Suspension & Brakes Theory, alignment, spring rates....
which calipers?
Old Sep 13, 2010 | 08:13 PM
white-eg's Avatar
Default which calipers?
have the jdm 36mm 5 lug conversion on my 99 gsr. have spoon calipers on right now and going back to stock. do i need to find a type r caliper? would a gsr caliper fit? i read somewere prelude calipers are the same. are they? would do i need to do? thanks
Old Sep 14, 2010 | 08:01 AM
roastbeefrichie's Avatar
Default Re: which calipers?
ITR calipers (stamped 1 7 C L 1 5 V N) can also be found on other honda/acura listed below:
Originally Posted by roastbeefrichie
1997-2002 Acura CL V6,
97-01 Acura Integra Type R,
91-95 Acura Legend,
96-02 Acura RL,
95-98 Acura TL,
92-94 Acura Vigor,
91-99 Honda Accord Wagon,
95-02 Honda Accord Sedan,
98-02 Honda Accord Coupe,
97-98 Honda CRV,
93-01 Honda Prelude VTEC
no, 94-00 integra ls, gs, rs & gsr calipers (are all stamped 1 7 C L 14 V N) wont fit on your 5 lug
yes prelude VTEC calipers (stamped 1 7 C L 1 5 V N) will work on your 5 lug, plug & play
Originally Posted by BrakeExpert
For those of you with a soggy brake pedal after caliper installation, here is the CORRECT bleeding sequence:
Bleed the brakes Right Rear, Left Front, Left Rear, Right Front. You do not go farthest to closest with Hondas.
Always bench bleed the Master cylinder when replacing the master cylinder, ABS unit, or proportioning valve.
Old Sep 14, 2010 | 04:40 PM
white-eg's Avatar
thanks!
Old Sep 14, 2010 | 08:34 PM
thanks!
anytime homie
Lthlintgra09
May 21, 2009 07:34 PM
Brooklyn101
Suspension & Brakes
Sep 30, 2008 10:27 PM
CRX_Fenatic
Dec 12, 2006 06:40 PM
Ekizzle
Sep 24, 2003 12:41 PM
Doctor CorteZ
30
May 31, 2002 02:06 PM
