TR><TD CLASS="quote">should i get civic struts with integra springs, or should i get integra struts with civic springs. just want to know the pros and cons of each setup.</TD></TR></TABLE>
You're putting stock shocks and springs on?
Old Jan 26, 2005 | 05:31 AM
artifex's Avatar
say it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ef2Ls &raquo;</TD></TR><TR><TD CLASS="quote">i have a 90 civic sedan in which i did a 90 integra ls suspension swap front and rear. i was just wondering what will be the best setup for my daily driver. should i get civic struts with integra springs, or should i get integra struts with civic springs. just want to know the pros and cons of each setup.</TD></TR></TABLE>
uhhh... don't you already have integra shocks and springs on the car?
Old Jan 26, 2005 | 09:21 AM
purplegsr's Avatar
Default Re: Suspension setup? (artifex)
Um, well, the DA integra shocks are longer than the civic shocks - which is why a lot of the DA owners buy civic shocks and have very low cars. So, if you already have a Civic with Integra springs and shocks swapped in, I am assuming your car is about 1/2 to 1 inch higher than stock?
If that's the case, I would go back to the civic shocks and civic springs. I guess you could try Integra shocks with civic springs, might be a little lower than it is now, but not by much. I think the spring perch is about the same height on the EF and DA shocks, but the DA just has a longer shock body and shaft. I am all for matching suspension components, so I would leave it as is, or go back to the civic setup.
mrchevez
Jul 21, 2009 09:06 AM
AK77
Jul 20, 2006 10:59 AM
1wiperDude
Mar 21, 2006 04:40 PM
DragonLegion66
16
Aug 22, 2005 09:28 PM
Whig-it
Suspension & Brakes
Jun 9, 2005 05:59 PM
