Suspension & Brakes Theory, alignment, spring rates....
Alignment really necessary?
Old Jan 24, 2005 | 09:31 AM
apm's Avatar
apm
Default Alignment really necessary?
well i just finished installing my front coilovers and the first 3 days were pretty good. no squeking no rubbing no pulling over left or right. i tried at high speeds and bumpy corky road and everything seems to be working just like before when the suspension was still stock.
question is....do i really need an alignment after the change to coilover? everythin seems to be ok. and the drop i think is about 3" or more. I set the thread to the lowest setting on the front. the rims are still stock steelies 14"
Old Jan 24, 2005 | 09:44 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: Alignment really necessary? (apm)
You can't always detect changed toe until your tires go bald. Alignment good. Which reminds me...
Old Jan 24, 2005 | 09:48 AM
apm's Avatar
apm
Default Re: Alignment really necessary? (94eg!)
i had experienced before that whenever Les S. does my alignment it will screw everything up.
either it will pull hard to the left or right. in short how was it that it's better off without the alignment. that's why im having a 2nd thought about the alignment. well as they say if ain't broke don't fix it.
Autoworks's Avatar
Yes you need an alignment. Any time you change your suspension settings an alignment should be done because your angles do change.
Old Jan 24, 2005 | 09:49 AM
Tyson's Avatar
go ahead, record your current mileage and check back with us in a month. let us know how things are.
Old Jan 24, 2005 | 12:13 PM
RineRacing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by apm &raquo;</TD></TR><TR><TD CLASS="quote">i had experienced before that whenever Les S. does my alignment it will screw everything up.
Then go somewhere else. Play it safe and have an alignment done, otherwise you run the risk of having to buy a new set of tires is the near future.
Old Jan 24, 2005 | 12:59 PM
apm's Avatar
apm
Default Re: Alignment really necessary? (RineRacing)
thanks for the reply guys...will try alignment with other shop as well
Old Jan 24, 2005 | 06:49 PM
travis's Avatar
either it will pull hard to the left or right. in short how was it that it's better off without the alignment. that's why im having a 2nd thought about the alignment. well as they say if ain't broke don't fix it.</TD></TR></TABLE>
That's not an alignment, that's a hack job. Some of these alignment shops can be really frustrating when they do a poor job. Still, it needs to be done unless you have a huge tire budget and don't drive in a straight line. Find a good shop that's willing to do it more than once if they screw it up.
Old Jan 24, 2005 | 08:24 PM
ek_will's Avatar
get an alignment your tires will get eaten up.
taimysho0
15
Oct 11, 2023 09:49 PM
jxhxb
Suspension & Brakes
Jan 9, 2009 10:51 AM
dwelcher
Honda S2000
20
Dec 1, 2008 10:38 AM
brownpride016
Sep 15, 2007 12:10 PM
Todd00
Sep 6, 2002 07:17 AM
