Suspension & Brakes Theory, alignment, spring rates....
HELP!!
Old Feb 2, 2005 | 11:54 AM
blk02ep3's Avatar
Default HELP!!
heres the issue: i have a 02 EP and i bought the RSX type-s 5 lug brake conversion for it... so i got both rears on and the front passenger side and i put the front drivers side on and the top of the tire sticks out and the bottom of the tires goes way in and when i took the wheel back off i noticed that the spindle is leaning down not straight so i thought it may have been the axels are not in so i put the wheel back on and drove both in reverse and in regular gears and there was nothing wrong so the axel has to be in right.. what else could be causing this? please help..
Old Feb 2, 2005 | 02:34 PM
numbnuts22715's Avatar
you dont need to post two threads with the same question.. especially whenever theyre only like 5 away from eachother on the list...
Old Feb 2, 2005 | 02:50 PM
blk02ep3's Avatar
Default Re: (numbnuts22715)
i only did that because the topic on the other one was weak..
Old Feb 2, 2005 | 10:31 PM
jeremyG2teg's Avatar
Default Re: (blk02ep3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk02ep3 &raquo;</TD></TR><TR><TD CLASS="quote">i only did that because the topic on the other one was weak..</TD></TR></TABLE>
Yes, mad weak yo...
Commence tech related replies to this topic.
tone*def
Honda Civic (2006 - 2015)
Apr 9, 2006 12:15 AM
t0ekn3e
Apr 29, 2005 02:02 PM
93_cxEG
37
Feb 13, 2005 09:56 PM
succdeez
Mar 3, 2004 12:23 PM
LillDragun
87
Feb 5, 2004 06:19 AM
